Question about Sony UP-960 Thermal Photo Printer
Sony UP960 door will not stay closed
Sony UP960 printer seems to cycle and door opens,close it and it repeats itself,door will not remain closed if unit is on.
    New Friend:
  • 30 Answers
Its either a gear problem or a bad sensor.
20 year experience working on Sony medical Products.
Posted on Aug 08, 2014
Garage opener try to close door when door at close position
There are upper and lower limit settings, it sounds like you have the lower limit set to low. Adjust it so it stops the door as it contacts the floor and see if this solves the problem. It is possible these limit controls are damaged and will not stay set. If that is the case it may be best to replace the opener if you cannot find a replacement.
Apr 06, 2014 | liftmaster Chamberlain Garage Door Opener...
Mazda 6 2005 driver door jammed
if you talking about door latch wont let door close.try to reset all door locks.first if you cant get door close.work unlock button with remote or door switch.then hold open door handle while you flat screw driver pull up latch in door latch should stay up so door will close.once get door close.try resetting all door locks by sitting inside vechicle with all doors close.remove key from ignition.open drivers door.wait 24 seconds.turn ignition switch on and back to lock position 3 times.press and release drivers door courtesy light 3 times.ensure doors lock and unlock.if not wait 40 seconds and repeat procedure.if this procedure fails. you have problem in the door latch and lock mechanism inside the door itself.
Jan 04, 2013 | 2004 Mazda 6 Sport
My Toyota 2001 rav4 remote light stays on it does nt open the doors alarm does not activate
The light for the keyless remote fob stays on? If so the battery may need replaced.
Here is link to a remote - LINK.IF this is yours get a battery @ your grocery store.
-open the key fob w/a flat screwdriver
-note the battery's position - is the '+' or the '-' visible?
-replace the batter the same way
-snap the cover back on
To reprogram (should also be in the Owner's manual):
1. Start with the key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Perform these steps within 5 seconds.
A. Insert the key into the ignition(Do NOT Turn) Pull key out.
B. Insert the key into the ignition(Do NOT Turn) Pull key out.
3. Perform these steps within 40 seconds.
A. Close then open the drivers door.
B. Close then open the drivers door.
C. Insert the key into the ignition(Do NOT Turn) Pull key out.
4. Perform these steps within 40 seconds.
C. Close the drivers door
D. Insert the key into ignition and leave it in ignition.
E. Turn the ignition to ON (Do NOT Start) then back to OFF.
F. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically
indicating successful entry into programming mode.
Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
locks should lock and then unlock once indicating successful programming. If
the door locks cycle twice, repeat steps A and B in step 6 as the remote was
not accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Open drivers door.
Oct 18, 2012 | Cars & Trucks
2006 Saturn, dome light turns itself on when it's parked.
The car might be "thinking" that one of the doors is ajar,
Check the spring switches in all the door frames to make sure that they are hooked properly, and doing their job. One way to do it is ( if the dome happens to be off) to close and open each door several times, to see if the bad switch stays open and turns the light on, even with the door closed
Dec 06, 2009 | 2006 Saturn ION
Have Sony cdp-c535 cd player. The door won't stay in. Keeps cycling in and out.
I had the same problem with our 5-CD Sony carousel player CDP-C535 (manufactured Nov 1993). I removed the top metal cover, and loaded five audio CDs into the carousel. After I closed the table, I pressed the carousel tight so that it stayed close, and hit the play button. The CD player tried to push the carousel out with quite a force. I needed to warp me fingers around the front panel to keep the carousel closed. After a few cycles of forcing the carousel to remain close, and caused two separate strong "clucks" from the gear area, the CD carousel became operational again. The diagnosis of gear problem seems right.
Nov 28, 2009 | Sony Audio Players & Recorders
Door won't stay up or stay closed. The door used to be pulled in so it would stay closed and remain latched. Now it slams downward when you open it and won't remain latched when you want it to run. Some...
you will need to replace the door latch, the door latches yes have sensors in them to make sure door is closed for safety reasons, also damage obviously has been doon to the hinges now too
Jun 29, 2009 | Dishwashers
Right door will not stay closed
Put vaseline on door seals
May 26, 2009 | Maytag MSD2758GEW
Door on DVD player
The drawer seems to hang up when it sits closed for a while. I found that using a very thin but rigid metal item such as a nail file under the leading edge, allows it to open with the first press of the  open/close button. I load the DVD, press the open/close button and it closes and stays shut.  After I submitted my problem, it occured to me that the reason for the door to continue to open and  close, was the repeated pressing of the button. The door was merely responding to each time it was "called."
Jan 15, 2009 | Sanyo DVW-6000 DVD Player/VCR
Whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
Oct 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Sony UP-960 Thermal Photo Printer Logo
73 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
