Question about Maytag Washing Machines
Maytag front loading washer
The door on my washer recently started opening at the bottom allowing water to rush out. The door was still locked at the top, but the bottom of the door pushed out allowing the water to get out. When I pushed the off button, the machine continued to fill with additional water making the problem evn worse.
  • 640 Answers
First check that gasket around door for rips tears and warpped condiction..if that not the case this will help...easy now go slow than check unit,,grasp the door and bend SLOWLY..from bottom of door and hinge,,because sometimes we hang wet clothes over the door ,and bend the hinge..the last but neat trick is to put 2 washers behind the door latch lock..between the door latchlock,,and the inner panel..that will push the latch back and make the door itself get tighter against the gasket..dont worry about the extra water that is just a flush down,,,keep me posted onthejob
Posted on Jan 10, 2009
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    We were on vacation for about month and a half. Upon my return, I opened the front load washer (Maytag Front Loader Neptune Super Stack Mo. No. MLE20000AYW) and water came rushing out at me. The water...
    Shut your water taps of at washer when you go away for long periods /you must have a small amount of water leaking pass water inlet valve of washer / You should have that replaced b/c that is the first sign that it may stick completely open at a later date/water valve is cheap compared to a flood...Hope I helped if I did please vote need more help please ask and good luck
    Feb 05, 2011 | Maytag MLE2000 Front Load Stacked Washer /...
    Door will not close
    Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
    Thank you !!
    Jul 09, 2010 | Frigidaire ATF6000ES Front Load Washer
    Can't get the door open
    Thank you !!
    Jul 06, 2010 | Frigidaire ATF6000ES Front Load Washer
    Door lock light is on door is not locked and
    Thank you !!
    Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
    Frigidaire affinity door will not lock when door is closed or register door is not closed when open
    Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
    Maytag neptune front load washer says control lock and wont start and buttons wont work
    unplug the washer for 15 minutes then:plug it back in and, restart a few times in a different cycle canceling each time until the door opens. Do this only if the tub is not full of water if it is let me know and, i'll show you how to drain the washer first before we try to open the door.
    Jun 09, 2009 | Maytag Neptune MAH6700A Front Load Washer
    The door is locked on my front loader washer.
    PUSH THE START PAUSE BUTTON, AND CLEAN THE LINT TRAP AT THE BOTTOM OF THE UNIT
    ROB
    Apr 14, 2009 | GE WPXH214A Front Load Washer
    Maytag Neptune Leaking From the Door
    possibly door lock not latching could be a bad wax mtr (within door lock asm) or control board
    Dec 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
    The door will not open.
    This is usally a door lock problem, or control board(you can pull bottom panel off and reach up by door lock and pull on a little plastic ring to release the door, make sure there is no water that can pour out)
    Oct 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Washing Machines Logo
    213 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
