Question about Miller 907428 Big Blue 350 Pipe Pro
I have a miller 350 pipe pro with a c1.5t cat engine what temp should it be running at when in high idol
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: Miller Pro 350D and the exhaust flex pipe needed
Hi Kyle. Welcome to FixYa. I am Kelly.
You will have to go to this link...
http://www.millerwelds.com/service/ownersmanuals.php
WITH your
Model Number ____________________
AND
Serial Number _____________________
Then download your owners manual (Wildcat 350D I think)
Look up your part number in that manual
And then
http://www.millerwelds.com/wheretobuy/
Enter your postal code.... and that should find your local dealer.
Thanks for using FixYa!
Kelly
Posted on Feb 23, 2010
My welding machine will not idol down .Only stays in high idol. Why won't my machine idol back down when not welding? Yes I have the switch on run / idol lol 225 bobcat miller Kohler engine
Possibly the idler control circuit board. I changed out my fair share back when I worked on them. Also, check your idler solenoid. I can't remember if those pulled in to idle, or pulled in for high RPM's. May be something as simple as rust on the solenoid plunger.
Dec 15, 2014 | Welding Tools
My welding machine will not idol down. Only stays in high idol . Why won't my machine idol back down when not welding? Yes I have the switch on run /idol lol 225 bobcat miller Kohler engine
put 12 volts to the coil and see if it pulls in. Could be coil, idle module, ignition switch, or wiring. Get a 12v test light and trace it.
I replaced all 4 of my oxygen sensors and my check engine light came back on and i went to get the car check out and i was told that its still my oxygen sensors what else might it be?
The catalytic converter may be no good. The reason for multiple O2 sensors is to measure the the catalytic converters performance. The easiest way to determine if the cat is working properly is to measure the temperature on both sides of the cat. The temp going in should be approximately 100 deg less then what's coming out of the cat. So if the temp is 250* going in to the catalytic converter, it should be about 350* coming out. the best way to measure the temp is to use a laser pointer temp gauge. If the temperature is the same on both ends, I recommend replacing the catalytic converter.
Mar 04, 2013 | 2004 Mercury Marauder
I have 1993 pontiac bonnevile, it will not pass emissions the nox levels are to high this is the fourth try. what can i do. also my check engine light comes on as well.
high NOX indicates your engine is running high combustion temps. Two of the major reasons for lean mixtures are intake leaks and clogged fuel injectors. The reason the engine computer cycles between rich/lean when running is because the cat needs lean mixtures to deal with HC and CO and a rich mixture to deal with NOX. If you are running lean the cat can't lower your NOX. I would first get your fuel injectors flushed and de-carbonize your intake/combustion chambers.
May 31, 2011 | 1997 Pontiac Bonneville
Engine dies when start switch is released on miller trailblazer pro350d
TRY REPLACING KEY SWITCH.
MAKES CONTACT ON START POSITION BUT NOT IN RUN POSITION.
Oct 30, 2010 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
you can buy flex hose at auto parts stores and fashion your own bends to replace the bad one
Feb 23, 2010 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
91 GMC G2500 5.7L 350 Stalling when warm
You should try looking at the transmission fluide, it must be short. If it is, you should go buy a transmission fluid. And make sure you car pipes has no leak.
Jan 11, 2010 | GMC G2500 Cars & Trucks
Have 2003 Nissan Pathfinder. Engine rattles under acceleration.
I would have to hear it. may be the engine mounts.
Nov 27, 2009 | 2005 Nissan Pathfinder
D1105 kubota engine on generator overheating
Can you tell if it's really hot (water temp) ? Could be a bad sensor.
Jun 23, 2009 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Cooling problem on 1997 deville
Get an engine analyzer that is capable of sniffing and measuring exhaust gases ( can be read in the overflow container ) Looking for excessive exhaust gases indicating leaking head gasket or cracked head. I would consider a cooling system flush. Sometimes an excessive amount of GM sealing tabs used in previous repairs will cause poor circulation and high temps, as well as phyical blockage of cooling fins on the radiator. Hope this helps.
Apr 26, 2009 | 1997 Cadillac DeVille
Miller 907428 Big Blue 350 Pipe Pro Logo
19 people viewed this question
Top Miller Electrical Supplies Experts
littlewheel
Level 1 Expert
Lawrence Oravetz
jeff5may32
Are you a Miller Electrical Supply Expert? Answer questions, earn points and help others
