Question about Protron PLTV-32 Television
Vga isn't working
I connect my computer (windows7) and it is not recognizing anything.
    Genius:
  • Protron Master
  • 2,432 Answers
What component input did you use in the tv, the hdmi or vga port?.might not compatible video resolution of the pc to the tv.
Posted on Nov 28, 2012
Connect toshiba satellite l305-s5919 to tv with vga to rca cable
that particular model of computer l305-s5919 has RGB component out while the tv seems to be rca input.
does the tv have component in.
you may find an adapter like this might work
http://www.ebay.com/itm/Ypbpr-component-to-Composite-AV-RCA-audio-video-converter-with-power-supply/272260592065?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D44770%26meid%3D75516a845eb841a3bec53062c7dfac66%26pid%3D100005%26rk%3D5%26rkt%3D6%26sd%3D230912528485
Jul 13, 2017 | Lifetime Computers & Internet
Connect toshiba nb500 netbook to RCA tv win 7 stater with VGA cable and s video no displaying in the monitor tv didn't recognize
Does you notebook shows any connection information after connect to tv. If not you need to install. If this didn't work you have to change VGA cable. If not your notebook doesnot supports the tv
Jan 21, 2013 | Computers & Internet
Computer screen messed up after connecting to a Projector.
Sounds like your screen resolution has gotten changed. Plug your VGA cable in and reset it to 1024x768. Then with the laptop on remove the VGA cable. When you connect your laptop to other devices like that, make sure you are not setting the resolution to the same as the TV.
Jan 04, 2013 | Dell Inspiron 1501 Notebook
Iphone not recognized when attached with usb connnection
Try using different usb ports on your computer. If it doesn't work then try hooking up your iphone to another computer. If it still isn't being recognized then try a different IPHONE USB cable.
If your Iphone still can't be recognized after all of this then read the article at the link below.
http://support.apple.com/kb/TS1538
Also try restoring your iphone to factory defaults if necessary. This is a last resort. If your iphone still won't get recognized by the computer then it could be the connection on the Iphone is defective and in that case replacing the phone is the only option.
Nov 03, 2011 | Sony VAIO VGN-N325E Notebook
I tried to install windows7 but it failed.now i have lost most of my drivers.cant get on internet.system is saying i need sm bus controller,video controller(vga)and some unknown advise.i cant seem to find...
I have the very same MB on my desktop. The VGA is not available for 7 and not likely to be. you can go to the SITE and run the tool, It will give you all the updates available, which isn't likely to be many. I have decided to get a new MB after I get taxes next year. I'm sorry this isn't good news, but that is the meat of the matter
Joe
Aug 30, 2011 | MSI K8MM-V Motherboard
Hi how can i connect from my pc's s-video socket to a projector which has a jack socket? I have all the right cables I've been told to press fn f4 but my pc doesn't have fn
If it's a laptop, they've usually got a vga connector on the rear panel which you can use to connect to an external monitor...or a projector if it's got the same (vga) connector. If your projector only has a jack socket, then that's not a standard connector for a video input and maybe you should consult your projector's user guide for clarification of the connectors (are you sure your jack socket isn't actually a phono or RCA socket? if it is, then your laptop video output signal probably isn't compatible with the projector as there's no way to make s-video output feed anything other than a s-video input (different signal levels and standards) Regards, nicam49
Aug 22, 2011 | Computers & Internet
Want to know how to connect acer 3680 to tv
It depends on your TV
If your tv has a Computer VGA connection you can directly connect the VGA connector from the left side of the laptop to the connector on the tv
If there isn't then you could go buy a S-Video to RCA cable at radioshack and connect the S-Video port on the laptop to a video in connection on the TV
For sound you can connect the speaker/headphone jack on the laptop to the tv using a cable either going direct from 8mm to 8mm or from 8mm to RCA...either can be found at radioshack
Let me know if you need anything else!!
Jul 01, 2011 | Computers & Internet
Playing a downloaded film with HDMI cable to my TV set Sony Bravia, after 10 minutes the colour on tv set disappear or change. Do I need a certain drive on my computer for HDMI
If it was playing the video fine initially, there should be no reason for that to change. Most likely the video card on the laptop is overheating or dying, which results in the change in colors. I fix laptops at my computer repair shop, and most are HP Pavilion DV6000 and DV9000, and they are notorious for having bad video chips on the motherboards. If it is still under warranty I would back up your data from the hard drive then send it in to HP to have fixed or replaced. If it isn't under warranty I would try to connect your tv using just a VGA cable, and see if the same thing happens. If it does, you have a bad video card. If it doesn't happen then you may still have a bad video card, it's just that the VGA signal isn't as high powered/high resolution so your card doesn't get pushed hard enough to malfunction. Try the VGA cable and let me know how it works.
Jun 21, 2011 | Computers & Internet
My Sony Vaio VPCY115FG can connect to most wifi, except for Telstra. The main problem now is that we've switched our home ISP to Telstra. I troubleshoot the problem and the problems found are: 1....
hello. are there other computers in your house that are connected to your router? are there any other devices connected?
you should always start from your AP(access point) and work your way to your computer from there 9 times out of 10 it isn't your computer. Check that the filters are at all AP's in the house. also the router is beside anything that will cause interferance such as mobile phones, landline telephones, microwaves, radio's.
if everything is checked and the router is fully connected then you can check your computer. When switching from ISP's they will usually provide you a firmware disk so that the router will automatically connect with your computers IP. please run the setup disc if you havent already done so.
(when you change you ISP there is a usually a cooling period that you have to got through before they actually turn your line on. )
please let me know if the problem still persists after trying these methods first.
Jun 15, 2011 | Sony Computers & Internet
Protron PLTV-32 Television Logo
49 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
