Question about Hitachi 51UWX20B 51" Rear Projection Television
Fuse Locations Power light comes on but no picture or sound. Other posting state it was an E907b pica fuse 3000mA and can be replaces. Can't locate and would like the location of all the fuses. Can find the larger fuses at the power input side but nothing else. Please help
  • 934 Answers
If E907 is open it's merely a symptom and NOT the cause. That said, there are several pico fuses in that unit. The three main are E903, E904 and E907 Hitachi p/n#AZ00106M If any or all of these are open it is an indication of a problem associated with the deflection board. Hitachi uses tiny yellow pico fuses. Most common are yellow and green. The "E907" is going to be printed right on the board next to the component it identifies. This is known as a location number. But let's get onto solving your problem... The fuse is not going to be the resolution. Having the deflection board repaired will. The regulator IC902 (remember that's a location number) is an STRF6628 it together with the horizontal output transistor and other components need to be tested to find out which culprit opened your pico(s). For this you'll need at a minimum a DMM meter, and ESR meter and a 20mHz scope. If you're lacking any of these you stand about as much chance of doing this repair as you do winning the lotto - - three times in a row... But, you could pull the board and send it in to PTS Electronics who rebuilds boards for a flat fee... problem there is it will be torn down and waiting a week or two and if you have no memory for all those wires, and where they go when you get the board back,,,, well I wouldn't give that idea much hope.. Lastly, the alternative, is calling a reputable shop and have them estimate the repair. If you can take it into them you''ll cut the cost significantly. And if you're not sure where to find a reputable shop contact NESDA and have them give you a referral to one of their member shops in your area.. Hope some of this helps.. Good Luck Bill
Posted on Jun 06, 2007
My turn signals and hazard lights have stopped working in my estima 2001 where is the fuse box for these lights
There are 4 fuse boxes in a 2000 + Estima
one in the passenger footwell behind the glove box...
One in the drivers footwell behind the lower trim
2 under the bonnet..... one above the engine
pictures of there locations link below
http://www.teoc.ws/community/topic/19417-fuse-box-locations
Jan 30, 2016 | Cars & Trucks
Drum turns but no heat
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad.
When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner.
One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad.
Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure.
There are 50/50 chances of thermal fuse blowinf up which does not heat.Regarding the thermal fuse I would recommend to replace it one more time and not to use the Self clean any more until you will perform all checks and repairs according to the service pointer. The thermal fuse is located at the back of the oven..
You can check about the pica and description of it over HERE
And one more thing if used the broil method you also have to replace the broil heating element due to low resistance.
So finally i just want to say replace the broil element and the thermal fuse and your problem will be solved.
Goodluck,
Please don't forget to rate me as fixya..
Feb 08, 2008 | Kenmore 62602 Electric Dryer
Where is the headlight fuse
you havent mentioned vehicle but usually interior fuse box is below dash drivers side , lid/cover will give the fuse's locations . if the fuse's are ok then check that there is power at the bulb holders if there is then it's the holders that need replacing , these can get distorted over time and the bulbs dont sit properly and make contact , if there is no power then need to trace from light switch forwards , also there will be a fuse box under the hood , usually very close to the battery , there may be a lighting relay in there , also locations given on the lid , hope this helps get you started
Jun 28, 2015 | Cars & Trucks
Power outlets do not work.
These outlets get shorted by improper use or wear, check the fuse boxes for blown fuses. the locations are stated in the owners manual fuse box diagrams.
Aug 29, 2012 | Chevrolet Silverado 1500 Cars & Trucks
Starter was bad i replaced it nothing works exept headlights i can hear the motor click to put up convertible top but thats it
Sounds as if you blew a fusable link. Below are 3 pictures. The first one is the location of the coolong fan relay. The second is what the connector looks like at the relay. At the connector using a test light you should have power at all times in the number one position of that connector. If you do not then most likely the fuse link has been blown. There are several fuse links down by the starter and more then one of the could have blown due to you shorting out those wires so you may need to check all of them (I believe there are 4 or 5 in one location at the starter). The last picture is the locations of the fuse links I am talking about. Check for power and/or comtinuity on either side of each fuse link to see which one(s) have blown. Good luck and I hope this helps...
May 26, 2012 | 1992 Chevrolet Cavalier
I have a 1999 chevy silverado and my parking light on the left rear is not workig. I have checked the fuses and they are good. Replaced the bulb and replaced the socket for the bulb and still does not...
Loosen up the housing and re-tighten, it may not be getting a good ground. Also, turn on the park lights and check for voltage at the fuse. Some auto;s have other fuses that work with other components. You can look in your manual and it may say fuse 14 is for park lights but look at other fuse locations and it will state fuse 25 is for park lights, horn, cig lighter, tow hook up. These are not the right fuse locations, just giving example of how it may be. Good luck
Feb 12, 2011 | 1999 Chevrolet Silverado 1500
WHERE IS THE FUSE FOR POWER WINDOWS LOCATED
Your owners manual should offer a picture or diagrahm of the main fuse block location...the fuse for the power windows is in this block...usually labeled...if not the owners manual diagrahm helps to pinpoint all fuse locations...
Nov 24, 2010 | 2002 Mercury Sable
Cigarette lighter in front and in back does not work in my 2000 v 70 volvo i just bought, could that be a fuse?
Definately sounds like a fuse if 2 locations are not working. Cigarette lighters are 2 wires to hook up so to have a faulty port is highly unlikely. Check your owners manual for the fuse location. It will probably not be under the hood in that fuse box but under the steering wheel up and under the dash. No big deal though.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Oct 07, 2009 | 2000 Volvo V70
Red light flashing, no picture/sound!!!!
HI, this unit has 3 main fuse links on the main board that may be blown. the fuse links should be check before you move further into the diagnosis stage. once you have checked the fuses and they are still in a working state, this will confirm a power supply board failure. this board provides and regulates the current flow and distribution of it throughout the entire unit. If the fuses are fine and the power supply board is damaged, the green light will come on briefly then, the main control will notice that the power supply is not functioning properly. Once the main control board senses an abnormal current, it will shut down the TV rendering the red light warning. The list of fuses to check are below. Remember, if they are fine and working, the issue will be the power supply board itself and, it will need to be replaced.
FUSE CHECK LIST--
3A 12v- fuse----(242208600623)
SM 3A 125v-fuse----(242208600657)
500 MA-fuse-----(242208611092)
PART NUMBER FOR POWER SUPPLY BOARD
(996500036816)
Please rate and god bless:)
Apr 13, 2009 | Philips 42PF9631D 42 in. Plasma Television
Klipsch ksw subwoofer wont power on
The power supply switching transistors are likely fried. Dangerous high voltages involved. I would remove the plate and send it to Klipsch for repair.
Jan 16, 2009 | Gem Sound SUB-650M Speaker
Hitachi 51UWX20B 51" Rear Projection Television Logo
263 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
