Question about GE Washing Machines
Washer is loud when on the spin cycle and grinds when it is on the wash cycle, I've also notice the clothes are wetter when the washer is done
5-6 years old
  • Stacha Nov 29, 2012
    model # S3700G0WW and seril # GM924291G
    Top Expert:
  • GE Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 28, 2012
Coldcut
  • 1554 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
The belt is slipping and needs replaced.
Posted on Jan 26, 2008
clusterfx
  • 67 Answers
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
ghappliances
  • 126 Answers
SOURCE: whirlpool washer Loud Grinding sound in spin cycle
HI,YOU MIGHT HAVE EITHER A BROKEN SPIDER THAT IS LOCATED BETWEEN THE IN AND OUTER DRUM OR A BROKEN BEARIG.BEST YOU GET A EXPERT TO HAVE A LOOK AT IT FOR YOU.GOODLUCK.MOHAMED
Posted on Sep 12, 2008
SOURCE: Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Posted on Apr 06, 2009
scottowa
  • 87 Answers
SOURCE: grinding sound during spin cycle
Is this a front loading machine? Also whats the model number when you open the door? If this is a front loading machine and you haven't been using HE soap, it's almost certain it's the brearing.
Posted on May 25, 2009
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Asko WCAM1812 makes noise when draining
I recently had this same problem. There is a spinning wheel inside the pump that has likely detached from the motor. Upon removing the back of the unit, you will see a water pump on the bottom left of the unit. There are three screws attaching the pump to the rest of the assembly, remove the screws and detach the motor, out should pop out a red spinning wheel. I Gorilla glued mine back on, and it sounds better than before the grinding noise.
Feb 13, 2013 | Asko WCAM1812 Front Load Washer / Dryer
Clothes are still wet after full spin cycle
Possible that the SPIN Speed is too low, check the drive, the RPM of the motor. Check for friction of the spindle , check for free movement of the drum. If you notice a change then you will need to reset the mechanism. If the motor speed is low check the capacitor.
Jan 24, 2013 | Hotpoint WMA64 Front Load Washer
Front loader spins at high speed, clothes still soaking wet? why?
I think the water is syphoning back from your waste outlet make sure the waste pipe is installed correctly
Jan 22, 2013 | Washing Machines
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
12 year old magic chef washing machine is making a lot of noise during spin cycles (with and without clothes in it) Kindof like a constant grinding/knocking. What should I do? Is it an expensive...
If you grab the bowl of the washer and try to spin it back and forth, does it feel loose and sloppy?
If so it is probably a bearing which might not be the easiest thing for you to change if you've never done it before. It shouldn't be very expensive, especially if you can take the machine apart and have it ready for the repair man.
Jun 07, 2011 | Magic Chef Washing Machines
Washer is making a grinding noise
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Mar 28, 2010 | Maytag HAV2460AW Top Load Washer
Loud grinding/scraping/rattling noise at rinse cycle
The balance sensor is likely failed.
Check the shock absorbers and springs for breakage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Washing Machines
Whirlpool washer Loud Grinding sound in spin cycle
Sep 10, 2008 | Washing Machines
Washing Machines Logo
57 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
