Question about NEC Laptop Motherboard (1580262530)
Computer shuts off on start up. It may load windows and everything would look fine however it shuts off completely after 1 min. If I let it do the chkdsk, it completely shuts off at the 80% read.
  • 158 Answers
I'm sure that this could be a heating problem. Check if the fans are spining properly.
Posted on Jan 10, 2009
I had a power failure in my area. When power was restored my pc booted up ok but the monitor screen only stays visible as it should for about 3 seconds, then it goes black screen. I have powered...
Close windows down. Wait 15 - 20 mins, then power monitor up but NOT windows. Screeen should say "NO SIGNAL in centre. If t does not, wait five mins If still no display shut down and wait another 5 mins. Then start monitor un ANDt windows.. All should be OK now, If not shut EVERYTHING down and disconnect from mains ovrernight. (PC riouter/modem,,,, EVERYTHING . 12 hours later, re-connetc in THIS order - 1.) MONITOR 2.) PC 3) ROUTER/MODEM Should be OK now.
Aug 17, 2011 | Acer X193W LCD Monitor
My Sony Laptop is stuck, not reboot nor shutdown,
Hey there, when your computer completely freezes while still being on you simply have to remove the power cable and pull out the battery. Then put the battery and/or power cable back in. When you start up your computer again it will say your computer wasn't shut down properly, simply select "start windows normally" and everything should be fine again.
Jul 27, 2011 | Computers & Internet
My '94 Ford Taurus stalls whenever its idling in neutral or drive, in park its completely fine. When I give it gas in drive or neutral its completely fine and runs perfect but if i come to a light, or slow...
Disconnect your battery black wire off for 1/2 hour reconnect turn on all assesorys lights radio blower start car leave run for 5 min shut off for 5 min idle is controled by the computer the load
brings the idle up. Should be ok if not you may have to ajust the idle screw a little and then do this all over
Feb 01, 2011 | Ford Taurus Cars & Trucks
Added memory causes machine to shut down and boot up continually.
it proves that your emacchine does not support your addition of memory try a bit lower capacity memory
Aug 22, 2009 | Computers & Internet
Dell Inspiron 530 randomly shuts down and restarts
Sounds like it could be a virus. Or, a heat buildup problem - are all fans inside machine working? Is the fan inside the power supply operating? Was there any work done inside the computer recently?
If the hdw is all ok, go out and buy yourself a copy of Norton Internet Security 2009 - 1 user lic - $49.99 @ Staples. Do *not* buy any earlier vers. of this software! Install, update it, run computer computer scan - probably will find/remove some/many viruses.
If this helps, please take the time to rate my response to you.
Thanks and good luck.
gurutim
Mar 22, 2009 | Dell Inspiron 530 Desktop Computer
LG L1940HR screen blinks for 1 min. when turning monitor on
some monitors blinks when you have a start up. this usually happens on an outdated video cards. so if it works fine then its ok then. but try checking if you have the latest update for your video card. this happens on an outdated nvidia geforce 7300 go on a laptop runing on windows vista 32 bit. once i updated the videocard, it doesnt blink anymore at start ups.
Feb 06, 2009 | LG FLATRON L1970HR LCD Monitor
Will not display output from Computer
Probably the video resolution or the monitor Refresh Rate (eg: 50/60/75 Hertz) is set too high in the operating system, which over-drives the monitor electronics and it is unable to display anything.
If you restart the computer manually (hold in the power button for 5 seconds, the computer will shut off, turn it back on again) you will see the normal BIOS and Windows startup display on the monitor, but then as Windows completes it's startup it returns to the error message you see.
To fix this, restart the computer manually and start the computer in Safe Mode. To do this press F8 just before the computer starts to load Windows, and choose Safe Mode. Once in Safe Mode, you should see the monitor working correctly.
Now restart the computer in Normal Mode and everything should be fine.
Dec 23, 2008 | Westinghouse LCM-19v1 Monitor
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Repeatedly restarts after Windows loads
NEED HELP SETTING UP WINDOWS XP . MY WINDOWS IS NOT LETTING MY ICONS UP ITS SAY ACTAVITE WINDOWS
Oct 05, 2008 | Microsoft Windows XP Professional for PC
No driver appearing in Vista
Sorry this is late but:
Unplug the monitor from the PC and then boot.
after you hear the windows starting sound wait for it to load everything up (say 1 min) and plug in the monitor
Windows then plays the "i have found an unknown device" sound and begins to search for drivers
Wait 5 min for it to do this and then shut down the computer with the power button.
Re boot
Monitor should work.
Note: you must be connected to the net for this to work.
- Adyhood
Dec 14, 2007 | Acer AL2017 20" LCD Monitor
NEC Laptop Motherboard (1580262530) Logo
46 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
