New Canon copier ir 2520 error e0000716 code how to solve
  • 121 Answers
SOURCE: Canon IR 1600 Error message E000
You'll need to replace the fuser unit. Not exactly the cheapest part of the machine...
Unless, that it, you were taking things apart and happened to unplug something accidentally. If you take the cover off where the paper comes out, look at the connectors directly inside there under the black piece of paper that you'll see. If one of those are pulled out, it could cause the problem.
Otherwise you need to replace the fuser unit.
Erice
Posted on Nov 23, 2007
  • 62 Answers
SOURCE: error code oo7 in digital copier
The fixing film heater is serviceable and requires replacement.
Posted on Jun 19, 2008
  • 62 Answers
SOURCE: canon ir 2022 digital copier error code E001
how many blinks do you see in the led indicator? if it is 5 blinks then the problem is the printhead. if it is 2 blinks, then problem is in the feeding mechanism. if the problem is the later, then you might have to bring the unit to an authorize service center to have it checked.
Posted on Feb 18, 2009
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
SOURCE: how to solve to check printer cover in canon IR
how to solve to check printer cover in canon IR 1610 copier
Posted on Jul 05, 2009
Want to clear error code on ir 2520
Go through the following to clear the error: CLEAR > ENGIN > ERRCLR; and then turn OFF and then ON the power.
Best regards,
Marius
Nov 29, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
Please help me with my canon ir 2520 error code e000002. i am trying to solved it but it fails
hi. you need to clear that error from service mode first.
press aditional function
press 2
press 8
when #sssw appear on the screen search with arrows in the touch panel until CLEAR appear on the screen
press ok once
and search with arrows until ENGINE appear on the screen
press ok once
ERRCLR appears on screen . press ok one more time
turn off the machine from main switch for a few seconds
turn on again and make copy test .
if problem persist replace the fixing heater.
May 13, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
What dose code 0002 means in canon ir 2520
that error means there is over temperature detection . you need to clear that error from service mode
May 04, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
How can i fix the error code e000002 shown on my canon ir 2520 photocopier
Unplug the printer let it sit for one minute than power it back up. If the error doesn't clear repost.
Mar 05, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
How to solve e000002 error canon ir 2520 Printers?
Fixing unit temperature rise too high. In service mode go to :CLEAR<ENGINE<ERRCLR,turn on and off machine. Replace the main thermistor,replace the fixing unit
May 04, 2015 | Canon Office Equipment & Supplies
Conon ir 2520 erore code e000750
E000 errors are usually a bad fuser (also called fixing assembly by canon) You should buy FM4-3367-000 (for US/ Canada / Mexico 110V version.
Sep 11, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
Solution to errorE000003 0f ir 2520
Press the additionel function button & press 2&8 buttons at once and again press additionel function .select COPIER and FUNCTION and CLEAR and ERROR andpress OK button.
Feb 26, 2013 | Office Equipment & Supplies
CANON IR2520 SHOWING ERROR CODE 804
In my experience the 804 error code relates to the location/availability of a file. If you are trying to print/access a particular file check the path and make sure you have permission to access it.
Dec 28, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
89 people viewed this question
jasbo
jasbo
