Question about RCA P52928 52" Rear Projection Television
Remote sensor board rca tv model p52928
I need a replacement remote sensor board or ive seen it called key controller board basically its the circuit board that contains the power button, channel, volume & menu controls spilled soda on it and it died over a week later...sometimes it works but i need to cange it and cant find any solutions or websites that carry it
    Top Expert:
  • RCA Master
  • 14,553 Answers
Disconnect the board if you have a real working remote, set will work via the remote without that board---remote sensor is behind screen and above the board.
Posted on Dec 22, 2012
techman
  • 3130 Answers
SOURCE: Non Responsive 35" RCA
You are going to have to check all of the small tact switches behind the push buttons in the front of the TV set. In the past, someone may have cleaned the picture tube and the liquid dripped down onto the switches and corroded them, or one is stuck closed or the remote sensor is bad. The best way to test this would be to replace the entire switch panel in the front of the TV set. Good Luck
Posted on Aug 19, 2007
SOURCE: TV keeps changing channels
Out of 30 years in the repair field, I have seen this problem maybe 4 times. Once was a stuck button on the keypad of the tv. The other time was a second remote control with a book sitting on it and it would turn the tv on and off when someone would move something on the coffee table, another time was a bad solder connections on the microprocessor on the keypad circuit board and the last time was from a humorous neighbor in an apartment complex who thought he was funny who had an all in one remote control programmed for his neighbor's tv set.
Posted on Oct 03, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA HD52W66 convergence problem
you will need to replace FL231, DL231 and CL230 all located on the deflection board . You can get replacements at the following link with free instructions on how to do the repair. the parts are all listed under the RCA parts category. Heres the link http://servicemanuals.vstore.ca/
Posted on Jan 16, 2009
  • 147 Answers
SOURCE: Menus pops up
The menu button on the TV itself is bad and must be replaced ( or removed ). Alternatively the whole front button assembly can be disconnected. Just follow the wire back to the main chassis and unplug it.
Posted on Apr 09, 2009
Slinteriors
  • 8617 Answers
SOURCE: I have a RCA R56wh78 projection power button flashing green.
Thats the classisc sign that the CP150, CP114 and CP120 capacitors need replacement. You can get the repair kit called CP150, CP120 and CP114 at www.tvrepairworld.com which contains the capacitors and the CD with step by step instructions on how to do the repair.
Posted on Dec 04, 2009
Testimonial: "Thank you. I will try this. I just dont understand why it worked with all of the button pushing on the front of the tv. Is this going to be a hard job"
Toshiba 32a14 does not respond to remote control
Hello
There is a infrared light sensor inside the TV which detects the infrared rays emitted from the remote control, when we press each button on the remote control. If this sensor has got damaged, the set won't respond to any remote control handset. The sensor can be located just behind the infrared sensor window at the front panel of the TV. To access it, you have to open the TV. It is a three terminal component, will be soldered diretily to front panel circuit board, of with the main baord itslef. Will look somewhat brownish black in colour. There are so many types can be seen . Just look what type if fitted with your TV.
2_4_2012_6_58_45_am.jpg2_4_2012_6_59_07_am.jpg2_4_2012_6_59_34_am.jpgSee some models infrared sensors. Check out which type your TV has.2_4_2012_7_00_45_am.jpg
Feb 04, 2012 | RCA Televison & Video
My R56WH78 tv has lost convergence overnite,I can not access any convergence menu with the remote control,What should I try next.
This RCA tv model have a dead convergence fuse at FL231 at the right side of a FBT- a big black plastic block with a wire hook to a board.Must resolders the FBT-(Flyback tranformer too).U have all the tools and also can do basic soldering work too?Yes,try website like Ebay.com to by the RCA tv convergence fuse to replaced at location FL231 and and also resolder FBT-Flyback tranformer too.Will solved this tv RCA model convergence problems.
Aug 02, 2011 | RCA R56WH76 Projection Television
Words have a shadow effect about 1/2 inch above the real image.most easily seen on words ( sentances)i have the rear of the tv apart, but can't figure out how to adjust the lights up and down to fiw the...
You need to use the remote control and go into picture set up, to adjust the convergence settings. See your owners manual. If you can't adjust the picture back in then the convergence amplifiers are bad and will need replaced.
Dec 05, 2010 | RCA P52928 52" Rear Projection Television
RCA TV service # 24V414T Turns on buy itself,
ive seen this before. possible remote control interferance from nearby neighbor
Nov 13, 2009 | RCA Televison & Video
My tv rear projection dont take the remote control my the year 1999
You need to replace the infrate remote sensor on the tv.(receiver problem)
Oct 14, 2009 | RCA P52928 52" Rear Projection Television
A RCA remote with no codes
Unfortunately there isn't much you can do to 'add' codes. You can try doing the 'code search' function, but this is basically the problem with buying cheap electronics. If the 'code search' function (look in your manual for how to start it) doesn't work, sorry, but you're out of luck.
Feb 05, 2009 | RCA RCR311B Remote Control
Convergence
Replace (2) STK392-150s these are your convergence ics.
Nov 12, 2007 | RCA P52928 52" Rear Projection Television
Aug 18, 2007 | RCA P52928 52" Rear Projection Television
RCA P52928 52" Rear Projection Television Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
