Question about HP LaserJet 3000n Printer
10.92.03 catridge not engaged - HP LaserJet 3000n Printer
  • rajakumar Nov 30, 2012
    Hi, Thank you so much. it worked. thanks
  • HP Master
  • 1,121 Answers
Pl check the video.. Observe yellow cartridge lever lock left & lever lock right, found any breakage? Replace it. If its left lever no issues,but its right you should take care of gear alignment..
Posted on Nov 29, 2012
Memory error msg shows after taken print of HP 1505n printer
Just observed that while loading the catridge, memory reading mechanism has to engage with memory, if this mechanism broken, not moving or jammed result memory error msg.. most of the cases observed broken.
Sep 15, 2011 | HP LaserJet P1505n Printer
No paper pickup problem in system printer (HPLaserjet 3050 models)
open back & side covers.. start diagnosys..
chech paper pickup unit trying to picking up the paper?..if yes.. clean/replace pickup roller..
No. check solonoid acting proprly,,
Paper passing little bit?..if yes..check paper sensor flag strucked?
check transfer roller gear properly engaging with the catride? 1.Replace catridge..2. Transfer roller check..
Good luck..
Sep 05, 2011 | HP LaserJet 3055 All-In-One Printer
I keep getting a error code 1203 what does that mean
Hello
It means your catridges overflow even from brand new catridges after several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge
use a klennex with a few drops of water to dampen and clean off those contact on the holder and your printer should work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned catridges a couple times then run clean catridges a couple times.
Print the test page to see how it looks .
Be sure not to leave any debris of klennex on those holder contact panel.
Jun 10, 2011 | Dell 926 All-In-One InkJet Printer
How to remove catridge
Catridge removal should be done along with the software support. Click on printers and faxes. Select your printer from there and click properties on it. Then Click on check ink levels in your printer. It will automatically show for the error if there is any empty catridge and you will get a screen with button named "Remove Catridge" On clicking it, the print head will come and stop near the opening from where you can open the print head and remove the catridge. Press the small tap like button on the side and while pressing it, the catridge will become loose , and pull it on the top. You can remove it by doing like this.
Aug 03, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I refilled the catridge it doesn't print
you have to clean and reset the cartridges. clean also your cartridge socket or holder.
Sep 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
HP 2320 problem
For Every New Catridge there is lock on catridge head u must remove to use the catridge...take out the catridge then remove the shipping seal or lock. refer instruction printed on catridge cover.
Jul 07, 2009 | Office Equipment & Supplies
My printer prints but no document is printed on the paper. Yes I have ink
1.remove your catridge wet your catridge head with headcleaner
2. clean your catridge head with tissue paper
3. do this two or three times
4. fix your catridge and take print
Jun 22, 2009 | Epson Stylus C60 InkJet Printer
Will not print black ink
Please check for the catridge..
I think either the catridge is empty on INK or catridge is having problem..
So, replacing with a new catridge will solve your problem..
Jun 12, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Cartridge error
In this case make sure that the catridges are inserted in the right slot...... The Colour Catridge should go in the right side and the black Catridges should go on the left side.... Make sure the catridge which u are using on this printer is the right one.......... It should not be a refilled cartridge if it is it will not work because Lexmark printers are not designed to work with Refilled catridges it may damage ur Printer......... If everything here is fine just take out both the catridges...... Take a Dry Paper Towel........ Clean the copper contacts on the printer as well as the Catridges....... Unplug the Power Supply from the Printer............ Replug it in and if still it says catridge is missing then may be a problem with the catridges.............. Hope it Works..... Good Luck........
Jan 17, 2009 | Lexmark X4270 All-In-One InkJet Printer
HP LaserJet 3000n Printer Logo
1,536 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
