Question about Cell Phones
Trying to setup bluetooth for boost phone - Cell Phones
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
Bluetooth for earpiece? Go live chat and I can walk you through. If I don't you don't pay
Posted on Jan 10, 2009
How to connect a bluetooth to a samsung replenise
make sure bluetooth option is turned on and also make sure the bluetooth headset is turned on.. you phone has to search for the signal from the bluetooth so make sure your bluetooth set is compatable with your type of phone but i think most are. the after it finds the connection you might have to click on it to connect
Jun 26, 2012 | Boost Mobile Samsung Replenish Mobile...
I can't find the codes for bluetooth pairing.
Normally, the 'factory default' paring code for a new bluetooth device is - 0000. Try this first.
If 0000 doesn't work, then try resetting the cd player back to factory settings (contact the manufacturer for further assistance).
Nov 28, 2011 | Car Audio & Video
How do I transfere a photo from my cellphone (boost mobil)to this computer to use in profiles & such?
Hello
It is not a difficult task,all you need to do is
1.Check if your phone has a bluetooth,put on the bluetooth of both the phone and the computer.
2.Confirm if both the phone and the computer has been paired,then you can now send your pictures,save them and use them for any purpose,
3.If your phone does not have bluetooth,you could use a USB cable to pair both gadgets and then send your pictures.
BEST OF LUCK
Jul 13, 2010 | Motorola Mobility Boost i415 Cellular...
Try to connect it to my boost mobile phone and the phone does a scan but doesnt picks up the bluetooth signal from the headset
Try this:
First, turn your bluetooth headset off. Then, start the scan to locate the headset on your phone. Just as the scan starts, turn your headset on. You may have to do it a couple of times to get it to work - but most headsets only go into pairing mode for a short few seconds just after being turned on.
Feb 06, 2010 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
I just got this phone and every time i go to recieve anything from bluetooth it says invailid file type. help
memory card ko password lag geya usko kholne ke liye kon sa password lagana chahie
Dec 19, 2009 | LG LX350 Cellular Phone
User manual for LG HBS-110 bluetooth headset
To pair the headset with your phone:
Turn on the headset. Then turn on bluetooth in your phone and search for bluetooth device.
When your headset is detected, just select it and follow onscreen instructions to pair it with your phone.
Jun 08, 2009 | LG HBS-110 Wireless Headset
I can't get unsupported objects such as ringtones through bluetooth.
To the best of my knowledge, this happens because Boost Mobile does not want you to be able to get ringtones from anywhere but through them. If someone sends you an MP3 file in a message, that file most certainly would be supported by your phone, because the Motorola i335 supports MP3 files. However, Boost Mobile can be greedy at times. The reason they tell you that the object is unsupported is because if they would let you download the object and allow you to save it to your phone, you would be able to use it as a ringtone like you want to. If you are given the capability to use files from the internet, friends' phones, etc. as ringtones, Boost Mobile loses money, because you get the ringtone, and Boost receives no compensation for it, making it unnecessary for you to buy anything of that nature from Boost.
May 04, 2009 | Motorola Mobility I335 Cellular Phone
Setup help
To locate the bluetooth you need to set the bluetooth up into pairing mode. Do this by holding the button on the bluetooth till the ring turns purple. Then see if you can pair it to the phone.
Jul 24, 2008 | Motorola Mobility H700 Wireless Headset
Bluetooth module not attached
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H500 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jun 27, 2008 | Motorola Mobility H500 Wireless Headset
Motorola V3x cellular phone
have you tried this? make sure that if the other persons bluetooth is not permently turn on that they select 'find me' in the setup selection. settings - connectivity - bluetooth link - setup - find me. good luck
Feb 12, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
153 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
