Question about Maytag Atlantis MDE7400AY Electric Dryer
Gas dryer doesn't heat up
I have a 6-year old Maytag Atlantis MD-15 gas dryer that does not heat up. I see that the burner does not ignite. I don't see pilot botton. How to ignite it? Anyone have a suggestion?
My maytag gas dryer doesn't put out enough heat, I have it on high heat what is the problem
Posted on Jan 27, 2009
    Sergeant:
  • 311 Answers
,when you start your gas dryer you should here two clicks, if so then your ignitor should begin to glow if two clicks and no glow [its your ignitor] but you can use a volt meter and make sure 110 volts at ignitor if voltage replace ignitor with new.if not two clicks then its going to be your thermal fuse its in the same area as the burner Therese two kinds[only one in each dryer tho],both white having two wires and small, one looks like a missile the other a fling saucer.ither kind you can put the two wires going to it to gether ,isolate them with tape and try heating.if heats replace.now if fuse you need to check for any blockage,inyou house or dryer.over heating can cause the fuse to open if i can be of more help you can email thru fixya God bless ,tom
Posted on Jan 10, 2009
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
Ignition works but doesn't stay on long enough to heat dryer
its either the hi-limit switch is weak on the burner tube,or the gas valve coils on the gas valve are weak and can no longer keep the gas valve open to supply gas,if they appear warm after operation they are most likely bad
May 24, 2012 | Maytag Dryers
The Maytag Atlantis dryer (gas) does not appear to be igniting the burner when it is turned on. The problem has gradually become more frequent over the last couple weeks. Now, it almost never lights up. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My Maytag Atlantis gas dryer does not get hot. What should I look at?
check out the ignition spark ignitor
that makes the burner to heat up
Mar 11, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
I HAVE A MAYTAG GAS DRYER MODEL MD-31 BURNER GOES ON AND OFF INTERMITTENLY ANY IDEAS. THANKS JIM
The burner is designed to turn on and off intermittantly. It is controlled by a t-stat and a hi and lo temp sensor
Jul 14, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Igniter works fine but there is no flame so therefore no heat
Replace the coils on this burner assembly. this will fix this issue you are having at this time.
The coils open and close the valves, which are responsible for gas flow. these coils are damaged.
May 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis gas dry is not heating up its about 6 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Mar 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis Dryer not heating up
Best guess is that one of the two solenoid coils on the gas valve is faulty, one has two connections and the other has three. Always replace BOTH solenoids even if only one has failed.
Aug 10, 2017 | Maytag Atlantis MDE7400AY Electric Dryer
How do I troubleshoot drying problems ?
could possibly be thermostats or heater if its just blowing cold air
Feb 11, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
279 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
