Question about Maytag PGR5710 Performa Gas Kitchen Range
All orange flames
After 4 hours, and replacing everything from the gas tank in, we are still left with orange flames on all four burners and the oven. The technician was obviously perplexed as he had checked from top to bottom. This is going to be an expensive problem. The pressure is exact and there is no reason for this issue. Can anyone solve this on a 2 year old stove. Model # MGR 4451BDB. Help....
  • 6 more comments
  • kathil17 Jan 10, 2009
    We bought the stove brand new 2 years ago....it was already converted from natural gas to propane. We live in Maine and, yes, it has been quite cold. Have not had this issue before as it has been very cold the last few years. Had the tank, regulator, and line from tank to stove all replaced yesterday. Didn't help. There is no obvious reason for this to happen. Next solution.
    More info: We have checked all ports and orifices. Everything fine. We have perfect pressure coming in. We have had the finish regulator checked and it is fine. The technician even went as far as hooking his propane torch directly in and it still burned orange. Adjusting shutters was not the issue. So, if any other suggestions are out there. This is one that has most stumped.
    You may send the 'hopeful' fix to my email address. I have replied to the email sent from my hotmail address. You should have it. I don't want to post that on here.
  • kathil17 Jan 11, 2009
    From what I could gather you should be lucienemaric. Is this correct?
    I wanted to ask before I responded. Let me know.
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    No, I am MNTECH. (from the land of ice and snow, Minnesota Technician)
    I won't get that "replied to" email. I suggest that you use the "Ask Me" feature to send a personal response. If you click on my user name the "Ask Me" bar should come up, or you can use the "find experts", then switch at the top to sort by rating, and I'll be on the fourth page and the "Ask Me" should show up there.
    I may have an explaination for your issue. We are not suppose to ask for email addresses, but I'd like to send you some info which would be rather long to retype here.
    Is this range using LP gas? What were the outdoor temps before and when this condition occured? What area of the country are you in?
  • 3 Answers
 mine was humidifier, orange flame is minerals in the water.
Posted on Feb 08, 2009
  • thisismehlt Jan 23, 2011
    We have been trying to "fix" the orange flame situation on our gas stove (we use propane) for over 2 years. It only happens during the cold winter months. Finally a very knowledgeable service tech solved the mystery: It is due to our humidifier. When we turn the humidifier on, we get the orange flame. When we turn it off, the flame is blue. Why does this happen?
  • William Krems
    William Krems Feb 27, 2016
    Color of flame a mineral produces. calcium an orange flame. Humidifier puts water in the air, air with a lot of calcium burns orange.
    Problem Solver:
  • 7 Answers
You say the stove is 2 years old, but is it new to you? i.e. Is it just now being installed at you home, or has it already been there for two years?
My first guess at this poblem would make sense if the stove is just now being installed in your home for the first time. There are jets in the control valves that are different based on whether you use natural gas or propane, which are delivered at different pressures. Normally you would see something like the issue you are seeing if a stove is equipped with propane jets but natural gas is being used (or vice versa). If this is actually the problem, then it is easily and inexpensively fixed by changing the jets.
Posted on Jan 10, 2009
1 burner of 4 does not get enough gas to work properly
The burner probably hes plugged holes for the gas to get through.
You can clean them out with a tooth pick or paper clip.
Feb 17, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
I have a 3 burner CaptnCook gas grill. The middle burner has a single flame when I try to light but does not light the whole burner row, just right at the front only. The right and left will not light at...
The problem lies with the grill's regulator and how the gas tank valve was opened.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Thanks for choosing FixYa.
Aug 23, 2011 | Barbeques Galore Capt'n Cook 3-Burner...
I have a charbroil commercial gas grill that won't ignite. I have a full tank of propane.....
Hello, here is my check list for your most common gas grill lighting problems:
1) Check your tank. Is it empty or nearly empty? The tare weight (T.W.) of your cylinder is stamped on the collar. This is the weight of your empty cylinder, usually around 18 lbs. Weigh it on your bathroom scale2_bing.gif. Propane weighs 4.25 lbs/gal. If it weighs around 20 lbs or less - Refill it. If not, go to #2.
2) Make sure you didn't turn the gas tank valve on too fast. Some gas hoses have a built-in excess flow valve that stops the flow of gas to a trickle if opened too fast. Close the tank valve, disconnect it and reconnect it. Turn the tank valve back on very slowly and then try lighting it again. Make sure all your grill gas knobs are turned to off when you turn on the tank valve and that you only light 1 burner at a time. If it doesn't help, go to #3.
3) Is the igniter sparking? Some are battery2_bing.gif powered-check the battery or replace it. If you have a standard push button piezzo igniter or a rotary style2_bing.gif igniter, check for spark. Can you hear or see the spark? It's hard to see the spark in bright daylight. It's easier to view the spark at dusk or dawn. It should spark an "arc" at the burner. If not, adjust it if necessary. The igniter wire may have a short, causing the spark to arc somewhere else along the wire and not at the burner. Replace igniter wire. It's also possible the igniter tip where it sparks has a cracked or broken porcelain portion of the igniter, causing the spark to not arc at the tip where it's supposed to. Replace the igniter piece. If not, go to #4.
4) You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening (on the end of the burner's venturi tube) has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the burner holes are not allowing very much gas through anymore. It's also possible the burner has rusted so bad, the burner holes have been enlarged, it is falling apart or has cracks along the burner seams. If so, replace the burner(s) immediately. It is unsafe to use. Your local propane co can usually order the parts you need and some will even do the work, if you are uncomfortable doing it yourself. Bring with you the Make, Model and Serial number of the grill, so they can order the correct parts for your specific grill. Also specify whether it's natural gas2_bing.gif or propane.
5) If none of these resolve the issues you are having, it is also possible you have a faulty or defective regulator, which may mean replacement. If the pressure still seems too low and none of the above has helped, and you have a silver/gray regulator; many have an adjustment screw on the top center of the diaphragm. Remove the outer cap and turn the inside screw clockwise in 1/4 turns to increase the pressure until the desired flame size is accomplished. Flames should be as blue as possible, but will burn orange if there is food or drippings on it. Yellow flames are not good, and will soot up everything and not cook as hot as blue flames do. Yellow flames could mean you do not have the right air shutter adjustment, clogged burners, or possibly defective burners, as mentioned above in #4.
6) Also make sure you have the hose connection tightened snugly to the propane tank valve to ensure the inner valve seat is fully depressed allowing gas to exit fully without any restriction. The black plastic female fitting should be hand tightened only. Older versions that use a left-hand male brass POL valve, requires a 7/8 open end wrench or adjustable wrench to tighten.
Hope this helps! Good luck in your trouble shooting! Douglas
Jun 08, 2010 | Char-Broil CharBroil Master Flame Gas...
Burner flames don't get hot, like not enough gas.
Try this, Turn off the tank. Disconnect it. Reconnect it. Turn tank valve back on very slowly and then see if you get bigger flame size.
May 15, 2010 | Weber Genesis Silver B Grill
I have a Kenmore 4 burner grill that I purchased about 3-4 weeks ago. 3 of the 4 burners have nice blue flames and work very well but the left middle burner gets a huge yellow flame no matter what temp it...
does the same burner flame turn blue if other burners decreast in flow-with that burner on high and others low-is it still yellow? if so Gas Valve needs to be replaced.
Oct 05, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
BBQ Galore Capt'n Cook 4 burner gas grill won't get hot.
Most modern gas regulators have a safety feature to prevent gas left on. If you shut off the tank first and then turn off the burners, it will trigger and keep the gas flow at a very reduce flow to prevent you from turning on the tank again with the burners left on and not realizing it. Turn everything off and then turn on tank first, followed by the burners and this will solve most problems of a low flame or a bbq that won't get hot.
Dec 05, 2008 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Maytag PGR5710 Performa Gas Kitchen Range Logo
535 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
