Question about Linksys E3000 Wireless Router
Hi , I forgot my login password to linksys router , please provide me solution for reset the password.
  • Linksys Master
  • 32,281 Answers
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Nov 28, 2012
  • 196 Answers
SOURCE: Forgotten Router Password
Hold the reset button on the unit for 30 seconds or more and the router will be restored to factory defaults. This also means that your configuration will be set to factory defaults also, so if your router is configured for your ISP you may loose your connection until you set the unit up again. The default password for the router is admin in lower case letters.
Posted on Feb 16, 2006
ebarrick
  • 38 Answers
SOURCE: reset admin pw on Linksys RV042 VPN Router?
unplug router on the back is a reset hole use a pen or paperclip and press for 30 seconds this will set the unit back to factory settings
Default IP: 192.168.1.1
Username: Admin
Password: Admin
http://www.smallnetbuilder.com/content/view/30186/51/
Posted on Apr 16, 2009
bob_computer
  • 3153 Answers
SOURCE: trying to login in to my 192.168.1.1 linksys
This commonly happens with a modem router conflict
Try the following procedure and write down anything you change so that if you need to go back you know what was changed.
Connect ONLY the MODEM to a PC by wire and nothing else
Go to the start menu and select RUN
In the box type "cmd"
Now in the black screen that has come up type "ipconfig /all"
Take note of the numbers that are in 4 groups e.g. 192.168.1.1
Also take note of the name in front of those numbers !
Write down any numbers where it says DNS too as they may be useful (you only need the ones with numbers not the ones with letters)
Now do the same thing with your modem
If that too has the same IP as your router in "default gateway" then you need to fix that issue as that is probably a part of your problems.
The fix for router modem conflict is to set the router to use a different IP range.
To do this only have the router connected (by wire) and open an INTERNET explorer page (it will fail but that's OK)
In the address bar type the number you got for default gateway above for the router e.g. 192.168.1.1 and press ENTER
When it asks for the user name, give it the one you gave it when you set the router up or the default one from your manual
Also give it the password you gave it when you set it up or once again the default one from the manual.
You now need to look for a box that has the number you just used to get into the router.
It may just say IP address or Starting IP or something similar
That is the number you should change. I usually change the third block e.g. 192.168.2.1 as opposed to 192.168.1.1
You should also have some DNS numbers from the checks further up with the MODEM
You should find the DNS boxes and place those numbers in there. This will allow your computer quicker access to finding things on the Internet
Now look for the save settings button and do so.
Reconnect the modem and router.
The cable from the modem should go to the YELLOW socket on the router.
Power up the modem and WAIT until all the correct lights are on.
Then do the same with the router.
Now power up a PC and check that you can surf without problems
If not then the problem may lay elsewhere. Go back and re-check.
Also don't try to change router settings via a wireless connection. It can be fraught with problems and most router makers advise against it.
Posted on Sep 02, 2009
router-user
  • 550 Answers
SOURCE: forgot password for wireless router
Are you speaking about the password of the router or the password of the wireless network ?
If you don't know the password of the router , then you will need to reset the router and use the default password of the router.
Once you reset the router, you will need to reconfigure it.
If you are looking for the wireless password, you can find it on the set up page of the router.
You will need to open the set up page of the router.
Click here for step by step instructions
Posted on Jul 22, 2010
govinda123
  • 2260 Answers
SOURCE: Cant access my linksys router
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
Posted on Sep 23, 2010
I forgot my password how can i reset my linksys router
with a paperclip or pen depress the reset button recessed in the reset hole and hold it for 10 seconds while power is on.
The product will reset to the factory default login and password.
Jul 19, 2011 | Linksys Wireless-G WRT54G Router
Tip
Forgot my password.
If you ever forget your password to your router you can look up the default password online.
Most default passwords for linksys is: login=blank password=admin
Default passwords for belkin is: blank
Default passwords for netgear: login=admin password=password
Default passwords for d-link: login=admin password=1234 or password.
if none of the passwords work then you can reset the router to factory defaults by holding the reset button in with a paperclip for 30 seconds while powered on. This will erase any customized settings and apply the factory default settings. If the password doesn't work please check with your device manual.
on Feb 23, 2012 | Linksys Computers & Internet
When using set up system is asking for a password for linksys G
have you tried entering a blank username i.e. enter nothing? and use admin as the password
if that doesnt work look on the label on the bopttom of the router your isp might have configured it with there own username and password
if you find this info useful please vote
Feb 23, 2011 | Linksys Wireless-G WRT54G Router
My Linksys Router is secured with password but I forgot the password Is there any solution for my problem? Please help...Ty
Perform a Linksys reset
The easiest method of resetting your Linksys router's password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password "admin", in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to "admin" on some of the newer Linksys router models).
Feb 18, 2011 | Linksys WAG200G Router
If you have forgotten the router password you can reset it.
To do this, turn the router upside down and look for a small pinhole that says reset. Get a stapler and press and hold the reset button for 5 seconds.
The router will reset to factory defaults and you will be able to login again using the default username and password. For linksys routers is "admin" for both fields.
Feb 16, 2010 | Linksys Wireless-G WRT54G Router
How can i change my linksis wifi password
access the GUI if it still on the default settings otherwise press the reset button at the back
Sep 17, 2009 | Linksys Wireless-G WRT54G Router
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and reconfigure it again.
To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
LinkSys Default Password
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigure the LinkSys router.
Sep 08, 2009 | Linksys Wireless-G WRT54G Router
I forgot my password so can i cannot unlock my wireless router to play wii
hold the reset button down for 10 seconds this will put it back to factory defaults...then reset the password. the default password is admin with no login name...please rank
Jun 15, 2009 | Linksys Wireless-G WRT54G Router
Forgot password to add new computer to router
Hi!
Press the reset button for 10 seconds. It set the factory default
settings. The router will erase all information, the DSL settings too.
After that you can login in with the default password, via web
interface:
http://192.168.1.1
username: admin
password: admin
The default username and password is admin/admin.
I hope it hekos.
Jan 09, 2009 | Linksys Wireless-G WRT54G Router...
Linksys E3000 Wireless Router Logo
126 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
