Question about Mitsubishi WD-62525 62" Rear Projection HDTV
How do i tell if i need to replace light engine
I replaced bad capacitors, but now there is no picture. The green light is solid and the ballast made no noise when i pushed "Power"
  • Nathan Kinkade Nov 30, 2012
    1. past 2 weeks picture developed horizontal lines, and eventually looked like i was using rabbit ears to pick up a poor signal.
    Pulled out the chassis and found 2 spent capacitors. 1 on FMT board - (4) 1000uf 16v capacitors; replaced all. 1 on DM board - (2) 1000uf 25v capacitors; replaced all. Replaced chassis & plugged in TV. Timer light blinked for 60 seconds then went off. I pushed power button and timer light came on solid green, but no picture came on &.heard no sounds of light engine starting. I checked the voltage on J14 pin 6, and it registered fine I checked the voltage on J9 pin 4, no value was registered. Checked the voltage on J9 pins 1 & 2, and they registered fine. Not sure how to test if f9a09 is "open.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
If it comes on or not try the self check, press and hold both menu and input(source) for 5 seconds or longer and release both buttons, power light should blink a two digit error code like one blink, two blinks and pause and repeat.
Posted on Dec 22, 2012
5 Suggested Answers
  • 1153 Answers
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Posted on Sep 18, 2007
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi WS 48511 Blinking Green Power Light
Your model will have two picos mounted on the same board with the 7 capacitors they will look like resistors without the color bands they will be F9B01 and F9B00 check them for continuity.
Posted on Jul 28, 2008
toddg
  • 171 Answers
SOURCE: I fixed the blinking light, but still no picture
Here is the correct and official service manual on the unit. Check all of the diagnostics first, then go into the service menu and validate your settings.
http://www.techlore.com/download/22529/MitsubishiWS55859-WS65869-WS55909-WS65909-WS73909/
Posted on Oct 10, 2008
tvguy171
  • 106 Answers
SOURCE: WD-62525 green timer light keeps blinking after lamp replacement
Did you let the green light flash for about 70 seconds? It goes thru a self check when plugged in and takes a little time
Posted on Dec 29, 2008
New member here. I have a 62" DLP Mitsubishi model #WD6252. I've already replaced my lamp AND ballast and continue to have the solid red lamp status indicator. I've made sure the connection from th
Your color wheel is failing or has failed. the red light ONLY means the lamp cannot light or was forced to shut down. it means nothing about the lamp or ballast specifically.
If your color wheel isnt spinning up correctly or you have a stuck fan somewhere, the lamp will be shut down immediately upon startup.
Id check to see if the color wheel is stuck or if its getting stuck.
Dec 17, 2014 | Mitsubishi WD-62525 62" Rear Projection...
Lg flat screen shows solid green but no picture
Theres a great possibility
that your Power supply unit has problems
Although the fact that somehow turns on
tells us that you may find some bad capacitors and maybe replacing them might fix your problem
Jul 02, 2014 | LG Televison & Video
Have replaced power board and main board... still no picture..
you need to check and see if you have 24v from the power supply to the ballast if you do the problem is going to be the ballast ( inverter board ) bad capacitor
Feb 03, 2012 | Vizio L37 Television
I have a 2006 Thomson/RCA ModelM50WH72S TV that we have replaced the lamp, it still does not work and a technician has told us that we need a light engine for it. How can we locate one?
have the same tv,, power light blinks, book said it was bulb, bulb didnt fix it,took it to tv repair shop, they found a bad capacitor, replaced it with a higher heat range capacitor, this capacitor was on the power board for the lamp circuit, repair was $200, not bad since i paid $1500 for the tv, other than that issue, just replaced a couple of lamps
Dec 28, 2010 | Televison & Video
I put in a new light engine and a new bulb and no picture
U check the ballast?Replaced it might solved ur problems.
Apr 04, 2010 | Toshiba 62HM95 62" HDTV
I turn tv on...green light comes on but i get no picture or audio....then light indicator blinks red
Hello!
Lamp or ballast(if lamp has been replaced) is bad.
Explanation: green comes on: system works, waiting for light to shine into light engine: no light is coming out of lamp, system shuts down, then you see red! how to determine: pull the lamp out of the unit's compartment. Inspect lamp: bloated stem? shuttered? reflector is not shiny? Chuck it!
Lamp looks good or just been replaced: try ballast. Close lamp compartment without lamp itself. Make sure, door is shut, as well. Turn unit on and listen close to lamp compartment: good ballast will make a buzzing noise, then stop. You've got "red'! No buzzing: ballast quit. Needs major repair! Lamp must be good, for sure, to get to the last part of diagnostics. Conclusion: more, than 2000 hours of usage: replace lamp first!
Good luck,
Alex.
Jul 29, 2009 | Panasonic PT-D5600U DLP Projector
Optoma 719, can't get lamp and fan to turn on.
There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
Jan 31, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Replaced Lamp to no avail
That problem is caused by two bad 100Uf capacitors on the PWB . you will need the manual to be able to get the chassis out and I dentify the correct board. Go to this link get the reapair manual they will give you free tech support and when they email your manual ask then if you can have Sonny for your free support. He can fix that chassis in his sleep, and he will tell you the exact capacitors that need to be changed and you set will be as good as new. heres the link
http://servicemanuals.vstore.ca/
Apr 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 52Hmx94
How many times does it blink?
I replaced the ballast in my 62HM84 and it fixed it. The problem was TV would not turn On, Red light solid green light blinked 9 times then TV would try to restart. At first I thought it might of been the bulb, so I replaced it, same results. Next I replaced the ballast which is pretty easy, just take pictures before you remove the light engine so you can go back to the picture to verify the connections when reinstalling.
Dec 25, 2007 | Toshiba 52HM95 52" HDTV Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
