Question about Printronix P7005 Matrix Printer
Crtg missing instal new ribbon printronix p7005
Error code in monitor: crtg missing instal new ribbon cartridge (for printronix p7005). Cartridge P/N: 255049-103
  • 826 Answers
This error message normally happen due to following reasons..
1. Didn't remove protective tape on cartridge.
2. Didn't properly seat cartridge.
3. Contacts on carriage need to be cleaned.
4.If you inserted and removed Cartridge many times..
Try to do it: You can wipe the copper contact plate on the cartridge over with a slightly damp piece of kitchen towel using distilled water. While doing this you need to turn off your comp and printer. Let the contact plate dry for a minute or two before putting back on.
After inserting the cartridge, run the print head cleaning program 3 to 4 times for best results as this will clean the heads and push the ink through.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Posted on Nov 28, 2012
jwr1914
  • 31 Answers
SOURCE: Print result p7005
You have something caught in the hammerbank cover. Sometimes a piece of lint, paper chad or some ribbon fabric will get hung in the holes and need to be cleaned out. Remove the ribbon, open the 'mask' as far as you can and look into the hammerbank area to find and remove the debris. Reload the ribbon and run a test print to see if the problem is solved. If not, the problem will usually be a hammer that is not retracting.
Posted on May 29, 2009
  • 12 Answers
SOURCE: printer
just go to add printer and install driver after finished wait for some more option.
Posted on May 17, 2010
printertech1
  • 96 Answers
SOURCE: My Printronix P5005B says "RIBBON STALL" what
Remove the ribbon and check for play when turning the plastic ribbon hub by hand. If it is loose try tightening with a torx bit. But it is probably cracked and needs to be replaced.
Posted on Mar 05, 2011
printertech1
  • 96 Answers
SOURCE: printer is not seeing a new ribbon
It is under the right ribbon. It is a small barcode reader.
apitjayakusu
SOURCE: driver printronix p7005
i have a printronix PSA3 P7005 but my driver is lost,please send me the driver. i want to re-install
Posted on Feb 06, 2012
Printer given barcode missing install new ribbon
There are two styles of P7000 a spool ribbon style and a cartridge ribbon style. You are getting a barcode error then your printer is looking for a ribbon spool not a ribbon cartridge.
Cartridge Ribbon:
PRINTRONIX 255048 402 P7000 EXT LIFE CARTRIDGE RIBBON New
Spool Ribbon:
PRINTRONIX 179499 001 ULTRA CAPACITY RIBBON 6 PACK New
Jan 03, 2016 | Printronix Office Equipment & Supplies
Bc sensor error
Bar code read error: The printer does not detect the presence of the ribbon bar code sensor
1. Power down the printer. Remove the ribbon and wipe the two lenses of the ribbon bar code sensor with a lint-free cloth or cotton swab.
2. Install the ribbon and power on the printer. If the message appears again, replace the ribbon.
3. Power on the printer. If the message appears again, power down the printer and remove the paper path or top cover to gain access to the card cage. Make sure the cable from the ribbon bar code sensor to connector J122 on the controller board is undamaged and has a good connection to J122.
4. Power on the printer. If the message appears again, power down the printer and replace the ribbon bar code sensor.
5. Power on the printer. If the message appears again, power down the printer and replace the controller board. Record the message and return it with the defective board.
I have the parts in stock if needed cardenas_rory@hotmail.com
May 06, 2014 | Printronix P7005 Matrix Printer
Printronix error b22 decompressed size
flash ic having problem logic crad have to change
Feb 04, 2014 | Printronix P7005/p7010/7205 Ultra Capacity...
Printronix p7005 reffil
do not use refill cartridge printing may be affected. use only new and exact cartdridge
Nov 08, 2013 | Printronix P7005 Matrix Printer
Driver printronix p7005
Feb 01, 2011 | Printronix LineJet® P7005 Printer
Print result p7005
Oct 19, 2008 | Printronix P7005 Matrix Printer
Printronix P7005 Matrix Printer Logo
512 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Cliff
Nick
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
