LG REMOTE CONTROL MKJ32022813 - will not operate
Will not respond to any button pushed including power. is there an on/off or reset that has somehow been activated
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
Check its infrared emission with fresh batteries loaded. Check the battery contacts at its battery compartment for any rust or dust accumulated restricting the flow of current from the battery. Clean that contacts well by any means. If all of these are correct, you remote control need cleaning. Visit the following linked site to know more about how to check and repair a remote cotnrol. One among the posts have all the details about this. Pull it up. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 28, 2012
SOURCE: the TV does not respond to the remote control nor the buttons in the front panel
i am haveng the same problem p58h10nja
Posted on Aug 03, 2008
SOURCE: Panasonic TH-50PX60U no buttons working
The software in the cpu of this set is damaged you must reload it to fix the problem..
Posted on Dec 18, 2008
jerryg50
  • 1689 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
  • 4 Answers
SOURCE: LG TV no longer responds to the remote control..
I have had the exact same problem with my 47LG70 after 13 months of use. I changed my remote control sensor but it did not help. Before you do that, try something simple which seems irrelevant. On this website, others have posted success by plugging in any standing set of headphones into the remote control or headphone jack on the rear TV panel. This solved my problem. So I proceeded to thoroughly dust all of the input/output component jacks on the rear and side of the TV with an air-can. This solved my problem and I do not need to have the headphones plugged in. So try these two things before changing the sensor.
Posted on Jan 23, 2010
budmrtn
  • 11361 Answers
SOURCE: Sony Bravia KDL-V40XBR1, no picture
You either have failed 24vdc power supply section or failed backlight inverter board, check for 24vdc first, look for caps with leaking/bulging top.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Sony+BRAVIA+KDL+-V40XBR1+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 13, 2010
What can cause an LG 47LN5700-UH TV not to turn on or respond to the panel buttons or remote control?
TV in totally unresponsive in many if not all areas. Only thing they all have in common is the set's power supply. They are big culprits.
Check the board for burnt rsisitors, diodes, bulging capacitors.
Aug 21, 2015 | LG Televison & Video
Tv on standby wont turn on either by remote or buttons on tv
Its not the remote but the set itself, Have it looked at and get an estimate for repair
Dec 05, 2012 | LG MKJ32022813 Remote Control
REMOTE WILL NOT TURN ON
Did you install new batteries correctly?
Nov 28, 2012 | LG MKJ32022813 Remote Control
Sony DVP-S7000 DVD player does not respond to front panel buttons or the remote control
The only possible solution and it is a long shot, unplug unit from wall receptical, now press and hold power for 60 seconds, this will drain any residual voltage and reset the microprocessor in hopes it will work. If this fails I recommend the sony technician.
Jul 17, 2012 | Sony DVP-S7000 DVD Player
TV has frozen will not respond to remote control (yellow button on right hand side of tv flashes when remote button are pushed) can not operate television manually as will not respond either
You can try to leave in unplugged from power for 10 mins, then try again. But in all likelihood something as cold soldered on the inside you can either try to get warranty (if applicable) or get a new one.
Mar 21, 2011 | LG Televison & Video
I received an LG 32LX4DC Flat Panel Television from a hotel. It came with a control box LG LST-4100A. I saw on fixya.com the method to access the installer menu. However, I could not get the hidden menu...
Just an FYI if anyone is having this same problem a factory reset will solve the issue.Follow the above directions... "1. Press MENU repeatedly till it seems to not respond. 2. Enter 2-6-6-3 on the remote then Enter 3. At the top, it says ENTER PASSWORD 0000 4. Enter 9-8-7-6 then Enter 5. Installer Menu comes up scroll through the options until you see "factory reset" change the value from a 0 to a 1 with the arrow keys and then power the TV off. When you turn it back on it should be reset to factory defaults.
Mar 20, 2011 | LG 32LX4DC 32 in. LCD Television
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
Do i need a remote to operate tv
once you have front panel in the tv and this one shows power channel +- volumen +- menu then your tv has to work with those ones and the remote is a second option to do the same. With this i mean you tv has to respond and at least show menu when you push that button " if no signal (cable DVD VCR) plug in"
Then if the tv is dead you should try to repair or sent it to repair. and then get the remote control and it can be universal too.
May 01, 2009 | Protron PLTV3250 32 in. LCD Television
Remote is working- but unit won't turn on
check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Check for reset or rst button in your remote control and push it to reset and test it in your unit. If wont work means either the receiver board or mean board is defective.You need a qualified tech. for this problem. For the mean time you can use manual button to operate the unit.
Jan 30, 2009 | LG LSC121PMA Split System Air Conditioner
LG HDD DVD Recorder remote control not working with LG TV
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
May 29, 2008 | LG DE9523P DVD Player
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
