Question about Motorola Talkabout Distance DPS (10 Channels) 2-Way Radio
Motorola Talkabout Distance DPS Monitor Button Dead
Have not used these in two years brought out of storage today and function tested them. On one the monitor button was working and now it does not. Checked transmit and receive is fine but no Squelch...when monitor button is pushed. Tryed changing batteries to no avail. Any suggestions or a known reliable repair place?
Email : ammoguy@hotmail.com
Retired USAF Vet
  • ammoguy Jan 10, 2009
    Further info: Compared two units. The monitor button does not have a positive click feel when you push it. Possibly sticking. Can any one tell me how to dis-assemble this so I can free/inspect the button underneath?
  • ammoguy Jan 11, 2009
    Thank you. For the info. I was able to just now get a look through the empty battery compartment to look at the problem. The rubber button was dislocated next to the main white plastic button. It was wedged not allowing it to reseat. I carefully relocated the rubber back on top of white button and functioned it for 5 min with no further problems. Wonder why this happened...Never happened before. I did need to get it fixed due to th PL was enabled, and without it functioning it would not allow for changing of privacy channels.
  • Motorola Master
  • 1,654 Answers
To remove the button properly/safely, you will need a frame removal tool. This extracts the component board from the radio, and then you can get to the back side of the button assembly. This tool is available for around $5-$7 at most Motorola dealers.
Note: The monitor button is not frequently used, so if the PTT button is working properly, I would not be concerned with the monitor button. The purpose of the monitor button is for the user, when using the radio with the "interference code eliminator" turned on, to be able to check for radio traffic on the frequency before transmitting. Very seldom is anyone so polite as to check.
If you are needing to have the unit repaired, here is a link to some info: http://www.eradiostore.com/cart/images/repair_request.pdf
Posted on Jan 11, 2009
  • eradiostore
    eradiostore Jan 12, 2009
    Glad you were able to fix the problem. You are correct. To set the PL you would need this button to function. Best regards.
    Problem Solver:
  • 9 Answers
Oh ******* *******!
Posted on Feb 12, 2009
Need battery tray for motorola sport 10 x
Unfortunately, the battery trays for this Sport 10X radio, Sport 7X and the later model TalkAbout Distance DPS are no longer available. In our repair facility we often get requests for these battery trays, and as a dealer we have not been able to get them for several years. Your best option is finding a used parts radio somewhere like ebay. In some instances the original tray can be fixed if you still have it.
Best regards.
Feb 20, 2014 | Motorola Talkabout Distance DPS (10...
Tip
TalkAbout Distance Charging & Battery Options
The Motorola TalkAbout Distance and Distance DPS radios have a rechargeable NiCd battery pack (HNN9056 and/or HNN9044). Use of this battery pack is the best method for powering the radio. This type of battery pack has a 18-24 month life expectancy. You can determine the age of your battery from the date code on the back of the battery above the stop sign. The first digit is the year and the next two are the week of the year. Ex: 919 would read 2009 the 19th week.
The DPS model came with both a NiCd battery tray and an Alkaline battery tray. While the NiCd battery pack is the best option for fully powering your radio, along with being the most economical option, in a pinch or when charging is not available the 6 Alkaline batteries will power the radio for up to 18 hours. Note: Replacement battery trays are no longer available, it is advisable to keep both trays. If one fails, you will have the other as a backup.
The TalkAbout Distance is a repairable radio. The consumer replaceable parts are the NiCd battery pack, belt clip, antenna and charger.
on May 06, 2009 | Motorola Talkabout Distance DPS (10...
Motorola Talk About distance dps battery tray bad. Where might i locate another b tray. THANKS! MODEL P24SRY03G2AA
Unfortunately replacement battery trays (both alkaline and rechargeable NiCd type) for the TalkABout Distance and Distance DPS have not been available for several years. We have had some success in repairing existing trays, here in the repair shop, if the damage is not too severe. As for a source, you might watch ebay for another unit for parts, or replacing your existing radio. Be certain to quiz the seller on the condition of the battery tray.
Best regards.
Nov 05, 2010 | Motorola Talkabout Distance (10 Channels)...
Need battery tray for motorola dps radio
[This is not a solution, but a commentary on the need for a tray. Please do not rate this post, as it is meant for informational purposes only.]
This is more common that you might think. The battery trays (both 6-AA Alkaline and NiCd rechargeable-style) have not been available for a few years from Motorola. From a nationwide repair center perspective, we find some damaged trays can be repaired, and some owners find a "parts radio" from sources such as ebay.
For those of you reading this posting which have the TalkAbout Distance or Distance DPS, let this please be a reminder to take care of your trays. Once the tray is gone, the radio is not functional, nor can it be repaired.
Best wishes on your search and please post back if you do find one.
Best regards.
Aug 13, 2010 | Motorola Talkabout Distance DPS (10...
How to charge battery in Motorola Talkabout Distance DPS
You can obtain a wall adapter style charger for your radio at your local Motorola dealer, or online at http://www.eradiostore.com/cart/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&epcode=Y&q=htn8232
Sidenote: The rechargeable battery is good for about 2 to 3 years. You can tell the age of your battery by looking at the date code on the back of the battery above the stop sign. The first number is the year, the next two numbers are the week of the year. 915 would be 2009 the 15th week. (Or if very old it could be 1999 the 15th week.) A good battery, when charged will go an 8-10 hour day.
Keep both of your charge trays, replacements for these are no longer available.
Apr 12, 2009 | Motorola Talkabout Distance DPS (10...
New pair of new motorola talkabout distance dps radios.
can you check the PL or DPL setting on the radio that is all stadic when you receive a call?
The radio is going into monitor mode after a call is received. This is most often a PL or DPL issue.
Dec 08, 2008 | Motorola Talkabout Distance DPS (10...
Motorla talkabout dps
The best solution we offer our customers is to try buying another radio "used" on ebay. The tray has not been available for several years. If you have a damaged tray, we have had success at repairing them. If the tray is lost or missing, we which you well on your search.
Aug 14, 2008 | Motorola Talkabout Distance DPS (10...
MOTOROLA TALKABOUT T5400
First check your batteries. Try the battery pack from a known good radio. If you do not have a battery problem, your issue is probably non-reversible. Sorry. This style radio is non-repairable. The repairable Talkabout units include the Distance, Distance DPS, the TA-7400 and TA-7200.
Jul 11, 2008 | Motorola Talkabout T5400 (14 Channels)...
Motorola Talkabout Distance DPS (10 Channels) 2-Way Radio Logo
295 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
