I have a kenmore 60 series heavy duty washer machine. Model series 13621. I know this thing is older then dirt but it was working great until the other day. Now it wont change cycles by itself and tge spin cycle wont work on cotton/sturdy but works on all other cycles. So right now were changing the cycles by hand but its obviously a pain. Any help would be greatly apprecited.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Do you see any other model numbers? I don't get any results for the one you posted.
Posted on Nov 28, 2012
  • 10 Answers
SOURCE: washer make a grinding noise in the spin cycle; barrel does not spin in spin cycle
check the transmission out or it can be a clutch problem
Posted on Dec 14, 2007
  • 185 Answers
SOURCE: kenmore heavy duty 70 series washer
put a new timer in it
Posted on Mar 24, 2008
IrishDruid
  • 2712 Answers
SOURCE: Spin cycle not working properly, clothes still wet!!!!
When the clothes are wet at the end of a cycle, check these:
Motor coupler Totest the motor coupler, re-start the washer in its spin cycle. Let themachine run for a minute, and then open the lid and notice whether thetub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • Ifit isn't spinning--and your machine was produced by Whirlpool®--you mayhave a broken coupler. Many Whirlpool-made washers use a small,relatively inexpensive device called a motor coupling. Thisplastic-and-rubber component is mounted to the shaft of the motor onone side, and to the transmission on the other. Over time, the couplerwears out and fails. When that happens, you need to replace itcompletely.
Spin cycle Ifthe washer doesn't reach its proper spin speed, the clothes may be toowet at the end of a cycle. Check to be sure the load is properlybalanced and run a spin cycle again. If the clothes are still wet, youmay have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®),or a worn motor pulley or tub bearing. Replace the applicablecomponent.
Alternatively, there could be clothes caughtbetween the inner and outer tubs. Read the "It spins but won't pump"section of the "It won't drain" section. Also, there could be otherthings that cause friction on the drive train. Seek the assistance of aqualified appliance repair technician.
Siphoning Ifthe water that pumps from the machine goes right back into the machineafter the spin cycle, it may be because your washer is siphoning thewater from a laundry tub with a slow drain, back into the washer. Tryto improve the draining of the laundry tub. (Is there something stuckin the drain?) Also, be sure the drain hose doesn't reach more thanabout 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inletvalves eventually fail. One problem that may develop with a water-inletvalve is that it can no longer completely shut off when the electricityis turned off to it. Then, the valve may leak and drip water into theclothes tub--you may notice that your washer has water in it when youhaven't used it for a few days. To fix this, replace the valve.
More information can be found here:
http://www.repairclinic.com/0088_11_1.asp#Level1_12
Posted on Oct 29, 2008
  • 68 Answers
SOURCE: washer stops at the spin cycle and won't drain
check your lidswitch. do you hear it clicking when you raise and lower the lid.
Posted on Dec 10, 2009
Testimonial: "Thank you so much!! I just saved the $ on going and buying a new machine. The lid switch was the problem..Merry Christmas!!"
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite spin cycle squeals
The clutch/transmission has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
We have an Kenmore 70 Series Heavy Duty Plus washing machine that is about 20 years old. The washer stops after the wash cycle and we have to manually move the dial one notch. The washer then completes the...
This is the deal, your washer is way to old to fix. The board is going bad and that is why it will not cycle properly. It would cost about $150.00 to fix and that does not even include labor. Consider craigslist as you can find some great deals from 40-60 for a newer one. Hope this helps.
JimmyC
Sep 26, 2009 | Kenmore Washing Machines
Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
Mar 30, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore 60 series will not drain
Well if this is a belt driven model then your solenoid coil is bad.
This model 's motor only revolves in one direction. To spin it has to shift gears. It does this by means of a solenoid mounted on the transmission called a wigwag. Note: if the lid switch is bad no power can go to the wigwag and shift it. If this is a direct drive model(no belt) then it has to be a bad lid switch.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Speed Control only works in Heavy Duty
sound like your motor is going out ,,,, the wiring at the motor may also be loose from out of balance loads
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
