Realistic sta 2500 blowing fuses
Fuse blows on powering on
    Sergeant:
  • 344 Answers
It is old , It has gave up the goat, Juat get some thing allse, It will cost you less then to have it repaired,
Posted on Nov 28, 2012
5 Suggested Answers
  • 7 Answers
SOURCE: sansui g5500 receiver keeps blowing fuse 5amp.
What fuse are you blowing? A fuse in the amp itself, or the fuse in your main fuse box for the house?
If it's the one in the amp, check the speaker wires for shorts, and if thats not it, then it is bad news as stated above.
If it's youre home fuse thats tripping, then you need to consult an electrician to give you another ciruit for your setup. Possible the TV is draining a lot of power.
Posted on Jan 27, 2008
  • 20 Answers
SOURCE: Receiver fuse continuosly blows when replaced and powered up
When a fuse blows it indicates that too much current is flowing. This melts the wire in the fuse.
What is actually damaged is hard to say, remove all the cables and test. If the fuse still blows take the unit in for service.
I doubt that a resistor has died, more likely something has created a direct short. It could be a power supply issue, or an issue with the amplifiers.
Ask for a quote first if it is out of Warranty.
Posted on Apr 03, 2008
robotek
  • 1512 Answers
SOURCE: nad 218 thx power amp
Hi there. From memory they had bridge rectifier problems with them going short circuit. Check them first. Sometimes the toroidal transformer can go a shorted turn, in turn blowing primary fuses. try to soft start it whilst it is blowing fuses, Best bet is to make up a special lead that has a 60w light bulb wired in series with the mains power supply(or across the fuse holdwer that is blowing:). Limits the power in the circuit to ... well you guessed it 60 watts.
check em out and let me know.
regards
Graeme
Posted on Apr 27, 2008
  • 5 Answers
SOURCE: sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Posted on Mar 19, 2009
My 2006 dodge ram 2500 diesel keeps blowing fuse
The Internal light is normally tied to your dash lights on a factory installed radio. Find the main p[lug on the back of the radio and unplug it then try it with a new fuse if it still blows then it is the wiring if it does not blow the fuse when the radio is unplugged, chances are the radio is bad and will have to be repaired or replaced.
Sep 16, 2014 | 2006 Dodge Ram 2500
How many amps is my RCA Sta 3850 am/fm stereo receiver and where would I find a fuse for it also what exactly could be making the fuse blow out?
I would like to purchase a Realistic STA-3850 AM/FM Stereo Receiver, anyone that would like to sell, please contact me at my email address: vfintd386@hotmail.com. Thank you-dave
Mar 24, 2012 | RCA Audio Players & Recorders
2001 Chevy Express 2500 van - power window fuse blows constantly
shorted circuit usually in one of the window regulator/lift motor assemblys. remove interior door handles (or whatever is necessary) to access wiring connectors, and disconnect. insert a new fuse. shouldn't blow now. reconnect one connector at a time until the fuse blows. that is the shorted component. replace the component. occasionally where the wiring harness comes thru the frame and enters the door, the constant movement or vibration will cause the sharp edge to slice into a wire's insulation and cause a short...
Oct 11, 2010 | Chevrolet Express Cars & Trucks
My 4x4 fuse is poping on my 1994 cheve silverado 2500
a fuse only blows when it is overloaded eg.if you have a 10 amp fuse & the unit it supplying power to is drawing 15 amps it will blow, that is why the fuses are there,firstly make sure you have the right amperage fuse,if it keeps blowing,whatever it is supplying power to is faulty, don't try and overcome the problem by using a bigger fuse as you may start a fire......hope this helps.....cheers
Jul 06, 2010 | 1994 Chevrolet Silverado 2500
2002 chevy van 2500 when i turn key to start van
Fuses only blow if-Old,Overheated or you have a Short circuit.
That should be any easy fix,to the extent that there aren't many 40 Amp Fuses and you will need a wiring diagram to follow the problem from the fuse to the cause. If you know what fuse it is, you can guess,but I wouldn't recommend that,it will be time consuming and maybe costly ,if you don't have a test procedure to follow and throw parts at it.
Don't replace the fuse.Their expensive and will keep blowing.
May 05, 2010 | 2002 Chevrolet Express
Keep blowing a fuse on marker lights and dash lights (same fuse for both)
disconnect marker lights from power re insert fuse if dash stays on search for trouble in marker light circuit possible bad ground or bulb short in socket if dash blows fuse than look under dash for a damaged feed line shorting or ground short
Nov 01, 2009 | 1995 Chevrolet Silverado 2500
Engine 1 fuse keeps blowing when you turn the key
sounds as if you have a power shortage in the van. first establish what fuse keeps blowing this will help in narrowing down the short.once short is located check all connections ,wires,and plugs.
Jul 12, 2009 | 1999 Chevrolet Express
Cross wired speakers and blown power transistor. After replacing the blown power transistor, started blowing low power (3A) supply fuses on power up. Where do I look next for problems?
Often when the outputs get shorted, the "driver" circuit gets smoked as well. If you are having the fuse blow, there are additional semiconductors that are defective as well. This unit should be brought in for service. Realistically, this will need about $30 or so in parts. Without experience, this will be a difficult one to repair.
Dan
Jul 08, 2009 | Pioneer A35R 2-Channel Amplifier
My fuse blew what kind is it to replace
Its probably a GMA fuse. Its value should be on the circuit board and on the old fuse. You can get replacements at Radio Shack or your local hardware store. Just make sure it is NOT a slow blow fuse. in most cases the fuse opens due to a problem with the receiver either in the power supply or more likely in the output circuit.
A slow-blow fuse takes a couple of seconds to open and in that time more damage will be done.
Feb 02, 2009 | Optimus STA-3500 Receiver
128 people viewed this question
 Grubhead
Grubhead
