Question about Hardware & Accessories
Door will not latch
interior will not latch because jam has moved
    Scholar:
  • 35 Answers
There are a few ways you can fix this problem by trouble shooting a few things.....#1 If there is room inside the door opening, and your door still closes you can "SHIM" one of the hinges out. Top or bottom can be shimmed depending on where the latch for the door is hitting the Strike Plate. Close the door and watch where the latch is closing on the frame. If it is hitting above the Strike Plate then you can shim the Upper hinge, Shim bottom hinge if latch is hitting below Stike Plate. You can use anything Thin( as Thick as the hinge plate or thinner) a wooden shim, a piece of plastic, something to bring the honge out a bit. Unscrew the needed hinge from the wall and insert "SHIM" between hinge and wall and retighten screws. This may adjusting enough so the door will latch. You may also use this method sort of in reverse. Instead of shimming the hinge, you may be able to recess in deeper into the frame or the door, creating the same affect. You will need to remove the door and use a wood chisel to sink the hinge(s) deeper. #2 If that does not work you may have to relocate the strike plate up or down, creating a new area for the latch. Follow the same proceedure as solution #1 to see where the latch is hitting the strike plate. Remove and reposition the strike plate so the latch hits in the center of the hole in the strike plate. Mark the strike plate where the new postion needs to be and use a wood chisel to recess the strike plate in its new position. Than you can patch the old area with wood putty. I think #2 is the easiest, depending on how your wood work on the door framing is......I have used these tricks before, and I hope they can help you out......Joe
Posted on Jan 10, 2009
    New Friend:
And if it even not working went the door is open?
Posted on Jun 25, 2013
How do I prevent the interior lights from coming on when driver's door is open - disable the sensor on the driver's door -- 1999 Nissan Quest.
Can you tape a coin or two onto the door at the spot that hits the light switch? If not, just remove the bulbs.
Dec 09, 2014 | 1999 Nissan Quest
1998 Plymouth Voyager drivers side sliding rear door will not open. I have removed the inner panel, checked the linkage and everything appears fine. I deduce that the rear latch mechanism is...
is the door latch mechanism moving and moving far enough to release the latch to open the door,you can`t remove the the striker plate from inside a panel as the bolts that hold the plate go in from the open side of the door jam,these do have a problem with the doors coming off the rails which mean that if this is the problem then the weight of the door will hinder the door from opening you may have to hit the door hard at the latch end of the door or even pry the door open at the same end to get the latch to pop open.the latch may even be seized or just jammed closed. good luck
Mar 02, 2011 | 1994 Plymouth Voyager
Where is the door switch on a dodge durango
Sorry Their are two different types. One is located in the jam of the door, in the body of the car not the door. it is a little black spring loaded button that pushes in when the door is shut. If it doesn't have that style then it is part of the door latch. You can take a screw driver and slide it in the latch to move the jaw on the latch their are two clicks until the latch is completely latched. try that and see if it says anything. Before you start this go arround and make sure all door are shut all the way including hatch. Then check owners manual and see if their is a switch on the dash that controls the interior lighting make sure it is in the off or door only position. There is usualy on off and door.
Dec 01, 2010 | 2005 Dodge Durango
Rear door will not open on my 2007 Ford Fusion. It won't open from the inside or the outside. I removed the interior door panel and can look inside the door. I can see the mechanism for the outside door...
use the fob and keep clicking unlock/lock button see if everything is moving.then try banging outside of the door about 6 inches from door handle while pressing unlock.has worked on some other cars like vw audi and vauxhall
Dec 30, 2009 | 2007 Ford Fusion I4 SEL Sedan
Power sliding door will not open at all manually with remote or with door locks tried to remove iod fuse and sliding door fuse but still dont open thanks
either something jammed in track/lock-- or actuator rod broke or disconnected from lock --need to remove interior door panel to get to lock release and latch check all rods and clips for damage or missing repair or replace as necessary u can manually unlock the door at latch if something was jammed or stuck in latch
Nov 26, 2009 | 2007 Dodge Caravan SXT Minivan New Cars
My interior lights will not turn off the dome light and rear bay light
check your door jamb switches to make sure they are shutting off the interior lights. They are part of the door latch.
All models have a lamp switch (13713) located in the driver's door latch that activates the interior lamp when the front door (20124) is opened.
I believe right door has one too, and maybe the hatch latch too
Aug 10, 2009 | 1996 Ford Explorer
Interior lights will not go off
try spraying the door latches with WD40
May 16, 2009 | 1996 Lincoln Continental
2001 town & countyr.. wife slammed sliding drivrs side door.. will not open.. have the interior panle off, are there more than 1 latch?
first how hard did she slam it... second... is the seat belt jammed into the door... basically the only fix for that is to move the handle as tho you are opening it and put your shoulder into it
Jan 27, 2009 | Chrysler Town & Country Cars & Trucks
Door won't latch, interior light stays on, dryer will not start
it appears that someone bent the door or the hinge. that is my first guess.
Sep 22, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Hardware & Accessories Logo
854 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
