24k split unit works on heating trips earth on cooling???
    Problem Solver:
  • 16 Answers
Heat pump?
Posted on Nov 28, 2012
  • 18 Answers
SOURCE: only fans work on split
Does the compressor try to start and the shuts off or is the breaker slamming off as soon as it is turned on. If it takes a few seconds the comp could be locked up and trying to start, high amps and tripping breaker. Tripping breaker right now would indicate a shorted or grounded compressor. Really would need to be ohmed out with a meter to check for ground. Not good either way.
Posted on Apr 25, 2008
  • 33 Answers
SOURCE: carrier central airconditioning heat unit - breaker trips when cooling turned on
well mineswas a blowen compressor
Posted on Jul 19, 2008
  • 4 Answers
SOURCE: Split Unit not heating
There is no problem the unit is cooling on ly and is not a heat pump so it can't heat.
Posted on Jan 20, 2009
baccardo
  • 150 Answers
SOURCE: Split system heat pump works in heat mode but not cooling.
check the reversing valve relay
Posted on Apr 28, 2009
  • 11 Answers
SOURCE: split system outside unit won't come on for cooling, only heating
Check your filters, dog hair and lack of maintenance will definitely burden the cooling mode of the Mr Slim units.
Posted on Aug 24, 2009
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
Samsung 2.0TR split ac compressor getting heated up and tripped after running for 10 mins
High limit switch set to high, obstruction in the system, or your compressor may be wearing out.
Apr 12, 2013 | Heating & Cooling
I have a Fujitsu split air conditioner AOT24RNCL. The cooling, dry and fan settings are working. When I change to heating the unit trips the electric switch which is located at the power board. Any...
You have a short in the heating element. This could be something in the heating element that is conductive and needs to be removed or the element is touching the case or side of the unit. WARNING make sure power is off as the heating element is electricaly charged befor you try any repairs.
Aug 27, 2010 | Fujitsu Heating & Cooling
Not working
If the circuit breaker tripped,then the unit is trying to work and the remote is certainly telling the unit operate, otherwise it could never trip the breaker if it did not receive a signal from the remote. Your problem may be with the outside unit that te compressor is stalled (having a hard time starting ) and this will cause the breaker to trip. You need a porfessional to diagnose if it is the starter control, or relay, or capacitor, or bad compressor, or bad terminals.
Nov 28, 2009 | Coffee Makers & Espresso Machines
LG ac M483CS not cooling
It is possible that the contactor points have carbon or dust deposits causing an intermittent condition or bad connection. Why not try replacing the contactor?
Feb 02, 2009 | LG LSC183VMA Split System Air Conditioner
Dec 27, 2008 | LG LS-K1830CL Cool Mini Split Air...
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
