Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
How to do replacement of Dyson DC15 PCB to Yoke Loom 907280-02
3 Suggested Answers
chrispurs1
  • 372 Answers
SOURCE: Changing the main hose on a Dyson DC15 Animal
Hi Bob.
If you look carefully where hose & elbow jount enter machine you will see a slot.
Rotate elbow so that lug on elbow aligns with slot & pull off.
http://dysonmanuals.llc.nu
Posted on Jan 14, 2009
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: Dyson DC15 Animal will not run in upright position, only when reclined. Power also does not seem to be all there. Any suggestions?
    Hi Ian,
    I'm sorry to hear you're having difficulties with your DC15. If the cleaner doesn't seem to be picking up as well as usual, it's likely to be due to a blockage in the machine, or because the filter needs a wash.
    The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
    http://www.dyson.co.uk/support/help.asp?article=815&product=DC15-ANIMAL
    In normal use, the filter should be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
    This should resolve your concern about the cleaner's performance - however, if the machine continues to shut off when stood in the upright position, it's probably best if you get in touch with us directly so we can help. You can call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
    Kind regards,
    Jack
    Dyson Online Customer Support
    Posted on Nov 14, 2011
    What does the pcb do as it keeps blowing fuses
    Hi, its the brush bar motor unit it must have a fault .It can be replaced.
    Dec 19, 2015 | Dyson DC15 All Floors - The Ball Bagless...
    Dc15 manual
    Hi Jean, it's Jack at Dyson.
    You can download a copy of the Dyson DC15 User guide directly from our website: http://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc15_uk_manual_120710%20pdf.pdf
    If you're looking for some help troubleshooting an issue, our online Support pages should come in handy: http://www.dyson.co.uk/support/dc15/dc15-the-ball-all-floors
    If you'd prefer to speak to our experts directly, you can reach the Dyson customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Mar 23, 2014 | Dyson DC14 Bagless Upright Cyclonic Vacuum
    When vaccum is tilted back suction does not engage.
    This can happen if two tiny wires that are connected to the circuit board and lead to the beater bar are broken. These wires brake where they go through a black rubber grommet. You need a torx screwdriver (No: 15) to remove two plastic covers to access these wires . When looking from the front of the vacuum, the circuit board is located under the gray covers on the right side of the vacuum. There is one big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
    Once covers are removed check both yellow and blue wires carefully. Wires may look intact but the break may occur inside the black grommet. Slowly and carefully push grommet out and then carefully pull wires to the one side. If a wire is loose or broken you will immediately see the break. You can replace wires using replacement part given below or if you are OK with using soldering iron you may be able to repair broken wires without any expense.
    Best solution is to replace broken wires with a new set of wires and connectors having fed the wires through the access hole making sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
    • UK: Dyson DC15 Loom BB Over Current, Part No: 907280-03, Approx. Pounds 4.45
    • US: Dyson DC15 PCB to Yoke Loom, Part No: 907280-02, Approx. $11.75
    See more details and photos at: http://bajwa.net/content/dyson-dc15
    Feb 20, 2013 | Dyson DC15 All Floors - The Ball Bagless...
    Where is the plunger located on a Dyson DC15 all floor model
    I'm not sure which part of your DC15 All Floors you're describing, but if you take a look at our Support page for this model, you should be able to find the information you're looking for:
    You can also download a copy of the user guide for this machine here:
    http://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc15_uk_manual_120710 pdf.ashx
    I hope this helps - if you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack
    http://www.dyson.com
    May 12, 2012 | Dyson DC15 All Floors - The Ball Bagless...
    Fixing seal on dyson dc15
    I'm not sure from your question which seal you're trying to replace on your DC15. For assistance, please get in touch with us directly by calling free on 0800 298 0298 (UK), or 1-866-693-9766 (US) - it will help if you have the machine to hand when you call.
    We'll look forward to hearing from you.
    Best wishes,
    Jack
    Jan 08, 2012 | Dyson DC15 All Floors - The Ball Bagless...
    Where is the upright switch located on a dyson dc15 all floors thanks
    Hi John,
    I'm not sure from your question exactly which switch you're referring to on the DC15. However, you should be able to find an answer on our online support guide for this machine:
    http://www.dyson.com/support/help.asp?article=527&product=DC15-SY-STD
    You can also download a copy of the DC15 user guide, in case you don't have yours to hand:
    http://media.dyson.com/downloads/us/floorcare/manuals/dc15_opmanual_usa.pdf
    I hope this helps - if you'd like any further assistance or advice, please call our Helpline free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack
    Oct 29, 2011 | Dyson DC15 All Floors - The Ball Bagless...
    DYSON VACUUM BRUSH WON'T TURN
    The problem will most likely be either with the PCB under a panel on the side of the chassis, or the small wires from it that feed the front brush motor.
    If you are technically inclined, you can ask for more detail on the repair here: The Dyson Forums
    Dec 05, 2010 | Dyson DC15 Animal Bagless Upright Cyclonic...
    I need a vacuum brush housing assembly for Dyson DC15 animal. Part of it is broken (plastic).
    http://www.espares.co.uk/dyson/dc15/p/1086/716/10
    Try the above link or do a search in google for "Dyson DC15 parts". Also, try searching in Ebay. You should have no problem in locating the part. Lastly, try calling Dyson at 866-MyDyson.
    Good luck.
    Aug 10, 2009 | Dyson DC15 Animal Bagless Upright Cyclonic...
    Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
    250 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
