Question about Kenmore Washing Machines
WASHER MODEL 110 26492500 WILL DRAIN BUT NOT SPIN
Lumpy816
  • 246 Answers
SOURCE: kenmore front loader washer model 11042822201 won't drain and spin
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Posted on Jul 09, 2008
  • 196 Answers
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Nov 12, 2008
TheMobilian
  • 8220 Answers
SOURCE: washer won't drain or spin.
Kenmore top loader blues direct%20drive%20cabinet%20removal.jpg Use a screwdriver to remove the screws holding down the control panel,then swing it upwards. Pop the s clips in the rear and remove the lid switch disconnect. Tip the case forward and remove it.You will now be able to repair the washer! The lid must be closed for spin. The lid has a striker in it that pushes against the lidswitch arm. This switch allows for spin IF the lid is closed. The switch may have failed. Mechanically the striker may be broken or the actuator arm may be broken. ls2.jpg here is a broken lid switch You can test the switch. If you have a meter. If not you can simply bypass this switch. In my left hand here is the lid switch male plug which I have removed from the lid switch harness. If I wanted to i could simply place a jumper between the 2 outside wires and the washer would spin. a%20lid-switch-unplug.jpg Do not leave it bypassed if you have small children or braindead brother in laws. a%20coupling.jpg A 3 piece drive coupling
hidden%20screw%20on%20dd%20washer.jpg NOTE: newer models have the screw hidden
dd%20washer1.jpg Here is a view of the washer with the case removed.
To get to the broken coupling
remove the pump first then
the motor,both are held
together with quick clips. a%20broken%20coupling.jpg pictured here is a broken drive coupling.
Line up the new part and replace
the motor, pump, and
case in reverse order. NOTE: This looks hard but if you take your time it is easy enough to save you big bucks! My friend RM made a 44 second movie on this subject. Click here to see it
Posted on Dec 23, 2008
honeymokey
  • 3113 Answers
SOURCE: Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
Posted on May 17, 2009
  • 464 Answers
SOURCE: kenmore washer model 8537143 doesn't drain during
have you checked to see if anything has gotten caught in the pump?
Posted on Oct 15, 2009
Maytag bravos model mvwx500xw0 will not drain and spin properly
This could be a lot of things. One of them is the belt on the bottom that connects the transmission to the motor, of course it could be the transmission/clutch.
Feb 22, 2014 | Maytag MVWX500XW - Bravos XTM HE Top Load...
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
WASHER WONT DRAIN
Does the washer spin on rinse and drain cycles ok? If it does spin but won't drain, the problem is the plasic impeller in your drain pump. This model is a direct drive unit with a reversing motor that runs one direction for agitate, but reverses to spin the tub and operate the drain pump. So if it spins but DOES NOT drain, it's the drain pump, but if it doesn't spin or drain, than it's probably a lid switch. Also the tub to pump hose or pump discharge hoses may be clogged with something. If your mechanically apt, you can do this repair yourself and save a service charge. The pump runs about 30 dollars or so and is really easy to change out. Check out Youtube videos on Whirlpool washer repairs, they will show you everything to do. Yes, I said Whirlpool, because Roper is built by Whirlpool.
Hope this helps
kcomp1863
Dec 29, 2010 | Roper RAS6233KQ Top Load Washer
Maytag washer will not spin,rinse or drain Model#LAT9806AAE
need model # but most common would be belt/pump /timer / & lid sw . lid sw only works in spin .. is it a front load or top ? hope this will help m m
Nov 20, 2009 | Washing Machines
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
Bosch washer wont drain
you do not need a repairman! Buy the correct part from appliancepartspros.com-they are very helpful (I checked the part number on the BOSCH website first). The aprt cost me $48 and some cents. I (being a professional woman, = not a repairwoman!) changed the unit in less than 45 minutes. See my other posts for the procedure.
Jun 01, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Washing Machines Logo
47 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
