Question about Brother MFC 8820D All-In-One Laser Printer
My printer says doc cover open on a mfc 8820d how should i fix.
    Problem Solver:
  • 5 Answers
You have to close the ADF. If the ADF is closed, then the left hinge is probably broken. Look for "MFC-8820D hinge" to find the solution in FixYa.
Posted on Jun 08, 2009
  • BL123 Jun 11, 2009
    The most common problem is a broken left hinge. Check it and if you find it broken, replace with LP2403001
    http://salestores.com/brotherlp240.html
I had the same issue. There is a small tab on the inside of the top lid. This tab goes up and down when you open and close the lid. Tap it a few times and it will reset.
Posted on Jan 25, 2010
Soulvisitor
  • 1113 Answers
SOURCE: doc cover open
Yes there is and I know your problem have a look at the left hinge on lid that you lift to put down an original for copying, it will be breaking apart, the switch is black in that same corner on doc feeder base, as the hinge breaks apart the doc feed lifts in that corner causing "doc cover open" cause that switch no longer gets pushed in when lid is shut
Dodgy repair - tape switch closed, but doc feeder will not work properly/can use glass.
Repair - Easy removal of three screws and replacing 20buck hinge bought from brother dealer...part no.LE8731001 Hinge assy left.
Now that's FIXYA!
Posted on Nov 19, 2007
Soulvisitor
  • 1113 Answers
SOURCE: How to replace broken hinge on ADF on Brother MFC-8820D printer
Look at back of machine and at your new hinge, note the screw hole, if you undo both of those on the back of the printer, entire doc feed will come up and out, BECAREFULL just lift A LITTLE is enough to enable hinge base to be free of sockets (many cables attached) and place doc unit slightly sideways on copy glass to enable yourself access to 3 screws that hold hinge.
Posted on Jan 05, 2008
SOURCE: paper jam in brother MFC 240C
the paper ripped at the corner in little pices and it is jamed in the printer how can I remove it
Posted on May 31, 2008
SOURCE: mfc-7220 Back Cover Open
This one made me crazy, but I finally figured it out. Turn the machine around so that you are facing the back. Open the back cover. Pull down the second smaller roller cover inside the machine. If you look closely at the second smaller cover, on the right hand side (closer the the inside of the machine), is a very thin round piece of plastic that is only half the length of the smaller cover. There are 2 thin plastic tabs attached to either end of this round piece of plastic. Gently shift this over so that the 2 plastic tabs can now go into the space provided for them. I had to move mine over only 1/4 inch.
Posted on Nov 13, 2008
komguy
  • 2306 Answers
SOURCE: brother 8820d MFC auto doc feeder does not work...
You need a new hinge so the cover will sit down properly, or paper will jam anyway, but it sounds like there is still a scrap of paper on one of the sensors inside the ADF, you need to look with a flashlight down thru where the paper goes and also look up thru the slot with the ADF lifted.
Posted on Sep 11, 2009
Testimonial: "thanks......i didnt see signs of paper anywhere. could you tell say exactly where the sensors are located inside the ADF?"
MFC 8820D ADF Will Not Feed Document
The ADF in my Brother MFC 8820D will not feed a page through
Feb 23, 2013 | Brother MFC 8820D All-In-One Laser Printer
How to connect MFC-8820D to a router for wi-fi operation
SETTING UP A SHARED NETWORK PRINTER
Any printer that isconnected to a computer and is connected on a LAN can be configured so allother computers on the same network can print to this printer. This means thecomputer with the printer attached to it MUST be booted up at all times whenother computers want to access the printer.You need to install theprinter driver on the computer and configure it as a Shared printer.The other computers on thenetwork need to add this printer to their computer.Follow these steps toset-up a shared network printer :-1. Connect the printer tothe computer and install the printer driver.2. Open Printers and Faxes- right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change theShare name, then click OK3. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation.Follow these steps toconfigure the computers on your network :-1. Open Printers and Faxes- click Add a printer - Next - select a network printer, or a printer attached to another computer - Next.2. Select Browser for aprinter - Next3. Click on and expand theMicrosoft Windows Network down to the computer with the printer - Next4. Select Yes for - Usethis printer as the default printer - Next - Finish5. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation.
Jul 23, 2012 | Brother MFC-8820D Laser Flatbel...
Maintenance error 7 on a mfc 8820D
Thank you for posting to Fixya.com and it is my pleasure to guide you.
I have scanned through the appropriate sections of the
Brother MFC-8820D User Manual & Brother MFC-8820D SERVICE MANUAL
and find no referance to a "maintenance error 7". Please include any and all messages given on the panel LCD!
Please press the reply button and I will check back tomarrow.
It is always a pleasure to help!
Jun 15, 2011 | Brother MFC-8820D Laser Flatbel...
Brother 8820d MFC auto doc feeder does not work...
Sep 11, 2009 | Brother MFC 8820D All-In-One Laser Printer
Hi I had a paper jam in my MFC 8820d - I removed the cover and removed the paper but I still get a Paper Jam error msg. I powered down the machine and turned back on - still same error msg. I have removed...
This can sometimes be related to paper dust interfering with a sensor. A burst of canned air can fix the problem. Just pull out the toner, open all of the covers and spray air into all the little crevices. You might want to do this outside, in case toner is loose in ther, so as not to make a mess.
Sep 02, 2009 | Brother MFC 8820D All-In-One Laser Printer
Unit says Doc feed open. After checking many times it appears closed but can't clear the message and swith from fax to copy
raise the lid and hold the black pin down, located on the left back underside of the lid. your left hinge is probably broken or cracked causing the lid not to go down all the way.
May 26, 2008 | Brother MFC 8820D All-In-One Laser Printer
Jan 05, 2008 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC-8820D Machine Error A
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor.
In this case, make sure that there is no mechanical load present on the main board.
While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
http://www.fixya.com/support/t5660619-7a_error
Oct 02, 2006 | Brother MFC-8820D Laser Flatbel...
Brother MFC 8820D All-In-One Laser Printer Logo
249 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
