Burner will not lite.
It will light and burn with the top cover off but will not burn with the cover on. What is causing this?
  • kiddboy66 Jan 11, 2009
    The air flow is good. I even changed all of the filters as well.
  • 61 Answers
Sounds like a problem with air getting to the burner. Make sure the fan is clean and there are no obstructions to the air flow.
Hope this helps.
Matt
Posted on Jan 10, 2009
Not light
check to make sure that the poilet lite flame is touching the tip or top of the thermocouple.
the pilot lite needs to heat up the thermocouple so that the thermocouple opens the gas to the main gas log. a cold thermocouple shuts off the gas to the main gas log or gas burner and a hot thermocouple opens the gas to the main burner.
the pilot lite flame must be touching the thermocouple to heat it up.
pilot lite orface needs to be clear to let the pilot flame gas through with enough pressure so that the little flame can reach & touch the thermocouple. Pilot lite gas feed tube must be clear to let gas through. Use compressed air or a fine sewing needle, or even carb cleaner to clear out orface hole and gas feed line to pilot lite.
important!! WARNING:
if you use carb cleaner,make sure all the carb cleaner is dry,soaked up with paper towell or kleanex tissue and blowed out with compressed air , because carb cleaner can burn just like gasoline; so any carb cleaner must be compleatly gone before you attempt to lite the pilot lite.
May 20, 2013 | Lite On Laars Lite 2 Heaters: 250,000BTU...
How can i make my Lite-on-SOHR-5238s CD-RW burner read and burn stuff on a DVD+R/DVD-R? Cause when i put it in my computer doesnt recognize it.
Hi Justin If it's a CD-RW burner then you can't burn any DVDs in it. You need to get a DVD burner instead - they are very cheap now.
Jul 14, 2011 | Lite On SOHR-5238S CD-RW Burner
1 IGNITER ON MY FRIGIDAIRE STOVE TOP SNAPS BUT DOES NOT LITE I DO HAVE GAS PRESENT
If the other burners are working and you hear gas and the sparking working, the burner may be clogged. This happened to me when some soup boiled over one time. Try lighting it manually. i.e. Hold a lighter, preferably one with long stem, while slowly turning on the burner. If the burner is clogged, you may need to hold the lighter in different places. If this succeeds, let it burn for a couple minutes and this may clear the burner. If it still doesn't work you will need to clean the burner. Most of the time the front and back burners share a sparker. Good luck and let us know how if this has sparked a solution.
Mar 27, 2011 | Frigidaire Kitchen Ranges
I am scared to death of gas grills -- nearly burned my hair and eyebrows off years ago -- husband always lights it -- he's out of town -- how do I light a Weber gas grill?
Be sure your outdoors in the open. Be sure that the cover is off. Use a large match stick (fire place)or a butane grill lighter to burn the gas. Place the lite match/lighter to the burner head and open the gas bottle. After 6 seconds, If the burner head does not light shut the gas bottle off. Try again till it lights.
Aug 15, 2010 | Weber Gas Go-Anywhere Grill
Heater wont lite
It sounds like you are having an airflow problem since it lights fine with the cover off. You need to adjust the airflow the burner or look for some type of obstruction.
Apr 04, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dvd burner won't burn!
do you still have the software for your external dvd...if so...uninstall it....now start all over like it is brand new...reinstall and reconnect the dvd....this shoud do the trick...
FYI
all dvd movie take 2-3 hrs to burn (some even 4 hrs..depends on the lenght)...and for the future never just turn off any data transfering devices....not even your pc when windows is updating....
May 25, 2009 | Lite On LITEON USB 2.0 EXTERNAL 52X32X52...
Burner doesn't lite up
I must assume that the unit uses manual controls for the burners.....if the orifice feeding the burner is plugged (some sort of spill) the gas will not reach the burner for it to light. If it is just one burner, I would investigate a plugged orifice feeding that burner.....if it is all the top burners, there may be a supply problem. let me know what you find.
clarkco
May 09, 2009 | Kitchen Ranges
Oven & broiler not working
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Jun 28, 2008 | Hotpoint RGB528 Gas Kitchen Range
The right front burner won't heat
The switch probably failed. Remove power. Take off the top rear cover and inspect the switch for signs of discoloration (burned or brown areas). If looks OK then maybe the element failed.
May 28, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
My LITE-ON DVDRW LH-20A1H thinks its a cd burner???
It seems Lite-on Has a lot of Probs.In fact I had the same model on an SATA system.It would not burn dvd's or cd's.You can try updating your burning software,and reinstalling the drive through device manager.I actually ended up buying an LG burner....lo-and behold...it works without any problems.Good luck
Feb 12, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
