I put a new hard drive in my computer and did not work
  • 2,072 Answers
Did you load an operating system on it or just add a new blank hard drive? What Operating system?
Posted on Nov 28, 2012
I connect my Hard drive after a month . once i connected its works properly than I connect to the different PC all of sudden its wont works, computer reconganize the drive but not able to access any files....
If it works on some computers but not on others either they don't support the format or the drive letter assigned to the drive is already in use by the computer. Windows Help > Change drive letter
If it cannot be read by any computer either the hard drive has failed, the AC adapter has failed or the internal board that converts USB to drive interface has failed. Best bet is to remove the drive from the enclosure and put it in a new enclosure. NewEgg.com or Best Buy > drive enclosures
If a new enclosure does not work the drive has failed. Google > hard drive recovery
Jul 18, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
I installed a new hard drive in my PC. It installed itself after I turned on the computer but it doesn't seem to show up on My Computer as a individual drive. BIOS and the Sys Info recognizes there is a...
Are you sure your BIOS is not showing the old hard-drive you had before you installed the new one?
On the new hard-drive you bought, do the following step
there should be a jumper that came with it, put the jumper to "master",
if that didn't work, put it to "slave", if that didn't show up, put it to "cable select" and try it.
If all failed, totally remove the jumper and try.
Also check in the BIOS to make sure that the Drive is not disabled.
This seems to be a problem from the jumper.
Please rate 4 stars if this helped you.
Apr 26, 2011 | Seagate HDD 1TB 7200RPM SATA600 32MB 3YR...
HP a6412p added 2nd hard drive but wont work get blue screen
you should try switching the sata port you plug your new drive into. also, you should go into your BIOS setup f2 and save setting then exit.
Jan 25, 2010 | HP Computers & Internet
My files on my hard disk are corrupted whaat do i
You can try taking out the hard drive from the ps3 and hook it up to a computer that has SATA connections. Then copy the files to a flash drive. This way you can at least save the information from the hard drive.
At that point, put a new SATA hard drive into the PS3 and format the drive. Then at that point put the information that you saved to the flash drive onto the ps3 hard drive. Do this all in the computer after you format the new drive in the ps3 and then put it into the computer to copy the files from the flash drive into the new hard drive.
Dec 23, 2009 | Sony Playstation 3 (PS3) Console
My computer will not recognize my external hard drive
the external hard drive's motherboard is burnt take it apart (this will be a little hard but it will come apart) after you take apart u will see it is just an internal hard drive in a case so either...
1) put it inside your computer as an internal or..
2) buy a new external hard drive case (that will have a new hdd motherboard in it)
after you install it either way your computer will reconize the hd and WORK i done this just yesterday.
Nov 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I want to pull info off a hard drive & put onto a disc.
If your new computer doesn't accommodate the drive then you will need a three and a half inch hard drive enclosure to put the hard dive in from the other computer.
You will have to look at the drive to work out which type enclosure you will need.
It will either be a SATA connection like this >>>>
Or a IDE/ATA connection like this >>>>
If you compare the connections on these examples you will one has plastic connections and one has brass pin connections.
As soon as you know which type of drive you have you can then proceed to purchase an enclosure.
When you have got the correct enclosure all you have to do is install the drive and connect it your new computer.
You will be able to access the drive, copy your data and use the drive as an external hard drive.
Regards.
Sep 22, 2009 | Dell Dimension E310 PC Desktop
Lacie HD power light flashing yellow and orange
Hi. Sometimes, there are compatibility issues on external drives. Most recent computers will read them while others may not. Either the external casing or the cable is causing this.
Aug 27, 2009 | LaCie (300728U) 250 GB Hard Drive
Hard drive doesn't work
You cannot just throw a hard drive from one computer into another there are specific programs that perform specific jobs for individual components that are different in all computers.
May 08, 2017 | Seagate U Series X 20 GB Hard Drive
New Scandisk 8GB doesn't work on my computer
In your computer cheeck the privacy policys check the user manual it will give the direction to navigate the drive in your systems
Jul 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I had a computer crash I bought a new computer and put the hard drive from the old one as second
yes it is working but I cannot see any of the admin files... I can see the user files.
Any suggestions?
Mar 23, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
