Question about LG 42LH40 LCD TV
LG 47LD650 turns off and on by itself - LG 42LH40 LCD TV
I have a LG TV 47LD650 that has picture but no sound out of tv speakers. If I connect an optical cable into the output and use a sound bar, will it still produce sound?
You have to go to setting and change the audio output to TV speakers for the TV speakers to work,, but, if you use a sound bar with optical connection...you have to set it also .. mine works the same way,,
Jun 19, 2017 | LG Televison & Video
Suddenly turned off. Why won't it turn on again?
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears to turn itself off. These cases are listed in the following table by category.
HELP! My LG LCD TV suddenly turn off by itself and ... - AVS Forum ...
www.avsforum.com/.../1084538-help-my-lg-lcd-tv-suddenly-turn-off-its...
Nov 13, 2008 - 30 posts - ‎22 authors
This morning, I turned it on, its suddenly turn off and on by itself repeatly. I can't even control the tv using the remote again. Then I try the trick ... Samsung TV turns on and off repeatedly before staying ...
Jul 1, 2014
My HDTV Shuts itself OFF then it Turns On by itself ...
Sep 12, 2008
More results from www.avsforum.com
Samsung Smart TV turning off - Forums - CNET
Dec 29, 2015 | Televison & Video
My LED LG TV 42" turns on/off by itself. Channels do not change.
Sorry to tell ya but your power supply panel or chip is going out! Mine done the same stuff! Freakin flat screens dont last as long as the older t.v's
Nov 01, 2012 | LG Televison & Video
Power button flashin, powering up but no picture or sound
means the inverter board is dead. call LG service for replacement.
Sep 12, 2011 | LG 47LD650 47 in. LCD HDTV
My 47" HD 1080p will
This kind of symptoms is cause by faulty(leaky/dried) electrolytic capacitor in the power supply section. In the first stage of symptoms warm up will make itself stable and the unit will power up after a few attempt of plugging and unplugging from the outlet but it will get worst, time will come that the unit will not power up at all.
Leaky capacitor has a physical indication of fault like bulged/dome at the top and can be easily identify like in the sample picture below.
Leaky capacitor with dome at the top.
Dried capacitor has no physical indication of fault, you must have a capacitor checker to determine its condition, if not available you should replace all electrolytic capacitor in the power supply section. It will not cost you much because it is one of the cheapest parts on that board.
Click this LINK for more information regarding electrolytic capacitor.
Jul 30, 2011 | LG 47LD650 47 in. LCD HDTV
We have lost our digital abc and channel 10 1hd and 11, how can I get them back, is there a default?
The problem is your digital antenna they lose signals all the time. Try moving the antenna around, if that don't work go to radio shack and buy a signal booster.If you programmed your LCD while the signal was low it wouldn't have picked the channel up also.
Jan 28, 2011 | LG 47LD650 47 in. LCD HDTV
My TV won't turn on right away. It looks like it is going to come on, but the light switches to red then blinks red-green for a while. I can usually get it to come on but it takes a long time. We tried...
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this hellpout, Good luck......
Aug 04, 2010 | LG 47LD650 47 in. LCD HDTV
LG Shine turns itself off constantly
This is a device issue. You will need to contact your service provider for replacement options!
Mar 09, 2010 | LG Shine KE970 Cellular Phone
My lg neon turns itself off after texting
your phone has a virus and needs a hard reset available at the lg store where you bought it or any other store than handles lg.
Feb 24, 2010 | Cell Phones
LG 8100
Hi Imatt015,
This is called "restarting". The mobile when restarting turns off and turns back on just as it happens to our PC when we restart it. This may happen at times when the OS of the mobile has encountered a problem or if there is some updates to any software in the mobile.
Thanks.
Nov 03, 2008 | LG VX8100 Cellular Phone
LG 42LH40 LCD TV Logo
80 people viewed this question
Computer Repairing
Computer Repairing
