Our Brivis StarPro Max won't change from heating to cooling when I press the Mode button and the heart icon is constantly flashing.
Brivis StarPro Max
SOURCE: Honeywell VisionPro USER SETUP CODES OR INSTALLER CODE FOR TEMP RESTRICTION
You need to get into the installer setup. Download the installer manual from Honeywell or an on-line vendor and it has the installer codes to alter the maximum heat setting. Press the system button and then buttons 2 & 4 at the same time for 5 sec to enter the installer mode. I believe the code is 0600 and then you enter the max temp for heat setting. Press done and your done!. Try this link for the installers manual http://www.alpinehomeair.com/related/Honeywell_VisionPro_8000_%20Install_%20Instructions.pdf
Posted on Feb 12, 2008
  • 57 Answers
SOURCE: fan runs constantly on cool mode
Simple Question: Did you check to see if the fan switch on the
t-stat is in ON or AUTO? If ON the fan runs nonstop. If in auto the fan cycles with the outdoor unit.
next does the fan shut off if you turn the t-stat to off?
A stuck relay should keep the fan running all the time.
Sometimes if the relay is stuck you can whack the side of the Air Handler and the connection will break.
Sometimes instead of a relay there is a stack switch.
It's a little black stack of 3 disks this is a bi-metal switch.
they do get stuck more often than relays.
The fan relay may be on a electronic board. I don't know for sure without seeing your unit.
Good Luck Phil
Posted on May 20, 2008
ripleymojica
  • 643 Answers
SOURCE: my sony cyber super steadyshot model DSC-T70 flash does not work. Nosmile icon appears on the touch panel when shutter buton is pressed.
go into setup menu and turn on the smile detection. go to photo and press the right arrow should have a pict of flash icon . press until the flash says auto.
Posted on Jun 03, 2009
relaga58
  • 158 Answers
SOURCE: Conia CA1800 wont heat
there should be a mode button, press it until you see the sun sign
Posted on Jul 09, 2009
SOURCE: Uniden uh064sx-2 2-Way RX Stuck On
Didyou have any luck resolving this issue? We currently have exactly the same problem
Posted on Apr 15, 2010
Brivis me20e fan speed adjustable?
all u do is turn the wall controller to the off position. then press the clock button then hold buttons 2 and 4 down at the same time. let it load for 10 sec then turn the knob all the way untill it sais 1500 that is max fan speed then push the off on button to exit it. dont adjust any other values in here tho just the first one
Apr 20, 2014 | Heating & Cooling
Beeping won't stop in Sportline 370 pedometer
Use MODE button to scroll to ALM (alarm) then press INFO button to change from ON to OFF. If that doesn't work use MODE button to scroll to PACE, then press INFO button to toggle from ON to OFF.
Feb 27, 2012 | Sportline 370 Traq Motion Sensor Pedometer...
The iron will not steam and the standby button is constantly flashing
Always switch off the unit and allow to cool before cleaning or storing. .... If your steam generator does not work, check the following points: ... working temperature, the LOW STEAM ICON will flash whilst the heating cycle takes place ... steam. 9 When ironing is complete, press the POWER. STANDBY button.
Jul 27, 2011 | Morphy Richards Jet Stream 42271 Iron
The automatic flash is constantly 'off''. Have
Well, try to go through your menus to understand what the problem is. Also, check to see what mode you are one. It is possible that that mode is preventing auto-flash. Good Luck!
May 09, 2011 | FUJIFILM Finepix S1500fd Digital Camera
I have a westclox atomic alarm clock - model #700...
I have the same alarm clock the damn thing gives me a heart attack when I wake up. All in all I have the instructions for your clock.
Simple on the back of the device there are five buttons hold down the one that is labeled mode/set then the display will flash use the oC|oF/Up key or Wave/Down key to change the keys and the mode/set the to move between each field.
If you press (not hold) the Mode/Set key you can change the alarm, change the numbers using the degreeC|DegreeF/Up or Wave/Down key to change numbers accordingly.
To turn the alram and snooze function on or off press the Alarm/on\off key.
What I just said may sound complicated but of you press the buttons as I told you then you should have no problems what so ever.
May 17, 2010 | Computers & Internet
Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Sep 22, 2009 | Heating & Cooling
Akai airconditioner AC-KS24HRC Changed batterirs in remote can not get heat mode icon on remote therefore no heating.Still under warranty but can not find Akai repairer Newcastle N.S.W. Australia...
I had the same problem. Check the remote control section of the manual. When you change batteries the screen flashes the hot and cold icons alternating. press a utton when the hot one is on and it will activate the heat+cool mode.
Jul 15, 2009 | Heating & Cooling
Long range mode
For the Cobra PR4700WX:
The user's manual is available here
To turn on/off the long range mode - (If you are referring to low & high power); Press and hold the Hi•Low/Enter button for two seconds.
Alternately, if you are referring to the Light/Max Range (receive sensitivity), 3 options:
1. To briefly turn off auto squelch - Press the Light/Max Range button for less than five seconds. If you hear two beeps, you have turned the maximum range extender on.
2. To turn maximum range extender on - Press and hold the Light/Max Range button for at least five seconds until you hear
two beeps which indicates the maximum range extender is on.
3. To turn maximum range extender off - Press and release the Light/Max Range button or change channels.
Probable reason that "fishing was all right but for hunting there is to much static" is becasue these radios operate on line of sight principle. Anything that obstructs the linear view would reduce signal strength/range. There is not that much obstruction when fishing compared to that when hunting in the woods or rough uneven terrain.
Please note that when using Channels 1 through 7 and 15 through 22 on high power, the Hi icon will be visible on the display. When using those channels on low power and on Channels 8 through 14, the Low icon will be visible on the display.
For the Cobra PR3500DX:
The user's manual is available here.
The transmission message icon off when not in use - this icon will only display if the radio is receiving something or if your are pressing the PTT button.
The other three the transmission signal is on at all times - indicates that either you are transmitting (unlikely) or the radio is in constant receive mode (most likely). I would venture a guess that the Auto Squelch is switched "OFF" or Maximum Range is switched "ON"
Both the 4700 & 3500 has Power Saver and it is a built-in feature. Your radios have this unique circuit designed that extend battery life. If there are no transmissions for 10 seconds, the radio will automatically switch to Battery Save mode and the Power Saver icon will flash in the display. This will not affect the radio’s ability to receive incoming transmissions.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | Cobra 22 CHANNEL 2-WAY RADIOS
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
