Question about Maytag Neptune MAH5500B Front Load Washer
I can always see water clear up to the bottom rim of my washer(door) after a load is finished. I had a technician out & he said some water always stays in the washer. It has become so bad that I have to run an empty load before I can do my laundry or the clean (?) clothes smell soured. This is unaceptable.
  • MEGAN RAE Jan 17, 2009
    THE WASHER WILL NOT DRAIN!!! HELP!!!!!
    Genius:
  • 1,036 Answers
First turn off and remove the outlet hose from the drain. Because the machine has water in it - it will be heavy to move. Lower the hose into a bowl to drain it.
Check to see that the hose is not full of debris / grease.
If it does seem bad, replace it in the outlet again, and use a cup of soda crystals in the machine - wash it on a hot cycle and see if it clears things.
There should also be a plastic hose support at the top of the outlet to stop the hose from kinking. Often it is missing and over time causes this problem.
Please post back if it does not improve before rating, as there are other causes too.
Posted on Jan 10, 2009
The washer wont spin on the wash cycle and water is standing in the bottom
You have a clogged water pump/ bad or a door switch .it is easier to remove the back panel to access the pump. Now remove as much water,now make Sure the machine is unplug. Get lots of towels , removed the two screws that holds the pump. Place towels under pump, caution water. Slowly unscrew the drain, but do not remove yet. After water is finish remove and clear pump trap. If the pump seems clear remove the pump and test it. You can open it Mark the location with nail polish for easier installation. Open the pump look for debris. If none of that works its the door switch. Good luck.
Mar 19, 2013 | Frigidaire Affinity ATF7000E Front Load...
I have a Whirlpool Washer, Duet, 3 years old. I have had the washer stop withour being finished with the cycle. None of the controls would start it, the door was locked, and the error showed an F 21...
The F21 error code indicates a long drain time on this type of washer. The door will not unlock if the washer control detects that water is still in the tub. To manually unlock the washer door, take these steps:
  1. Unplug the washer to completely disconnect electrical power.
  2. Remove the bottom front service panel as shown in the first image below.
  3. Carefully reach up through the bottom opening and pull the release tab on the bottom of the door lock assembly until it clicks. NOTE: Internal metal edges in the washer can be sharp. Protective gloves are recommended for this procedure.
By pulling the manual release tab on the door lock assembly, you should be able to get the washer door open.
After opening the door and removing the clothes, I recommend emptying any remaining water in the tub with a wet/dry vacuum (or bail it out). Since you already have the bottom front service panel off and the washer unplugged, you can arrange shallow pans and towels to catch any remaining water and pull the filter out and clean it You may find a clog in this area that is preventing your washer from draining properly. Clear any clog or debris from this area and reassemble the washer. Check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Here is a video to show you how it is done.
Oct 19, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My bendix washing machine door does not open after wash cycle ha finished
  1. Is there still water in the machine when the wash cycle has finished? If so, the door doesn't open because there is still water in the machine. Try clearing the filter at the bottom of the machine, in the front. If this doesn't work, check that the drain hoses are cleared. If it still doesn't work, try replacing the drain pump.
  2. Is the "door" light still on? You may have a faulty door lock assembly, or your control board may be faulty.
Feb 27, 2011 | Tricity Bendix AW1400W Front Load Washer
Mold remain in rubber rim of washer
Hi Qqiustin.There are couple of solution for this,you can try that before attempt to change door gasket.1- Run machine empty on Cotton 95C cycle,while it's intaking water add 300ml of bleach.(It could produce some foam but let it go & finish it's cycle)That progress will clean your machine & mould on the door gasket should get disappeared.Alternatively you can try EXIT MOULD or likely products on the super market sells.Follow the instruction.Goodluck.Thanks.
Aug 02, 2010 | Miele W1926A Front Load Washer
Kenmore HE2 does not drain after first load.
  2. Remove the bottom front service panel.
By pulling the manual release tab on the door lock assembly, you should be able to get the washer door open. After opening the door and removing the clothes, I recommend emptying any remaining water in the tub with a wet/dry vacuum (or bail it out). Since you already have the bottom front service panel off and the washer unplugged, you can arrange shallow pans and towels to catch any remaining water and pull the large item filter out of the drain pump assembly as shown in the second image below. You may find a clog in this area that is preventing your washer from draining properly. Clear any clog or debris from this area and reassemble the washer. Check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Feb 23, 2010 | Kenmore HE2 Plus Front Load Washer
My front load Tromm LG washer flashes OE message, won't drain or finish wash. Door does open
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
Dec 20, 2008 | LG WM-2277HW Front Load Washer
Kenmore Elite smart wash quiet pak 9 Front Load Washer
Our washer is flashing a F21 and it never finishes the load there is always water left.. what can we do to fix it?
Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
Water still in washer.
remove bottom panel and clean pump
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Affinity Front Load Washer
You have to remove and clean the rubber around the front of door,
, Snap it back on.
disconnect AC to prevent any accidental shock.
open the bottom access panel
screws on bottom front , open the large filter and be ready for latent water to spill out , have rags ready.
clean the inside of the filter with clorox.
finally run a strong solution of clorox when you finish.
then rinse well.
leave the door open after loads finish
the door has a child lock
black dot next to lock on door , insert coin and rotate.
keeps them from closing the door.
Feb 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
