Question about HP Designjet T1100ps Printer
HP T1100 paper load incorrect - HP Designjet T1100ps Printer
  • HP Master
  • 1,121 Answers
Check:
1. Was its sensing the paper while loading the media?(roll or sheet)
2. Perform 'service test for sensors' to know how media sensor is working.. if its fails clean media sensor located left side of carriage assembly. If the media sensor becomes dirty due to ink, printer unable to detects the medias edge. Clean sensor gently.
Entering in service mode: Power off the printer using from the operational panel off button. Press & hold up arrow,ok button switch on the printer, wait few seconds to enter in service mode, once its enters in service mode, scroll to sensor test.
Posted on Nov 29, 2012
How to remove the error paper loaded incorrectly:remove paper on hp Designjet T790
Ensure you have the full range of support from HP.
I have Support assistant and HP printer assistant on my desktop. These were downloaded from the HP support website.
Oct 11, 2017 | HP Office Equipment & Supplies
Hp t1100 grinding noise after print
I suggest you run the diagnostics for the printer which allows you to isolate and run individual components. That way you can see which item is causing the noise. If it is coming from the left side, you might have a problem with the cutter.
Dec 17, 2016 | HP Designjet T1100 Photo Printer
Error 13.33.00 hp 4345
Paper jam inside top cover area. The paper didn't arrive at the paper-delivery sensor on time. This is usually due to worn out paper pick and feed rollers in the paper trays. Replace the rollers and you should be good. This error also occurs if your paper has a high moisture content, is the wrong kind of paper (too thick or too thin), or is loaded in the paper cassette incorrectly.
Mar 12, 2014 | HP LaserJet 4345mfp Printer
13.33 = Paper jam inside top cover area. The paper didn't arrive at the paper-delivery sensor on time. This is usually due to worn out paper pick and feed rollers in the paper trays. Replace the rollers and you should be good. This error also occurs if your paper has a high moisture content, is the wrong kind of paper (too thick or too thin), or is loaded in the paper cassette incorrectly.
Hp designjet t1100 blank hard drive installation
Unfortunately I had a similar issue with an HP A0 printer. The Hp 'Engineer' could not fix it. The hard drive had failed and there is a complete new hard drive with software loaded available but only through Hp.
Feb 27, 2014 | HP Designjet T1100ps Printer
Paper loaded incorrectly.remove paper in HP plotter T610.
T610 with "paper loaded incorrectly" error. Finally removed the paper roll completely and still had error. Opened top, but no signs of paper. I walked behind plotter and on the left , in the paper path ,I found the paper sensor using a flashlight. I got on my back and reached underneath to remove the plastic cover securing the paper sensor and the sensor itself. The sensor was dirty. Blew it off, reattached it and the error disappeared.
Jul 21, 2011 | HP Designjet T610 InkJet Printer
Error 47:01 for hp desighjet t1100 plotter
This error relates to the starwheel assembly and motor. Open the printer and make sure that there are no paper jams or anything blocking the star wheels (the little pointy wheels that guide the paper.
If nothing is visisble then service diagnostics are required. Not sure of your technical skill level, so post back if you are comfortable disassembling the unit, if not, contact HP to find a local Designjet technician.
May 20, 2011 | HP Designjet T1100ps Printer
08:11 error in hp designjet t1100
I had this code recently, and solved it cleaning the contacts pins in the formatter whit 2000 sand paper (could be pencil rubber) and reseating it.
Oct 01, 2010 | HP Designjet T1100ps Printer
Out of paper light flashes even after paper is loaded
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
Apr 25, 2009 | HP DeskJet 690c InkJet Printer
Hp photosmart c7280 won't work states calibration off
Solution
If the color or photo paper is loaded in the input tray when the printer aligns, the calibration might fail.
Follow these steps to resolve the issue.
Load unused plain white letter or A4 paper into the input tray.
Press the OK button on the control panel.
Cause
An incorrect type of paper is loaded in the input tray
May 30, 2008 | HP Office Equipment & Supplies
HP Designjet T1100ps Printer Logo
894 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
