Question about Indesit 24 in. IDL700 Built-In Dishwasher
Indesit idl705 first cycle light flashes continuously and sound like the machine is trying to drain all the time
  • Anonymous Mar 24, 2014
    Indesit dishwashing machine typeDFG 051 S EU
    Problem: END indicator light and START/PAUSE indicator light are flashing
    ON/OFF button don't work
    Starts with draining the water but won't continue working START/PAUSE and END indicator liights are flashing
    Sergeant:
  • 236 Answers
This sounds as though it is in "flood mode" and may have a water leak into the base. unplug unit and check for leaks by tipping the dishwasher at a 45degree angle backwards and seeing if any water seeps out from the base. if it does you have a hose/ pump / seal leak.
Posted on Jun 06, 2007
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Lights keep flashing
I would check the water pump for a blockage, there could be something in the pump preventing it from doing its job as the machine cant go to the next cycle until the water has been expelled before the machine can continue eric
Jan 16, 2018 | Indesit Washing Machines
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Indesit IDl705 flashing lights 1+2 during heating cycle and will not carry on. Have checked pump and all is fine, also checked float device.
If a machine cant do what its trying to do then it wont carry on. It will just sit there.
If its doing this while its supposed to be heating then my money is on the heater being at fault.
Oct 26, 2011 | Indesit W 123 Front Load Washer
Indesit IDL 500 Pump noise when switched on not continuous, sounds like it is acting in surges, and the pre-wash indicator light flashes in time with the surges. Is this a fault, what is the solution?
this indicates that there is water in the base of the unit activating the safety float switch... usually a leak..or an overfill due to blocked filter
Power off & remove plug
1st port of call would be to drain the base by pulling forward and tipping back.. make sure you have large towels to hand...
Once drained power up again and put on quick wash...
if cycle completes verify no leak by tipping back again and no water should flow..
if there is a leak then the flashing would resume during cycle... and best get someone in to locate as there are a few possibilities...
Dec 18, 2009 | Indesit Dishwashers
Flashing star sign
Try turning off the breaker to it for a few min… and then turn it back on that might reset it.
Nov 07, 2007 | Indesit 24 in. DE73 Evolution...
IDL705 dishwasher showing error code
Indesit IDL700 first two green lights flashing and cycle stops with dirty water left in the machine. CAUSE - blocked or jammed drain pump. SOLUTION - First remove all the filters inside the machine, syphon or sponge up all the water in the sump and check for any obstruction over the fine grill at the very bottom. (we had a pistachio shell covering the hole!). If this doesn't cue it you will need to gain access to the pump. First, turn off the power. Gently lift the machine onto it's side (be ready for some water to spill out!). Remove the bottom plate (6 screws) and disconnect the sump float switch. Remove the single screw retaining the pump to the bottom of the machine and rotate to remove. You should be able to see the rotor blades. With your finger check to see if the pump rotates freely. To dismantle the pump, remove the 3 screws and separate the two halves. Our pump was jammed with an apple stalk!. Reassemble and connect any cables. Apparently this is a known problem with these machines and can be prevented by assembling the filter system correctly and pre-rinsing plates etc. before placing in the dishwasher.
Sep 19, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
INDESIT IDL705
Sounds like an water inlet valve problem
Jun 28, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit 24 in. IDL700 Built-In Dishwasher Logo
256 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
