Hp laserjet1020 plus printer can not print from remote desktop but print from localy
When connect 2008rs server by remote desktop then my local hp 1020 laserjet printer show as redirect printer in remote desktop printer list but when want to do print then no print and no show error
5 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: HP 1020/1022 PRINTER OFFLINE
No drivers / Incorrect driver setup on user pc
Posted on Oct 19, 2007
khanmohammad
  • 188 Answers
SOURCE: Remote desktop printing
Hi Prebhakar,
Please click on the web link given below and perform the steps as provided in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00763382&cc=us&lc=en&dlc=en&product=439320
This should fix the issue.
Have a great day!
Posted on Mar 24, 2008
FixinFax
  • 3085 Answers
SOURCE: MY HP Laserjet 1020 printer makes shadows on what
This a very recent model. Try replacing the toner cartridge.
Posted on Jul 22, 2009
  • 20 Answers
SOURCE: I have a HP laserJet
Possible problems:
1.Missing drivers on your desktop machine: This one seems the most likely to me. Go to HP's website and make sure you have all of the software installed with the latest drivers.
2. Bad connection: You may have the cord plugged all the way into your computer, but if the computer slot is faulty (which happens from time to time), then you might want to try a different port.
Best of luck to you!
Posted on May 02, 2011
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Print jobs get stuck in the queue
OK - all the answer posts on HP sites, Experts Exchange and MS have been a joke to this problem so far. HP 10xx series LaserJet printers do not work (well) in a shared environment. I have found two solutions to this problem. If you really don't understand shares/printing/services/firewall exceptions - don't bother trying this - buy a networked printer when the toner runs out of the HP10xx.
If you want to spend a few hours or about $100 for a print server/NAS device, read on... I HAVE an HP1022 shared on a Windows XP Pro SP3 machine serving as a print server to a Vista laptop, a Windows 7 desktop and a Mac-Mini running OS X 10.6.x. ALL are working.
1. Buy a network print server device (or a NAS device with an included print server - I picked up a Buffalo LS-CHL 1TB and it worked out of the box. I AM NOT ENDORSING BUFFALO NAS servers, they get horrible reviews and you may end up having the same problem down the road due to the NAS device) In this case, your print clients (Win7, Vista, XP, MacOS X) can use a traditional SMB Windows client to print or the BETTER solution is to use the print services for Unix client that comes with Windows but is not installed by default. Both clients work, you may have fewer problems down the road using the Unix (LPR) client. See http://www.alexfalkenberg.com/2009/10/06/linkstation-windows-printing-problem-solved/ This is an excellent article on the Buffalo - BUT THE SOLUTION works in a native windows environment as well.
2. Build on the idea from number 1 above and INSTALL the LPDSVC (friendly name TCP/IP print services) on the machine with the printer LOCALLY attached through USB. You will also have to open up some firewall ports on the machine you are using as a print server if you have one running... I used a program exception (C:\WINDOWS\system32\tcpsvcs.exe) but you could lock this down to 1 TCP port if you wish - I think TCP 515 but you'd better check on this one...) Share the printer as normal. Next install the "Print Services for Unix" CLIENT on the machines you want to connect to the printer remotely from. When you connect to the printer share from the clients, select a LOCAL port, create a NEW PORT, select LPR, use the hostname or the IP of your machine acting as a print server and the NAME OF THE SHARE as the queue. (I don't like to have spaces in my share names, so I used HPLaserJet when I set up the share and description.) You will HAVE TO INSTALL THE RIGHT Printer driver locally on each client. This might be easiest just plugging in the printer with a USB cable since the HP printer driver is an installer as well and wants it to be connected locally unless you can extract the driver...)
Sorry I can't give more details than this. If you don't get the jist of what I am saying above. Don't try it. Give up and call the plumber.
Feb 09, 2010 | HP Hewlett Packard LaserJet 1022 Printer
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Communication between PrintServer DP-301U and HP LaserJet 1020
Trying turning your printer off and then back on. It happens sometimes that the print server looses the printer.
Alex
www.CAS411.com
Feb 13, 2009 | D-Link Air Plus DP-G310 (dpg-310) Print...
Can't find HP Photosmart 7150 driver during setup
check here.
Answer number 7 helped me when i had the same issues with the samsung ML-2010.
I installed the printer localy and then followed the sugestions at this link.
changed the server to a static ip
activated the required windows uttilities
changed the printer settings
http://www.fixya.com/support/t299506-issues_printing_dpr_1260
hope this helps.
Jan 13, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Lj2600n no output
i need HP colour laserjet 2600n software supporting to windows vista
May 07, 2008 | HP Color LaserJet 2600n Printer
Hi Prebhakar,
Have a great day!
Mar 06, 2008 | HP LaserJet 1020 Printer
Wireless laptop not printing
Indeed, you don't need the print server. Since your HP 6310 already has an integrated network port, you may setup and use it on your laptop the same way you do with your desktop. If you can browse the Internet wirelessly with your laptop, you should also be able to print.
Jan 20, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Can Not Print to HP LJ 1020
hook the print server directly to the computer and program it with a static IP address.
than create a new printer port in add printer. Than setup the printer and use the port you just created and it will work fine
Dec 14, 2007 | D-Link DP-300U (DHDP300U) Print Server
107 people viewed this question
jasbo
jasbo
