Question about Targus AMW15US Mouse
Communication problem I am not able to connect my mouse with laptop. Even with connection using usb cable. Please solve my problem.
  • 1 more comment
  • shtank2001 Jan 23, 2009
    Thanks man, it helped me. My problem is solved.
  • shantellhadl Jan 24, 2009
    I HOOKED THE MOUSE TO THE LABTOP BUT ITS NOT WORKING IT ON BUT NOT WORKING
    President:
  • 8,637 Answers
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Jan 22, 2009
How do I use mouse instead of touchscreen on Samsung laptop
Do you have a mouse connected by cable or a USB dongle? If so, then your computer's Plug and Plug (PnP) capability to detect, install and activate peripheral device drivers will have recognize the mouse and made it accessible to you. If the mouse in not usable, look in Start, Computer, System Properties, Device Manager, Mice (etc.). If you have a Yellow Triangle, click on the mouse then the Driver Tab to Update the driver. This should solve you problem. You may have to Restart to gain access. If that doesn't work. Unplug the mouse connection, Restart the computer, then plug the mouse connection in again. Watch to see if PnP detects the connection and installs it.
Sep 20, 2014 | Samsung Computers & Internet
USB port for wireless mouse gets hot and not working
1-try to connect another USB peripheral like USB flash or something else,if this does happen again you have some problem with your USB chip or maybe your main board or USB cabling in your laptop (some kind of short circuit),
2-if your problem still did not solve you have some short circuit or problem with your USB device and try repair or replace the device ,
3-if your problem persist and doesn't solve even with another device you must consider this note:
some USB devices needs 500ma current mode that only available in PCs and some devices and most laptop available in the market just support 100ma USB port
Dec 15, 2013 | Toshiba Computers & Internet
I dont know how to install my mouse to my laptop. The laptop is an ASUS. please email me asap
You can only connect USB mouse to yout laptop. For USB mouse the driver is not needed. You can just plug in the USB cable of mouse in USB port and go ahead. Windows will install the relevant software automatically.
Thanks,
Amar
Sep 05, 2011 | Dynex Wireless Optical Laptop Mouse...
I cant get my mouse to connect to the computrer, I have the mouse and the batteries are inside but is there supposed to be a reciever with it?
If you are talking about wireless mouse than definitely yes , it should have a usb device which will go to your PC or Laptop usb port so that your mouse can communicate with it and work.
If you are using a laptop which has a inbuilt Bluetooth and even your mouse is also a Bluetooth mouse, In this case you have to you Bluetooth device setting application and pair your mouse with your Bluetooth devices.
All the Best.
Jul 10, 2011 | Logitech Cordless Mouse
In my dell xps L501x ethernet cable is shown unplugeed even when it's plugged in. The cable which i m using works fine on my desktop which i connect to my adsl2+ mt882 modem through this cable. Cable also...
1. laptops USB port is not recognized by the router .
2. This could be due to the usb hub drivers for this unit not being installed on the laptop.
3. check your "device manager" to see if you have all the usb hub driver installed.
4. Also check your router manual for the usb setup for a laptop connection.
Feb 20, 2011 | Skque Ethernet Cable Cat5e RJ45 White 30...
I just purchased my first laptop...and do not like the touchpad...I want a wireless mouse...can I use a wireless mouse without being connected to wireless...in other words can I use a wireless mouse while...
Yes, the mouse most likely uses Bluetooth to communicate with your laptop and is independent of your wired/wireless connection to the internet. The mouse should have come with an adapter that plugs into one of your USB ports. Plug it in and once the drivers load (automatically), your new wireless mouse should be working!
Sep 08, 2010 | Computers & Internet
Disable onboard mouse
TouchPad Enable/Disable ( Fn+F9 )
Dec 24, 2008 | Toshiba Tecra A3 Notebook
Dell A920 Inkjet Printer is not communicating with an HP Pavillion dv6700 laptop with Vista Operating System
It could be related to Vista. Check Dells website to see if they have a Vista driver for it.
If you have another USB Cable you can try swapping it.
If you have a spare USB Port, you can try swapping that as well.
Jun 15, 2008 | Dell A920 InkJet Printer
Input failure on the above laptop
just try to check your connection may be your usb connection is loss contact....or maybe the cable wire is disconnected...to solve that problem you just try another keyboard and mouse....
Dec 17, 2007 | Acer Aspire 5100 Notebook
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
Targus AMW15US Mouse Logo
461 people viewed this question
Top Targus Computers & Internet Experts
dhnguyen
Josh Whitehead
Josh Whitehead
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
