Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
Hitachi 50 inch plasma tv gets bunch of green dots after it warms up
    Top Expert:
  • Hitachi Master
  • 73,635 Answers
Sustain drivers can make this kind of fault. Panel too tshould suspected. Check the site linked below and see the illustraations there. There are illustrations of faulty plasma display panels, which can't be included by this window. Check it and see which type of fault to your TV resemble with. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 28, 2012
Drummernick
  • 440 Answers
SOURCE: Hitachi 50" plasma no picture
well they give usaly 1 yr parts labor i would get it in asap to be fixed bad power thx nick
Posted on Feb 07, 2008
eagle338
  • 4889 Answers
SOURCE: p50h401 50 inch hitachi plasma tv
Its difficult to guess what the problem is with the given info. How ever I think its probably the ceramic fuses and burning smell is due to burnt resistors, caps or something else. I would suggest that you get the back panel off take a snapshot(High resolution) of the suspected area of damage so that i can assist you further. By the way you can upload the pic in an imagehosting site like imageshack.us
Posted on Sep 28, 2008
  • 108 Answers
SOURCE: Hitachi Plasma EDTV has green dots flickering all over screen
that is called diffusion. that can be adjusted out in most cases by adjusting the y sustain pcb but can also be the main pcb, the logic pcb and panel itself but not likely.
Posted on Jan 11, 2009
  • 50 Answers
SOURCE: Hitachi Plasma - green dots
Please read all the info before you start and if you have any question please feel free to message me at pleasefixitdave@yahoo.com or just give me a call @ Cell # 1-503-432-9904 Ask for Dave! What you'll need to do is remove the stand and the back cover. Once you have both the back cover and stand off you'll need to put the stand back on the TV so that you will be able to set the TV up right! Then you will need to locate the Y sustain board. The Y sustain board is the board that is to the left side of the TV if you are looking at the TV from the back side. The Y sustain will have a large heat sink on it 3 1/4 inch's wide and 6 inch's long. There is a small heat sink 3/4's of an inch wide and 3 1/2 inch's long just above the large heat sink. A little to the right of the larger heat sink. The little heat sink also has two large capacitors just to the left of it. Once you have located the small heat sink you will want to look just to the right of it and you'll see two Blue with Yellow centers adjusters.b5e4dcb.jpg You do not want to touch any of the adjusters other then the two that has the location #'s VR1 & VR2 next to them. Please make sure you have located the right adjusters by making sure that the location # next to them is VR1 & VR2. Start with adjuster VR1. Before you make any ajustments take a felt tip pen and make a stright thin line over the top of the Blue with yellow center adjusters. This will help you put the adjuster back in to the factory setting position if you need to start over and it will also give you an ideal as to how much you have adjusted the adjuster. At this point you should have the TV with the back cover off and the TV in the up right position with the stand on the TV. Now you will need to find a friend to watch the screen while you make the adjustment to Location # VR1 & VR2. plug in the TV and turn it on. The TV should be cold, another words if you have had the TV on at all let the TV cool down for about an hour or so before you do the adjustment. Start the adjustment by turning VR1 counter clock wise slowly untill the specs on you screen go way. If the specs on you screen get worse then put the adjuster back in the factory set position and turn the adjuster VR1 clock wise until the specs go away or lessen. In some cases you will not be able to get ride of all the specs but you will be able to lessen the amount of Green or Red specs on the screen. If adjusting VR1 dose not completely clear all the Red or Green pixels from your screen make the same adjustments to VR2! WARNING: Plasma televisions use high voltages to display images on the screen. Be sure to unplug your unit, and then press the power button on the front panel to discharge the capacitors in the unit before beginning to open up the case. Always observe the necessary precautions when working around electrical equipment and never touch anything with your bare hands that may be carrying a stray voltage. By following these instructions you agree to assume all risks involved with the repair of your unit, and agree to hold me harmless of any damages that may result to either you or your television from the following of the instructions on this page. Please feel to message me or give me a call if you have any question regarding the repair of your TV! Thank you! 03.gif Dave All TV Repair Cell # 1-503-432-9904 pleasefixitdave@yahoo.com
Posted on Feb 23, 2009
SOURCE: My 50 inch Hitachi plasma 1080 tv has a blinking
my hatachi hd/1080 tv has a solid blue light on and it wont turn on i push the reset button on the bottom right and it still wont turn on
Posted on Feb 08, 2011
Having a problem with plasma tv hitachi
It will depend on the age of the set but the lines are either a bad board or a bad display unit .
Dec 12, 2012 | Hitachi P50H401 50 in. Plasma HDTV
When the Samsung 50" plasma TV is turned on and during the whole time the TV is running there is one small green dot (or light) in around the middle of the screen. It continues and does not go away as the...
Still under warrenty?Yes,call the tv manufacture,get this tv replaced quickly.The Plasma screen is developing a burn in dead pixels.This problems,can't not be repair.Except replaced the Plasma screen itself.The plasma screen panel are 90% of the tvs,not worth repairing,if it damages or broken.Will cost the same as a new tv,if the screen require replacing.Still under warrenty call it in right away to get the picture screen replaced under warrenty.
Oct 04, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
My 50 inch Hitachi plasma 1080 tv has a blinking blue light and screen is blank when powered on.
Mar 27, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi Plasma 50 inch H4011 series just went off and red light blinked 4 times. Won't come back on even after unplugging and waiting 30 seconds and plugging back in per Troubleshooting guide in owner's...
Power supply board is dead.Replaced the power supply board,Ur tv will get the power back.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for replacement.
Feb 21, 2010 | Hitachi P50H401 50 in. Plasma HDTV
TV turns on but has no picture or sound.
Take it in to an authorized Hitachi servicer. ther are too many things that need to be checked .The difference in cost of parts could be $200- $300. Not something you want to guess at.
Apr 24, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Jan 11, 2009 | Hitachi 55HDS69 55 in. Plasma Television
42EDT41 colored snow/pixels
I have the same green dots that are seen especially when the bacground picture is dark or black. Mine does not seem to be changing when it warms up, and I also get it on my digital cable as well as on any DVD's I play. Please help with any advise. I think it was always there, but I assumed that a dgital cable upgrade would fix it - I should have known better...
Thanks a bunch in advance...
Oct 22, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
