Question about Bose (321GS) System
BOSE 321 in Cabinet and need to mount an external IR repeater
Siliconchip
  • 52 Answers
SOURCE: bose 321 cd/dvd tray stuck closed
Please kindly check if this is d model of your 321
Posted on Jan 03, 2008
freetek
  • 5568 Answers
SOURCE: Bose 321 won't turn on
I'm amazed at the range of comments regarding this system; they range from unbridled enthusiasm to some **** words.
Before I try to help, if I am not familiar with a specific model but have a clue to what the nature of the problem might be, I research the item to see if I find some support for my suspicion.
You might keep tabs on some comments I found relating to a possible class-action lawsuit due to the array of problems that have appeared with this system.
This link will give you a sample of them:
http://www.amazon.com/Bose-DVD-Home-Entertainment-System/dp/B0002JY6SQ
Posted on Oct 17, 2008
  • 899 Answers
SOURCE: bose 321 system reads bad disc on all dvds
if will not read a laser lens cleaning disc , then it will need to be opened up and the laser lens will need to be cleaned manually with the cleaning solution and a cotton tip , but do it easy and dry the lens with the cotton tip
if that don't do it then the laser mechanism will need replacing
electech
Posted on Nov 27, 2008
SOURCE: communicating with your tv message on bose 321 series 2
Well, it seems that this may be a common issue with this BOSE unit. My 321 GSIII was working fine as well for about a week. After a full frustrating day of switching, disconnecting, reconnecting cables and resetting the unit and TV several times, I was forced to call the BOSE Technical. They tried to help with the situation over the phone by directing me to do just about everything I did before I ever called them. After about an hour of their unsuccessful help, they left me in saying that I will now have to run Composite cables because my TV will not connect for some reason through HDMI even though it was working for a short time. AHHHHH...I custom prepared the walls in my new office to accommodate non-exposed cables and wires and now BOSE is saying to expose Composite cables. Tomorrow, I am going to connect the Composite cables to confirm if the 321 will now work that way (for curiousty). I will then call BOSE back and demand a replacement unit. I will keep all in the loop with my progress of this situation.
Posted on Feb 13, 2010
No sound from bose 321
You need to localize. Play a DVD, does the same audio cutout happen? Do you have the center dvd or the left mounted dvd? The console unit has input jacks for external audio inputs, put an external audio source in and see if the same cutout occurs. See if the external output jacks lose audio or just the system speakers, including subwoofer. This may help localize which unit has the problem.
Is the console stacked above or below other electronic units, it may be a heat related cutout? Reseat all your interconnect cords, I have seen corrosion occur on the square connectors.
These are expensive to have repaired, good luck. If you're daring enough, you make find free service manuals on websites like Elektrotanya, hifimanuals, hifiengine, and eserviceinfo (.com)
Jul 15, 2016 | Bose Av3-2-1 Series Ii Media Center...
Power cord is broken on my bose 321
Is the power cord bad, or the jack in the unit that you plug the AC cord into broken? If you're interested in repairing your Bose, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Dec 22, 2014 | Bose 321 GS series II
Bose 321 Series III Lateness
This depends on the source. If this happens internally (from a DVD in the 321) then the problem should be able to be resolved by just resetting the 321. (unplug the power cord from the sub for 30+ seconds) -If this is from external sources like a cable box, believe it or not, you can reset the cable box the exact same way. If resets don't fix this (and this is external) then check the cable box's settings for a/v delay compensation.
Jun 19, 2009 | Bose 3 2 1 GSX System
Bose Model 321
the bose will not play anew dvd comes up need paasword
Aug 08, 2008 | Bose Wave Radio
Bose 321 Remote not working
Pull off the front panel, be carefull there is a ribbon attached. Detach the ribbon. There are 2 ribbons attached to the front panel, one that leads to the IR (remote sensor) and other for the controls on the top of the unit.
Most likely the ribbon that goes to the IR sensor detached itself, this is common if the unit is dropped etc. Insert the ribbons (2) re-attach the front panel and the remote should work fine. You'll notice some tape on the IR ribbon, I suggest using some stronger tape, BOSE tape thats not very good.
This happened to me on my 3-2-1 GS II system and fixed it.
Jan 26, 2008 | Bose (321GS) System
Remote stopped working
already tried a new remote and new batteries. bose says the ir bulbs need replacement so i'm taking it in. shucks.
Dec 23, 2007 | Bose (321GS) System
Bose 321-GSX.
Not familiar with unit, but you can try a couple of things. Have you tried to play DVD's and CD's? If they both don't work you may have a laser problem. You can also hook up an external DVD/CD player to the coax and/or optical inputs and see if that will work. If this does, than you can still use the unit with an external source component. If that doesn't work you may need a new unit.
Jul 10, 2007 | Bose 3 2 1 GSX System
Bose (321GS) System Logo
26 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
