Question about Kohler Toilet Seat - Elongated Front Quiet Close Quick Release - Cachet by
My self closing toilet seat is making loud noise when closing
  • 33 Answers
SOURCE: Quiet-Close Kohler toilet seat lost its quiet close feature
Hello len_moon, Look under plumbing in your yellow pages for a Kohler distributor. Also here is the web page for you part numbers. You will need the hinge assembly. Copy and Paste to your address bar. Hope it helps!
http://www.kohlerserviceparts.kohler.com/ServicePartsPage.aspx?DocumentID=c83b1f213d0545f984b01b9f0be37b9d&ModelID=558da26604ce43ec98c83fe8ed0aa604
Posted on Feb 03, 2009
  • 2976 Answers
SOURCE: slow closing toilet seat not working
It needs a new air shock on it. You might be able to take the old one apart and fix it but replacement would be best.
Posted on Feb 18, 2009
  • 81 Answers
SOURCE: QUIET CLOSE TOILET SEAT COVER
There is no adjustment for a slow close/quiet close seat. It would defest the manufacturers intent.
Posted on Jun 02, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: Quiet close toilet seat no longer closes slow on
Sorry to read about your problem, I hope this helps you out.
Contact Kohler, and they will take care of you.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
  • 300 Answers
SOURCE: My slow close toilet seat
WOW! Slow-close toilet seats. What will "they" think of next, to pick your pocket?
Slow-open mechanisms such as cassette players and top-loading DVD players use a special type of grease to achieve that effect.
The screen on the laptops uses a friction mechanism based on a "clutch-spring" with enough holding power to keep the display in the position selected.
This "clutch-spring" is factory adjusted so it neither slips under the weight of the laptop screen, nor is so tight that extra force is required to close the laptop.
These things do wear out, and as a rule are not user serviceable.
Can you adjust it? Good question!
Can you adjust it so it works? Ahah!
My rule of thumb: If it's already broken, how much more broken can it get?
Therefore, my conclusion is that the toilet seat's slow-close mechanism is factory set at the point where it will neither slam down nor stop half-way, but glide down gently until it's closed.
An interesting added feature would be for the toilet to recognise who's about to use it, and for what, select the seat position be it up or down, and then regulate the water volume needed to flush.
Also, it could flush itself once the lid is fully closed, to avoid or minimize the dreaded "toilet flush mist". arrrghhh!!!
Posted on Jul 04, 2011
Coco 9500R bidet seat makes loud noise when you sit down,could this be the heater?
sorry but never heard of a heated toilet (biddet ) seat
Feb 07, 2017 | Home
How do I remove toilet seat?Appears to be 2 bolts with top access only.
rak soft close toilet seat - YouTube
? 0:31
https://www.youtube.com/watch?v=RLssM9BYJjg
Oct 9, 2013 - Uploaded by Paul Hooker
rak soft close toilet seat. ... How to remove and change a Villeroy & Boch toilet seat with top fixings ...
Rak Series 600 Back To Wall Toilet - YouTube
Nov 29, 2015 | Home
Self closing all in one tolet seat boxed, hidden screws, how to tighten
If you are trying to install a standard toilet seat on a special "smooth sides" toilet, it likely will not work. Most hidden bolt toilets come with a special seat because you cannot get to anything from below. This special seat has a set of expanding style bolts that are attached to the screw that is part of the seat. The plastic expanding bolt goes into the hole(s) on the toilet, and as you tighten the screw on the toilet seat bolts, they expand the plastic part in the hole of the ceramic toilet.
Aug 29, 2013 | Kohler 3386-6 Rialto Skylight Round Front...
After flushing flusmate toilet a very loud siren-like sound occurs.
Try changing the opening of the water valve that feeds the toilet... just open the valve a little bit, try again, if noise is still there try closing it a bit... the noise is probably from the water valve vibrating and changing the position often will eliminate it. The valve should be obvious, it's what the water supply line from the toilet connects to.
Jun 26, 2011 | Home
Toilet drains to a certain level every half hour then refills with a sqeaky noise,when flused it makes a very loud sqeaky noise.
May need to replace toilet flapper or entire flush valve. water is getting from the tank into the toilet which is causing this to happen.
Aug 31, 2010 | Toto Aquia II Dual Flush Toilet
My toilet seat is loose but there are no visible external securing parts. Its a Banyo suite with gentle self closing lid mechanism. How can I tighten it up and secure it back in place?
where the hinges sit, use a small screwdriver and prise off the top chrome cover.Under neath are the securing screws for the seat. tighten these carefully until seat is secure, then replace the covers.
May 13, 2010 | Home
We just installed a new one piece toilet from Neptune. It makes a loud noise when you flush it and after the water fills up. In addition, if you flush another toilet or turn on the washing machine it also...
Hello. I doubt that the installer would not install it properly. That said, the issue you are having makes me wonder if your bath drain plumbing is properly vented to the outdoors through the roof. Joe
May 07, 2010 | Neptune FB1602 Roma Elongated Front Toilet
Noisy fill valve
You may have higher than normal water pressure. Try closing the the cutoff valve on the wall half way and see if that helps. You can experiment with it till you find the best position. You can get a pressure gauge that will attach to a hose bib for a few dollars to see if the pressure is too high (more than 80 psi is too high). If it is too high you can have a plumber install a pressure breaker on the line where it enters the house.
Apr 02, 2010 | Toto C743s-03 Drake Ound Toilet Bowl Only...
Kohler Toilet Seat - Elongated Front Quiet Close Quick Release - Cachet by Logo
216 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
