Gateway model mx3228 laptop will not turn on power supply seems to be okay and when i try to hard boot all I get is a pink light by the battery could it be just a problem with the battery
    Novelist:
    Champion:
  • 233 Answers
4 possibilities.
1 The power supply is duff. How do you know it is actually working? Have you been able to test it on another system?
2 The charging circuits in the laptop have failed. Only a workshop can test this.
3 The Battery is dead. How do you know it is good if the system is not working?
4 There is a mechanical connection problem. Damaged lead/plug/socket etc. Examine and swap out to check.
Note that the system would not work if 1, 2 and 4 were the problem. (Since the system should still work of AC even without a battery).So a battery problem is the lowest probability.
The above assumes that your original diagnosis is correct, and there is a charging problem, and not something else.
Replacement Gateway MX3228 AC Adapter 65Watt 19V 3.42A
Posted on Nov 30, 2012
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Nov 28, 2012
Will not power up
If it's not the battery or the power supply cube, it may be a motherboard power component.
Also, if there are two memory modules try removing one and if the machine doesn't boot replace the first and remove the second.
May 25, 2014 | Computers & Internet
Every time I power on my laptop, the date and time is set to years ago. I've changed it to the correct date and time a lot, turn it off when I'm done, but it goes back once I turn it back on. I have a...
You need to change the internal clock battery. It's referred as a CMOS battery or a system battery. It will most likely be a silver button cell...either a 2016 or 2032. You will most likely find it by removing the main battery and one of the bottom access covers. After you change it, boot up to Windows and change the time and date. It should now retain the settings.
Nov 05, 2013 | Gateway Computers & Internet
No power the power supply appears to be functioning but laptop will not turn on once in awhile a pink light appears by the battery could it just be the battery. tried to use the power supply only with the...
Nov 28, 2012 | Gateway MX3228 Notebook
I have a Gateway MX 3228 laptop that does nothing. I can hear a slight sound from the area of the hard drive when I turn it on. The battery is supplying some power as the button light illuminates when the...
If you get no display at all, it could be failed memory.
Find and open the memory slot, remove and reinstall whatever memory module you find and retry it.
Many systems I've seen will do absolutely nothing if memory is faulty; they do not give any POST beeps, displays or start to read from the hard drive.
The hard drive will spin up when power is applied but will not start their own self-test or look for the boot sector if bad memory is in play.
Good luck-
Oct 24, 2009 | Gateway MX3228 Notebook
Gateway W340UA Black screen - does not boot
Yep it's probably the graphic card that's failed
Oct 16, 2009 | Gateway Computers & Internet
No power lights on gateway laptop model mx8711, power cord is working, does this model have a power fuse inside
Hi there.
The battery maybe faulty, remove the battery and try it on AC power only, there are no fuses that can be replaced inside the laptop.
If the laptop boots up on AC turn it back off and reinsert the battery and try to boot again, if it does not boot up then there is a problem with the battery and you will need a new one.
Good luck and thanks for using FixYa!!
May 12, 2009 | Computers & Internet
Recovery for a gateway mx3228 laptop
try not putting password in it when you do a recovery i have xp and i never use password i have the same error when i recover too but i just ignore it always recover with new instalation
Mar 26, 2009 | Gateway MX3228 Notebook
Cooling fan doesn't seem to be working
If you have a volt meter you can see if the computer is putting out power to the fan, also you should
be able to test the fan on an external power supply, if you dont know the fans voltage start off at 5vdc
, most fans are 5 to 12 volts. Hope this helps
Dec 22, 2008 | Gateway MX3228 Notebook
My gateway 700 xl doesnt boot
Unplug the power from you 700xl and from you monitor. Try removing the cmos battery and reinstalling it. Then, plug everything back in and try restarting. If it continues to give you the yellow light, you may need to replace the CMOS battery, especially if it is more than two years old.
Another thing to consider is if your power supply is underpowered for the number of external devices you have plugged into it (i.e., cd, dvd, external hard drives, printers, pci cards, etc). Gateway installed very low powered power supplies in their 700xl desktop computers. Usually only around 250 watts maximum.
If you are replacing the power supply with another 250 watt maximum power supply, and you have a lot of external devices plugged in, you may need at least a 350 watt power supply....if your CMOS battery is not the problem.
Nov 06, 2008 | Gateway 700 XL PC Desktop
Broken cd drive :'(
your Gateway has either a:
Toshiba (TSST) TS-L532U
or
Hitachi/HLDS GWA-4082N
You can check the device manager for the model of your laptop.
I have good luck at:
Tigerdirect or compusa.
You can call their sales office and give them your model and order it from cheaper than Gateway.
Dec 23, 2007 | Gateway MX3228 Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
