Question about Avital Vehicle Parts & Accessories
Car cranks but won't start with avital 7111l remote starter
ltfrc
  • 227 Answers
SOURCE: engine cranks will start fine with key remote will not start it
Did it ever work as far as you Know? Some vehicles have a coded key and if the key is not in the ignition at the time the remote is activated it will not start. Some systems have a key hidden in the system and some have a bypass. It is hard for me to tell you which you have as not being the installer. You may have to contact Avital or go to thier web site for more detailed info.
Posted on Jan 28, 2009
ltfrc
  • 227 Answers
SOURCE: cranks but engine doesn't start avital remote start
I beleive it is a pink wire for the ignition. If you can locate where it is connected this is your ignition wire. It may have worked loose under the dash.
jpk528
  • 95 Answers
SOURCE: I have a 1998 Chevy cavalier with Avital 3200
it sounds like its the bypass module. When it doesnt start the car goes into security mode and wont let it start for up to 15 minutes. I would check the bypass module to see if it still has power or has been reset, if its not something you can do, bring it to a local mobile electronics shop and they should be able to take care of it for ya.
Posted on Mar 03, 2009
  • 171 Answers
SOURCE: AVITAL 4103 REMOTE STARTER STARTS BY ITS SELF
Check the alarm program it shoudl be programing to turns it On every 2 hours, or if you have a temperature sensor should be programed to turns it On when is too cold.
Posted on Jan 05, 2010
  • 151 Answers
SOURCE: my viper remote starter cranks engine but car
Did you connect the tach wire of the unit to your car? if not you need to refer to your documentation to turn on or off the tachless operation for the unit to work correctly.
Posted on Jan 13, 2010
2002 cavalier, ignition cylinder was changed for pass lock failure now remote start cranks but wont start. avital 4103L
Hi, ur problem is a simple one. U have a factory alarm-starter kill. The key and ecm have to comunicate. Ur alarm has a digital modual to make the ecm think its seeing the key when u remote start. Since u changed the "code"u have to reprogram your alarm interphase so it all comunicates the code.
Nov 28, 2015 | 4103LX Remote Start System with Two...
How can I get instrction book for reprograming avital remote starter for rpn 7111l
If you are looking to sync the remote key fob to the remote starter:
Remote programming 1. Turn key to the ON position 2. Within 5 seconds, press and release Valet button one time. 3. Within 5 seconds, press and hold the Valet button. The LED will flash one time and the horn honks to confirm entry into remote programming. 4. Press the button on the remote control. 5. The horn honks to confirm the remote has been programmed. 6. Release the Valet button, and turn the key to the Off position. 7. The horn sounds one long honk to confirm that remote programming has been exited. The programming routine exits if any of the following occurs: • The ignition is turned off • There is no activity for 30 seconds • The Valet button is pressed too many times
Mar 01, 2015 | Avital Vehicle Parts & Accessories
Avital 5303 kills engine while driving 1998 honda civic
you check to see if the engine was hot or something like if the water level in the radiator was down the sensors in the security system would pick it up
Jan 27, 2014 | 5303L 2Way LCD Remote Start Security...
Avital 473L TX will start and keep the starter engaged
Sounds like the ignition or accessory output from the remote starter is connected to the starter wire. Has it always done this?
Mar 06, 2013 | Avital Vehicle Parts & Accessories
Alarm keeps turning on when I turn on my car starter
Okay, the Avital 4111 is a one button remote starter. So, it has no way of locking your car doors except if wired to lock after start or, after shut down. In the 2010 CRV, the unit should have been wired to disarm the alarm before start(brown wire in kick panel) and to unlock doors when running (grey wire in kick panel in same harness as disarm) with the press and release of the remote starter remote. If the unit is not working in cold weather it may be due to the installer using a valet key instead of a bypass and/or the unit may be programmed for virtual tachometer or voltage instead of having a true tachometer wire connected.
Jan 25, 2013 | Avital Vehicle Parts & Accessories
Doorlock operation won't work on new Avital 4103. Why? 1990Buick LeSabre
The door locks on the car are reverse polarity so u have to put realys in between the system and the door lock
Oct 21, 2012 | 4103LX 4Button Remote Start System with...
Last Year I installed an AVITAL5103 Remote start & Security on My 2002 DODGE RAM 1500 Q.Cab.Everything was working fine,util I instal a new car battery.When I attempt to remote stert ,the starter cra
There are two types of starters for Dodge, if you installed new battery, check to see if the remote start is to ignition module or starter solenoid, then make sure the circuit has not been closed-they go in series circuit!
Nov 29, 2011 | 5103L Security/Remote Start System
How do i reset my remote start car alarm avital 5303
i have a avital 7352l remote start my fob got smashed under the hood of my car still locks and unlocks car but went to use remote start and it tried to start car but it didnt then i got into my car and try to use my key and it didnt crank at all can anyone help me solve this problem?
Feb 21, 2011 | 5303L Security/Remote Start System
Vehicle Parts & Accessories Logo
32 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Colin Stickland
Colin Stickland
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
