Question about Epson Stylus CX6000 All-In-One InkJet Printer
Paper feeds crooked
My CX6000 has a problem with the paper feeding crooked. A good 1/8 to 1/4 inch difference from top to bottom.
  • KLD2 Jan 22, 2009
    I have the same damn problem! It infuriates me...this must be a problem with these...I fixed it for a while, and now it's doing it again. I forget what I did to fix it, but I know it involved a lot of hitting. Anyway, it's doing it again months later...
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 22, 2009
Hp deskjet 3512 feeds paper in crooked
Hello, Vicki -
I found a HP discussion board where someone posted the same question, but for a different model HP printer. See all the replies here:
https://h30434.www3.hp.com/t5/Inkjet-Printing/Paper-feeding-in-crooked/td-p/6334779
Best wishes.
Jan 15, 2018 | HP Office Equipment & Supplies
Paper is pulled through crooked printing is not straight. how doyou clean the rollers?
This can be caused by several factors. It could be that there's something(like small foreign objects in the paper feed area) causing the paper to get crooked. It can also be caused by improperly adjusted paper guide or the paper is not in good condition.
Paper Feed Rollers Are Rolling But the Paper Is Not Feeding
How the Accu-feed Paper System Works
Mar 23, 2011 | Lexmark X75 All-In-One InkJet Printer
My printer feeds the paper crooked and causes a jam
Cleaning the internal rollers may fix it, if not a new one is required.
Mar 01, 2011 | Computers & Internet
My Konica Minolta bizhub C250 seems prints about every 10th page crinkled and crooked. I can hear it going through the machine and crushing a crease in the paper as it prints. The printed also seems to...
The paper may not be feeding straight out of the paper tray due to poor stacking of the paper in the paper cassette. try another paper tray or check the paper in the paper tray for folded over papers usually near the bottom. Also try feeding paper from the hand feed tray on the left side. This uses a different paper path.
Dec 07, 2010 | Konica Minolta bizhub C250 All-In-One...
Paper feeds crooked then jams?Used less paper different paper it just pulls the paper in unevenly the jams. Help
Check feed roller for contamination, fan the paper to seperate sheets and then make sure that you are using paper of the following standard:
Paper Type Thickness Weight Single sheets
(plain paper) 0.003 to 0.004 inch
(0.08 to 0.11 mm) 17 to 24 lb
(64 to 90 g/m²)
Make sure you are using paper supports and feed guides.
Apr 09, 2010 | Epson Stylus CX9400 Photo Printer
Print wedding announcements and the print is not straight
Card stock on an HP can be a nuisance, due to the paper feed path. The stock has to curl around the platen.
Some things to check: Make sure you are telling the print driver you are using card stock. It should be in the printing preferences as paper type. The printer will respond differently, knowing it has the heavier paper. Also make sure that your paper guides are adjusted to fit the smaller stock. Just putting in 5.5 x 8.5 paper into an 8.5 x 11 tray may cause it to skew.
I am assuming that you are already telling it to print high quality, as it is for a wedding announcement, but make sure that you are. Slowing down the paper feed speed by putting it into high quality mode can help.
Your printer is an older model, so it could be that the rollers are wearing down, and it just can't feed the last bit as well. You could try to print it in "landscape" mode. Turn the paper 90 degrees in the paper tray, so that the 8.5" is the feed side. This will allow the printer to have a better grip on the paper as it goes through. A word of caution with this method, though. HP's have a 1/2 inch margin at the bottom of the paper where it can't print. Turning the paper 90 degrees will force you to have a side margin of 1/2 inch. Currently, your bottom margin has to be 1/2 inch. I don't know what your layout looks like, so I don't know if you can turn the paper.
If you are the one getting married, the congratulations, good luck, and mazel tov! (Have to cover all the basis).
Jul 17, 2009 | HP DeskJet 5550 InkJet Printer
Paper feeding crooked and jamming in my Canon IP6600D printer.
Try doing a thorough cleaning of all the rollers in paper path making sure that there also no scraps or obstructions in the path.
Aug 31, 2017 | Canon Pixma iP6600D InkJet Photo Printer
Paper feeds through crooked and comes out crunched
Make sure the blue slide device on the left side of the paper holder is tight against the paper. If not, the paper will feed corrked.
May 29, 2008 | Epson Stylus Color 740 InkJet Printer
Printing is crooked
if paper comes out straight, and lines in paper are not straight then there is problem wit laser unit, its not installed corrrectly, also you can check drum unit and transfer belt for correct installation.
Apr 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
267 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
