Question about Air Hogs Havoc Heli Helicopters
My rc helicopter won't fly straight
Can't get helicopter to fly straight
3 Suggested Answers
  • 23 Answers
SOURCE: my helicopter wont fly
either stripped the main gear inside the heli or the main blades where they slide on the shaft. you should be able to buy a replacement set of blades. try that and see if it'll fly.
Posted on Apr 04, 2010
bayyagg
  • 1672 Answers
SOURCE: my green air hog helicopter
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Thanks for asking FixYa!
Posted on Aug 09, 2011
Just got a s301g Helicopter and it won't start up
Check the wiring where you plug in the charger to the helicopter. There is a red wire with quick disconnects. If its loose (the quick disconnect) you get this problem. In my case the helicopter came out of the box with this completely disconnected. It was hard to connect because there wasn't enough slack wire but once we did it the white light on the front of the helicopter came on and we were flying.
Nov 19, 2012 | Syma S301g Rc Helicopter 18" 3 Channel Rtf...
My air hogs stinger since day one will not fly straight up.
Look for a trim setting or reference trim the users manual. It is usually a dial on the side of the remote.
Oct 10, 2012 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Hi, I have a Walkera CB180d and there doesn't seem to be enough power for the helicopter to lift higher than my shoulders. I replaced the main rotor with a new one after I noticed a gap in the...
The gap is causing you to loose power transfer. Replace the main gear and you should be back in the air. The CB180 is a fixed pitch, so as long as the blades are intact and straight, you can't do anything esle to them. Also make sure your battery is good and fully charged.
Aug 12, 2011 | RC Remote Control Helicopter Ready To Fly
My green air hog helicopter is spinning on the ground, it won't lift and fly, how do I fix it?
Aug 09, 2011 | Air Hogs Havoc Heli Helicopters
My helicopter (SO32 Gyro) having previously worked perfectly now will only hover. I have tried recharging it but it makes no difference. I wonder if I have overcharged the battery and if it is possible to...
Batteries are available online (amazon and many others) and change easily with only small screwdriver. Overcharging is not the issue. Nearly impossible with PCB (overcharge prevention circuit) hard wired into battery AND in charger. Problem is likely UNDERcharging, overDIScharging, or improper battery care. Battery MUST be allowed to cool 10 minutes after flying. Charge until light on charger doesn't get any brighter when helicopter is unplugged... light comes on (dim at first) well before full charge. 10 minute cool-down after charge also a MUST. And, most important, when flying, as soon as you are unable to maintain altitude, land helicopter and power it off. Li/Po batteries should never be fully drained. Even one full discharge can cripple or ruin entirely your helicopter's battery.
hope this helps.. let me know,
r
Feb 27, 2011 | SYMA Toys industrial Syma S032 Ready to...
I have an air hogs sharpshooter helicopter and it wont stop spinning when i try to fly it and it only gets about a foot off the ground
it could be that you just need to use the adjustment nob it is next to the right joy stick u can turn it to make the heli fly straight. or one of your blades is not working like it should.
Jan 06, 2011 | Master Heaters Air Hogs Sharp Shooter...
I need an owners manual
why does my helicopter fly to the right.Are there adjustments? how do I make it go straight. I'm new to this. I'm just trying to find out all i can
Jan 05, 2011 | Jumbo RC JUMBO HELICOPTER
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
S032 won't fly higher than 0.5m. and for a few secondes. I bought 2 Syma S032 helicopters whith 3 lipo's. The first 3 a 4 times both choppers flow verywell. I have charged the batterie's so as told in the...
1) Ensure you're fully charging. Indicator light on charging unit should NOT get brighter at all when you unplug the helicopter. If it does, then plug helicopter back into charger until light stays the same when you unplug. Note: If you're charging with a usb charger and are using a laptop or the front side data port on your desktop, these may take several hours to fully charge as they are usb 2.0 and do not carry the full 5 volt dc charge. Use powered usb (3.0) on back of desktop, or get a usb/ac adapter. Normal charge time approximately 1 hour. Go by the light, though.
2) Don't run them dead. As soon as you can no longer maintain altitude, land and turn off helicopter. Fully discharging a Li/Po battery (particularly when it's new) will cripple it's ability to hold a charge, and can ruin them.
hope this helps
r
Nov 01, 2010 | SYMA Toys industrial Syma S032 Ready to...
My rc helicopter wont fly high?
flew at first hit sealing won,t fly now hit the trim button,s but still wont fly
May 13, 2010 | Radio Shack Indoor Micro Mosquito Rc...
Air Hogs Havoc Heli Helicopters Logo
306 people viewed this question
Top Air Hogs Toys Experts
freddyfox
jasiel murphy
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
