Question about LG Refrigerators
Fridge is leaking water
The proper "name" of the fridge is: LG GR-S642AQ IceBeam Smart Fridge. It is a563 Litre fridge, with the freezer compartment on top of the fridge. About a month ago water just started appearing spontaneously around the door of the fridge. I've owned it for about 5 years, and it has never done this before.
Maytag317
  • 1136 Answers
SOURCE: leaking freezer into fridge
Hi, What has happened is that the drain hole in the freezer has frozen up and the defrost water is dripping into the fresh food area.
Remove the floor panel and the rear fan cover in the freezer and you see the ice that is blocking the drain.
Be carefull when removing the ice. DO NOT use a sharp object. The best way is to use a hair dryer.
Once you locate the drain hole, you will need to melt the ice down in the drain hole too. For this, you can use the hair dryer or poor a few glasses of hot water (sopping up the water between each glass).
What you will need to do after the drain is open is to put an after market drain heat transfer kit on to prevent this from reaccuring.
Please let me know if this is the case and I can get you the right part# or even send you the part.
Thakns
Vic
Posted on May 15, 2009
carputers
  • 255 Answers
SOURCE: lg ICEBEAM GRS512GC. Freezer cooling but fridge
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Posted on Sep 24, 2009
  • 4 Answers
SOURCE: LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Posted on Jan 16, 2011
SOURCE: LG Fridge Icebeam Door Cooling
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Posted on Feb 12, 2011
  • 257 Answers
SOURCE: Ever since I've owned my
Your defrost thermostat is broken and needs to be replaced. Here is a link.. your freezer is located differently but you can still use this video. http://www.youtube.com/watch?v=mQS3pNQFXAo&feature=related
Posted on May 11, 2011
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
Lg express cool turbo gr-t452gva water build up in fridge
Drain pipe is in the freezer below where the fan(s) are. You may need to take a cover off to get to it.
Mar 20, 2013 | Refrigerators
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
Water on floor
I had this problem with our 2 door frost-free LG fridge (model GR-B207EC). Perhaps you also notice a regular ice buildup in the bottom of the freezer compartment?
My solution was to switch off the fridge and unplug it from the wall, unload the freezer compartment and remove the white plastic back panel inside the freezer compartment. The panel has arrows marked around the edges where the catches are that hold it in place. Carefully flex out the panel at the catches using a large flat blade screwdriver if necessary. Ice buildup can make removal of this panel more difficult.
Behind this back panel is a condenser, under which is a silver tray, which is designed to catch the drops which fall from the condensor (this is the 'frost-free' part of the fridge). I found mine solidly frozen with ice and used a low-heat setting on a heat gun to melt the ice. In the absence of a heat gun a hair dryer will work fine, but don't melt the plastic components of the fridge. (It is also unadvisable to chip away ice with a knife of other sharp implement as you can easily slip and damage yourself or the fridge).
After fully defrosting the tray (this will take some time), including the drain hole in the base of the tray (pour a small amount of warm water in the tray and make sure it drains readily), reassemble the fridge components and restock your fridge. Remember to plug it back in and switch it on.
No more water leaks.
As an alternative to this fix ... if you have the luxury of being able to transfer the contents of your fridge to another fridge and not have to use the leaky one for a while ... empty the fridge and freezer, unplug it from the wall, leave the doors open for a week in a warm location. I didn't use this method but I reckon a week would be long enough to defrost the ice buildup behind the back panel of the freezer and allow the water to drain, yielding the same result.
Feb 28, 2010 | LG Refrigerators
LG ICEBEAM GRS512GC. Freezer cooling but fridge not cooling. Just had tech replacee fridge pcb with no sucess... any suggestions? thanks in advance :)
Sep 23, 2009 | Refrigerators
Apr 08, 2009 | LG Refrigerators
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
Lg fridge freezer model gr-s352gca fault
Buy another brand. LG are cheap and nasty when it comes to whitegoods even though the price tag is still up there. I have done nothing but research for my next fridge and i might go with the same brand as i have had for the past ten years and have not had a single problem.(it is definately not a LG of Samsung or one of these other brands that have all the advertising and have only been around for a little while)
Jun 01, 2008 | Refrigerators
Refrigerators Logo
20 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
