Question about Canon Optura 30 Mini DV Digital Camcorder
Canon optura 30 not ejecting tape
I have a canon optura 30. the tape will not eject. when i open the door, the tape rises up as it does when it gets ready to eject, but before it ejects it stalls out and then goes back down again. i replaced the battery with a new one. i have tried ejecting the tape with battery power as well as with the camera plugged into the charger
  • neonchrome Jan 10, 2009
    i can't see if the tape is clean as it won't eject at all.
  • neonchrome Mar 29, 2009
    i managed to get it to rewind all the way, but still no luck. the mechanism begins to eject but stalls out before pushing out the tape.
  • 1,031 Answers
You have to to rewind them all the way. If you rewind them fully they eject If not, they stick.
Hopefully it will eject
Posted on Jan 10, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
My guess is that the tape got wrapped around the capstan shaft so it can't be pulled back into the cassette so that it can be ejected. You will have to disassemble part of the camcorder and manually unwind the tape from around the shaft. Before working on it have a well lit work surface and use some good small tools.
Thanks
Rylee
  • 1 more comment
  • Rylee Smith
    Rylee Smith Jan 10, 2009
    Hi!
    Thanks
    Rylee
  • Rylee Smith
    Hi!
    If its happening too often then might be a sign that the slip clutch on the take-up spool is slipping to soon i.e the clutch slips before it can eject the tape out maybe due to a foreign object or tape label came loose and is stuck inside.
  • Rylee Smith
    Try to FF and RW the tapes so that if they are stuck tape would lossen up and come out.
    President:
  • 2,110 Answers
Ensure that the cassette is "squeaky clean" before placing it in the camera. Even almost invisble specks of fluff will jam the whole eject mechanism.
Tape won't eject on Canon Optura 20 MiniDV. About
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jul 30, 2011 | Canon Optura 20 Mini DV Digital Camcorder
DV tape won't eject from Canon Optura 20. Power on, screen flashes "eject". Battery is fine. Tape comes up but won't release.
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
Dec 18, 2010 | Canon Optura 60 Mini DV Digital Camcorder
I connected to AC and recharged, turned on and got...
yes thats is an easy problem to fix..
no parts need to be fix
this is a mechanism problem
from here thats all i can say i did not see the camera
and heaven if i want to its impossible
hope that will help
regards Alan.
May 20, 2010 | Canon Optura Pi Mini DV Digital Camcorder
Optura Pi Mini DV Digital Camcorder: I connected to AC and recharged, turned on and got...
yes i think; if you can find a good tech he should be able to make the mechanism alignement and clean out debris could be in the mechanism but he can charge you more because its as been open..
and clean the mode switch all that can be done with out parts replacing beleive me i know! because i fix a lot of camera and cam corder
hope that will help you..
regards Alan...
May 18, 2010 | Canon Optura Pi Mini DV Digital Camcorder
Will not eject mini dv tape
I had the same problem. I cycled through the eject process until it finally gave me back my tape. I had to send it back to have the tape carriage replaced
May 03, 2010 | Canon Optura 20 Mini DV Digital Camcorder
Eject mechanism not functioning
Once when this happened to me, I took it to a repair shop and they said it just needed to be cleaned. (Optura PI tape won't eject)
    Dec 28, 2009 | Canon Optura Pi Mini DV Digital Camcorder
    Reads "eject tape" or "remove tape"
    Theres been a failure in the drive system for the tape. Probably mechanical, so you woul need to take it in to get fixed.
    A few times I've been able to resolve this by blowing compressed air in the frame and cleaning the head (if u can get to it)
    Aug 26, 2009 | Canon Optura 20 Mini DV Digital Camcorder
    Tape Eject Problem
    I have the same camera and it just did the same thing.  Can't open it and its jammed.  Hope you find an answer, but my answer was to go out and buy a JVC 850 at Circuit City for 200 bucks.
    May 31, 2008 | Video Cameras
    Tape deck won't eject tape
    The tape might be wrapped around the head or the capstan. The mechanism is delicate so you risk more damage by trying yourself - check with some of the repair shops on the Fixya home page for prices to remove the tape.
    Dec 17, 2006 | Canon ZR10 Mini DV Digital Camcorder
    Cassette Jam
    The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
    Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
    Canon Optura 30 Mini DV Digital Camcorder Logo
    298 people viewed this question
    Top Canon Video Cameras Experts
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Steve Mason
    Are you a Canon Video Camera Expert? Answer questions, earn points and help others
