Question about Cuisinart DLC-8S Pro Custom Food Processor
Motor runs but switch won't activate despite new parts
If I press the small black button on the base with a screwdriver, the motor runs.  I replaceed the 2 main bowl parts, but the switch still won't activate in the normal operating position.  If I use a knife and push the actuating pin down further, then motor engages.  I took out the switch, but there are no obvious defects.
  • 8,596 Answers
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked position. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
-Tha Mp3 Doctor
Posted on Jan 15, 2009
KitchenAid KFPM770 motor runs 3 seconds and stops
Determine first if it really is the motor. Does it only cut out if loaded or will it happen without any load? Remove all bowls and blades, plug it in and turn the power on and press the on button. With something plastic press the small white button that is in the middle above the switch panel and normally hidden by the bowl. This is the safety cutout switch avtivated by the bowl, lid and pusher being in position. Does the motor run while the button is depressed or does it again cut out after a short time but with button still depressed. If it doesn't cut out it's likely that wear in the complicated mechanisms in the lid and bowl handle are releasing the cutout switch with small vibrations of motor running. I figure out which one to replace by swapping out one of the 2 parts for a new one as I try to carry both parts in stock for that purpose.
Jul 11, 2016 | KitchenAid Food Processors
Closing the lid completely the processor does not work
Take everything off and see if you can activate the motor with the safety switch. It is located at the front above the button panel normally covered by the working bowl. Mixer plugged in and turned on press that button switch in with something non metallic. If the motor goes then fault will be with the mechanisms that activate that switch in either the bowl or the lid. The lids are slightly more likely to be the problem than the bowl. Only a new part will properly solve it.
Sep 01, 2014 | KitchenAid KFP750 Food Processor
Magic bullet base is full of particles
Yes its easy to take the Magic Bullet apart.
1. First pry out the 4 black rubber feet on the base with small screwdriver and unscrew the 4 cross head screws revealed below.
2. Remove this black base to reveal the inner black base Unscrew the cable clamp - 2 screws and the 3 screws that retain the remaining black base to the body of the bullet - slide it off over the power cable.
3. Turn the bullet the proper way up and pry out the 3 white rubber bumpers with a screw driver blade that are set inside for the cup to rest on - each is located with two rubber pins. Once all 3 are removed you will reveal 3 more cross head screws - these countersunk - remove all 3 and then the internal motor will be free to lift out through the top of the Bullet casing.
4. Its possible to slip out the 3 white plastic sliders - taking care to note how they seat each on a small spring to cleanup both the slides and the sliders.
To re assemble step by step in reverse - noting to align the motor cable with the cutouts on the bullet base.
Sep 18, 2012 | As Seen On TV Magic Bullet Food Processor
KitchenAid KFP740 9 Cups Food Processor: I used my processor last in September, 2010 to blend tomatoes for salsa (it was working just fine). When I tried to use it again in Dec., 2010 it simply wouldn't...
Most likely it will be to do with the bowl or the lid. The safety mechanisms in both parts are likely culprits, they operate a micro switch just above the switch panel and hidden by the base of the bowl. Have just the bare motor plugged in and turned on with the run button depressed. Now with something plastic depress that small black button, the motor will likely start running. That proves motor is fine and you need to figure out which of the bowl or lid is the faulty part. The pusher needs to be in the lid tube before the motor will run in case you have forgotten.
Apr 09, 2017 | KitchenAid KFP740 Food Processor
Cuisinart dlc-7 superpro food processor won't run.
The DLC-7 SuperPro is awesome -- very powerfull. Be aware they are 1.5 horsepower; the blade can take your hand completely off in a blink of an eye. Because of the potential danger, SAFEGUARDS are in place such that everything must be aligned and in correct position or it WILL NOT POWER-UP. So, yes, is very likely the safety switch.
Simple test: Use just the BASE, (no work bucket, no top, no blades), such that if it starts, only the spindle will turn. There is a little black button on the base, just back of the spindle. Use a chop-stick to depress it. Plug-in, press the button w/chop-stik, press the PULSE button. It should power up.
Presuming it powered up okay, the "problem" is probably in how the unit is assembled; such that the button is depressed properly.
1. The work bowl must be all the way down on the base, and the alignment column in the back, work bowl base skirt turned to the "Hard Stop". It will feel very solid when docked properly.
2. The top inserts and rotates into and snaps into position while pressing the plunger into the button.
It all sounds too easy, but if something is just a little off, the plunger doesn't plunge ind the power doesn't go on.
These are FABULOUS machines -- spend the time into getting it working. The near- equivalent if something this robust and powerful in today's products will cost nearly a THOUSAND dollars - seriously.
May 04, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
Motor works but will not turn on
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl asssembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Jan 01, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Bravetti Chopper Model FP 105H
Not positive as to your problem, but I was just given one of these and thought it didn't work. On closer inspection, I found a little switch that needs to be depressed from the bottom side. When I pressed it with a tiny screwdriver while holding down the bar on top, the motor runs!
I just have the white top with the motor and the glass jar thing. So I'm on a search for whatever is supposed to fit between them. There's room for a seal between the two, and I imagine it has something to push the tiny button, to activate the motor (guess technically it's a safety interlock).
In case it isn't obvious where that button is, turn the motorized plastic top upside down and look at the center. There's the star drive in the middle, and four little depressions, or holes around it. One of them isn't white inside. It's the magic switch! When I push it with a screwdriver and push the power bar, the thing comes to life...
If that works it for you, then your new mission is to figure out what pushes that button and put it in the right place.
Oct 21, 2008 | Bravetti SB212H Quad Blade Food Processor
Wont run
If you try the instructions below, and the motor test fails, you can send it in to Cuisinart for a trade-in, but the trade-in will be just as expensive as getting a new food processor (unless your product has an extra-long motor warranty):
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. Make sure you enter your exact model# at Cuisinart's website, because a DLC-7 is not the same as a DLC-7E or 7P, for instance. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl assembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Sep 16, 2006 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-8S Pro Custom Food Processor Logo
194 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Greg Cann
Greg Cann
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
