Question about Refrigerators
Samsung side by side water dispenser not working since power out
We recently had a 3 day power outage, since then the water dispenser has not worked on our samsung side by side refrigerator
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
Does the solenoid click on the back? This would be better as a chat as there are several things to check. If you find this helpful, please rate as such or email me
Posted on Jan 10, 2009
Samsung Rs2530B frig had power outage, now cubed ice is blinking and water and ice dispensers are not working.
CONTROL BOARD ON REAR PANEL IS MOST LIKELY THE PROBLEM .THIS IS COMMON WITH STORM DAMAGE..
Apr 26, 2017 | Samsung Washing Machines
My GE Side by Side refrigerator stopped making ice and dispensing water.
Check out the solenoids and power to the water solenoids for ice maker and door water.
Aug 22, 2017 | Refrigerators
Flashing green light on control panel
Samsung refrigerator RS2530bwp
Cause: Power outage
Symptoms:
- One LED light flashing on console (in the Power Freeze section)
- Not running (not cooling, but inside lights work, ice maker not working, ice crusher doesn't work, water wont dispense)
Solution:
Press and hold for at least 10 seconds
Ice type button + Filter Reset button
Console should light up.
This is not documented *anywhere* on the web (until now). Best of luck
Aug 12, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
Ice maker makes ice but will not dispense it. water dispenser not working either.
check and make sure ur ice is not melted together. blockage can cause an issue
Jul 08, 2012 | KitchenAid Superba Architect KSCS25INSS...
Water dispenser not working. Ice dispenser works
There should be a water filter inside the water lines to the water spout. This filter could be clogged, or the water lines themselves may still be somewhat frozen and not allowing flow to the dispenser itself.
You can also test the power to the dispensor to make sure it is drawing water. Can you hear the pump trying to pump water to dispenser? The water valve should also be opening. You can test power to the valve that draws in water from the external water lines.
Nov 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Automatic ice maker quite working after 7 day power outage
Check to see if the power cable is ok. If your unit has a fuse, you may need to replace that. Looks like the power outage might have fuzzed up the power circitry. If neither of the above works, then you may need to get the machine serviced.
Sep 28, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire Icemaker not making ice.
That on/off arm...you should be able to move it and it will likely make a small click when the switch goes on or off. That arm controls the ice making. There is also a float, is it working freely? It has a switch too. Ultimately, the water is controlled by a solenoid valve. It may be defective. Many of these units are removable to test the switches with a multimeter. Turn off the water and remove to test. Some parts are available...some parts are by the unit only.
Dec 24, 2007 | Frigidaire FRS23KF7AB Side by Side...
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Problem after power outage
yes it is but is a solder one and has to be open by a skill person to check for shorts most times the spike protector is short..good luck
Jul 27, 2006 | Maytag MSD2754G Side by Side Refrigerator
Refrigerators Logo
105 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
