Question about LG WM Washing Machines
My LG 7.5KG WD-10165FU doesn't want to spin
Front loader washing machine doesn't spin. It makes a humming noise but the drum doesn't turn
SOURCE: Washer LG Model WD-8013F Noisy & vibrates badfly when spinning
I had same problem, the bowl is supported by (2) large springs from the top & two telescoping shock absorbers underneath.
I inverted the machine, found a large hollow retaining plastic bolt had falled out of the shock absorber,causing the bowl to be out of balance & the drive belt to be missaligned.
I reinstated the plastic retaining pin/bolt then tried the machine again.
Now the damn thing refuses to wash or spin.
I'm not happy.
Posted on Nov 06, 2008
SOURCE: washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
* Inspect the water pump for a blockage
* Inspect the coupling
* Inspect the transmission
* Adjust the drive belt tension
* Check the motor bearings
* Check the drum brakes
The above are possibly the general remedies for this problem.But possible if the problem still persists after this, possibly the drum bearings might have been damaged during the previous heavy vibrations.Please do post comments.Will be glad to help you out.Good luck.
Posted on Jan 16, 2009
MNTECH
  • 1543 Answers
SOURCE: Lg Tromm washing machine drum will not turn
the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Posted on Mar 01, 2009
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
heatman101
  • 43501 Answers
SOURCE: my kenmore washing machine (front
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Mar 22, 2011
Hi my LG 7.5 kg (10165fu)front loader washer has just stopped functioning. It shows on screen a big "CL".What do i do? Pls help. Griffiths
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and thats it. It might have a little kids face above a lock key, inbetween the wash and rinse buttons, hold these for 3/5 seconds and it should work
Dec 03, 2016 | LG Washing Machines
My new LG front loader washing machine makes humming-buzzing noise when starting (only hot washing from 60C and above)
it is buzzing because it is try to let in hot water and is activating the hot water inlet valve/solenoid
Sep 06, 2015 | LG Washing Machines
I have a LG front loader WD-1049C it's 6 yrs old And has just started to make a loud noise while in spin cycle All other cycles are fine
If the washer is making a loud noise the tub bearing might need to be replaced. This is a very involved repair and will require disassembling most of the washer. The manufacturer recommends that if possible the complete outer tub and bearing be replaced rather than attempting to replace just the bearing in the tub. If the bearing is bad the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine
Feb 19, 2015 | LG Washing Machines
I have an LG 7.5kg WD 10165FU front loader and it has stopped spinning. what can i do?
Hello there, Ok, first check under the lid, there is a peg that goes into the top edge of the washer. That is a switch. The idea between this is that it is a safety feature for mostly kids, so that when the washer is on that high speed spin cycle, that a child does not open up lid and stick there arm or hand in and have it injured. Most washer are designed so that the washer will only spin when the washing machine lid is down. So, of course you have it down, but sometimes the lid might have got a little bent or warped. So first try with lid down pushing down on lid while on spin cycle. If still wont spin, most likely it is that switch that that peg goes into, if you take a knife or flat head screw driver, with lid up on spin cycle and push into that hole with the knife or flat head screw driver and do not here a click when pushing it and releasing it, then you need to replace that switch, it is pretty cheep, normally under 20 bucks and a appliance store and when picking up the part they can tell you exactly how to replace it yourself, it is pretty easy and only takes a few minutes. Hope this helps. Mike Please select a 4 thumb up, if this helped you, and atestimony if you like. Also take advantage of fixya expert assistance live. For a price, expert works with you while you work on your washer or anydo-it-yourself project. Fixya is always less expensive than a service call.
Jul 26, 2011 | LG Washing Machines
My LG front loader washer stops in the middle of it washing with the error code LE. For some reason or another it sounds as if a screw is loose in the drum or something in or near the drum is off cause it...
"Lock Error"
The fault code suggests that the lead that runs to the door interlock switch is faulty, has come off or is loose (Probably the latter by what you describe). I can't inagine how this intermittant error could be linked with what sounds like an item stuck in the drum.
For the item in the drum, I have sucessfully removed screws and the like by thoroughly draining the machine then turning it onto its face, supported by enough bricks or other items to allow me to have the door dangle open. Gently spin and rock the drum back and forth and let gravity do the work. It doesn't always work, but it often does.
Jun 28, 2011 | Washing Machines
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Front Loader spinning failure
check you can turn drum by hand if rotates freely then youre motor brushes will have worn out the motor needs to be removed to fit replacements but they are cheap to replace.
Aug 10, 2008 | Neff W5340X0 Washer
Washing Machines Logo
236 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
