Question about Car Audio & Video
I hav a alpine cda-w925ehi head unit an it just stopped an now says "interrupt"
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Hi I believe you have an Australia model? Alpine's use what's know as an interrupt wire to hook into vehicles/phones to interrupt the audio of the deck when their is a signal sent to it. On the Alpine harness you need to search for the Pink/black striped wire which is the audio interrupt wire. Make sure that wire is insulated and not grounding out against anything or hooked up incorrectly.
-Boz
Posted on Nov 28, 2012
Replace my citreon c4 head unit
what year is your car?newer cars 1999 and up the radio wiring harness goes thru the ecm (electronic control module).if that head unit is not supported it wont work correctly.in a bad case senario the head unit could damage the ecm.
Nov 03, 2007 | Alpine CDA-9847 CD Player
How do i get my Alpine CDA 9885 head unit out to fit a sub???
Remove the face, and trimring plastic.
There are slots on either side that you put the Alpine unlocking keys into (came with your headunit new) then slide the chassis out.
If you don't have keys - you can use a small allen wrench - or buy them at best buy etc.
A local alpine dealer will probably let you borrow his keys as a good business practice.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 23, 2009 | Alpine CDA-9885 CD Player
Alpine CDA-9856 interrupt message
theres a wire loose, bring your car to an audio tech and he'l sort it
Nov 06, 2009 | Alpine CDA-9883 CD Player
Cda 9886 installed and says interrupt
verify all your wires are correct. if anything, just plug the ignition power(red) constant power(yellow) and ground(negative) and turn it on and see if it still says interrupt. If it does try to see if it has a reset button and try that. If not, try connectiong the rca's one at a time and see if it gives you the same problem with the rca's, wich would indicate a short with the rca's. If it works ok after connecting the rca's, then go to your individual speaker wires and see if you have a short with one of your speakers. Hopefully it's not the head unit itself.
Nov 06, 2009 | Alpine CDA-9886 Car CD/ MP3 Player
Need pinout for Alpine CDA-7940 head unit
facing the back of the 7940 the top left corner is pin 16 the top right corner is pin 9. The bottom left is pin 8 and the bottom right is pin 1. Only a few of the 16 pins are used due to this unit only having pre-outs, no internal amplifier on this unit. Pin 1 red (ignition), Pin 2 pink/black (interrupt), Pin 3 orange (Illumination), Pin 8 black (ground), Pin 9 blue (power antenna), Pin 10 blue/white (remote turn on), Pin 16 yellow (battery).
Feb 21, 2009 | Alpine CDA-7940
No sound from my 9855 alpine
There is an option in the unit itself to turn off the internal amplifier. If you push the 'menu' button, then go to the setup/settings menu, and then i believe it was under the 'general settings' tab. there's a option called INT IC or something. Make sure that is turned on.
Dec 12, 2008 | Alpine CDA-9855 CD Player
Alpine cda-w550e
It must be an older unit, because it is not on the Alpine website call Alpine and they will help get you a manual. 1-800-421-2284 Ext.8853
Leadispenser
Aug 26, 2008 | Alpine CDA-7998 CD Player
Alpine cda-w550e manual
I needed a manua for my alpine cda-7897 and went to alpine's website and just type in my unit number under there manual section and there it was in a nice little pdf. file. hopes this helps.
Car Audio & Video Logo
333 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
