Question about Dryers
I have a desk lamp and broke the glass lamp shade, where may I obtain a replacement for: 07/2M E109585-RJ02 Portable Lamp Issue No. BJ-1093 Copyright Cheyenne. Note: this is not for a ceiling fan, it
07/2M E109585-RJ02 Portable Lamp Issue No. BJ-1093 Copyright: Cheyenne
SOURCE: fan light relacement
you can go to the home depot and they sell any class for any kind of fan take one that is not broke and they might have it
Posted on Sep 13, 2008
SOURCE: Glass Diffuser 54" Ceiling Fan Cruiser
opal glas single light lamp
Posted on Feb 18, 2008
landsend
  • 1066 Answers
SOURCE: Broken glass cover for Hampton Bay Cruiser ceiling fan.
go to Home Depot, not only do they have replacements, but they can order for you what you need.  Hampton Bay is the Home Depot brand.
Posted on Mar 31, 2009
Rube69her
SOURCE: Glass Shade wont come off
The same thing happened to me, you put them on two tight. just right now i was going to take mine off so i could let u know which way to turn it. but can't take it off and i just put it on last night, & not too tight. i just remember that i have an xtra one, okay i got it it's counter clock wise. you're going to need someone to help you hold the light kit fitter assembly while you turn it. careful not to strip the light kit fitter assembly. mine rotates both ways now because when i tried to take it off it would turn so mabybe it's the other way, and nothing. then i got **** & started to used more force, back and fort, by myself even with the help of my friend it was a ***** to get it off. good luck. Rube
Posted on Jun 27, 2009
  • 48 Answers
SOURCE: hampton bay glass shade broke model no. 640-658
good luck cutrite , Hampton Bays importer King of Fans in Fl prob wont even know what your talking about they don't speak English very good. If you speak Chinese you might have a chance but if the part is over a year old..'forget about it' as we would say... they don't stock old parts (over a year) and everything is manufactured in China. Try a local lighting store you'll save yourself a lot of aggravation. And don't patronize Hampton Bay it only encourages them to push garbage on us all.
Posted on Sep 28, 2009
Kyocera c3200 error Problem
A C3200 is as follows:
Exposure Lamp Problem.
• In indicator check before starting copying, the average value in scanning of the shading plate with the CCD is 128 or more.
Solution:
Defective scanner board (KP-5063).
Replace the scanner board (KP-5063) and check for correct operation
Defective exposure lamp or inverter board.
Replace the exposure lamp or inverter board.
Incorrect shading position.
Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor.
Poor contact of the connector terminals.
Check the connection of connector YC7 on the scanner board (KP-5063), and the continuity across the connector terminals. Repair or replace if necessary.
These are direct from the Tech man.
More than likely it is the Exposure Lamp.
Hope this helps.
May 02, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Hi sir ....... when the copier ( kyocerammita 5530
Optical system (AGC) problem
1. insufficient exposure lamp luminosity
2. defective engine pcb
3 incorrect shading position
4. defective CCD unit
check exposure lamp harness connections; adjust position of contact glass shading plate or clean/replace the scanner home position sensor; replace the exposure lamp or inverter pcb if needed; replace CCD unit or engine/main board if applicable
Jan 10, 2010 | Office Equipment & Supplies
I have a OK Lighting touch lamp and three of the glass planels are broken do you kow whenere I can get replacements
Hello there:
here is several links that will definatly help you in your quest to find touch lamp glass ok? look below mainly # 3
best regards michael
  1. Lamp Shades - Glass Lampshades - Silk Replacement Lamp Shades - 2000 item catalog of glass lampshades, silk replacement. ... Finishing Touch - Finials. Tulip - Lilly - Large -Small. Oil Lamps & Fonts ...www.specialtylampshades.com
  2. Speciality Lamp Shades Add a finishing touch to your shades. Reverse Painted & Dome Glass Shades ... Replacement Glass Lamp Shades- Reproduction & Custom ...www.specialtylampshades.com/lampshades.html - Cached
  3. Touch & Glow Replacement Kit | LampsPlus.com 3-way touch lamp. Saves energy. Extend bulb life. ... Glass Shades. Light Bulbs. Night Lights. Under Cabinet. View All Categories. Bathroom Lighting ...lampsplus.com/.../Touch-and-Glow-Replacement-Kit__35098.html - 110k - Cached
  4. Elegant Touch: Brown's Lampshades ... a special accent for your special lamp and replacement lamp shades. ... Glass Small Tear Drop Lamp Finial. c3-finial $12.95. Crystal Gothic Cross Lamp Finial ...brownslampshades.com/store/ctgy/elegant-touch.html - Cached
  5. Nec Display Solutions 50016683 Replacement Lamp - Yahoo! Shopping Yahoo! Shopping has Nec Display Solutions 50016683 Replacement Lamp. Quick Links: Specifications - Description - Compare Prices shopping.yahoo.com/p:Nec Display Solutions 50016683 Replacement Lamp... - 126k
  6. Replacement Shade for 2198 Floor Lamp - Shop.com Shop for Replacement Shade for 2198 Floor Lamp and Floor Lamps at Shop.com. the 2198TA lamp was designed by fontana arte in 1954. a very dignified modern touch to an...shop.com/replacement_shade_for_2198_floor_lamp-59830151-7...
lamp
Sep 24, 2009 | Electrical Supplies
Error 3200 and no light from scanner Lamp on Kyocera FS-1118MFP
this error belogs to Exposure lamp problem ? cause of this error 1. Defective scanner PWB. 2.Defective exposure lamp or inverter PWB. 3.Incorrect shading position poor . 4.poor contact of the connector terminals Solutions:- 1. Replace the scanner PWB and check for correct operation. 2. Replace the exposure lamp or inverter PWB. 3.Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor. 4.Check the connection of connector YC7 on the scanner PWB, and the continuity across the connector terminals. Repair or replace if necessary.
Mar 24, 2009 | Kyocera FS-1118MFP Laser Printer
Canon NP 6030 photocopier is printing all black. Cannot rectify by altering shading setting. Appreciate any help to fix ASAP. warrengevans@tadaust.org.au
Hi
If it is solid black with no hint of an image in the backround, its an exposure lamp or exposure lamp fuse. Both are not user replaceable. To check, open the copyboard(lid over the glass) and push the print button. If you dont see the lamp come on under the glass it is most likely one of the 2 things mentionerd above.
Oct 30, 2008 | Canon Office Equipment & Supplies
Dryers Logo
854 people viewed this question
Top Dryers Experts
