My Computer Does Not Boot
My PC does not boot when I press the power button on. The power comes alright but it will not boot and load files unless I leave it on for a long time and later reboot it again. This has been the problem for sometime now and I decided to take it that, the Intel Mother Board Intel D845PEBT2 needs to get heated up before it finally boots. I wish to bring this issue to your notice so you can help me out.
Another issue is that, it always reports a system date change(Problem with the C MOS date after it finally boots (thus during the booting up process). A computer technician in my area advised that I should change the CMOS battery, I inserted a new CMOS battery but the problem remains the same. Please help me.
  • Kalevra13
    Kalevra13 Jan 10, 2009
    Ya i have the same problem, everything powers up but no signal to monitor. Is the board sol or is there maybe a siple solution that you geneouses know of??? Thanks for any help.
  • limerickeire Mar 24, 2009
    My Gateway laptop ML6227b will not power up either with battery or power cable. What do you think could be wrong. Would apreciate your help on this. Regards from me Don
    Sergeant:
  • 192 Answers
If your system is still not holding the date and time after changing out the CMOS battery, then ther is what is called a "cold" solder joint on the motherboard thjat might work, as you mentioned, after the system is warm.
However, sicne the system does boot up and operate later, it is more likely that the power supply has the issue and is not delivering power properly until it stabalizes.
Get a replacement PS, just make sure that it has at least the same wattage as the original one. You don't even have to physically install it at first, just swtich all the connections from the old one to the new one and see if the system comes up right away. It is does, then do the swap. If not, you can return it and replace the motherboard.
Posted on Jan 10, 2009
Acer aspire x3812 power button
Check your hard drive, run a diagnostic. You may be able to boot into safe mode. Turn on the system and keep hitting the F8 key immediately. If that doesn't do it then try to reinstall the operating system. You may have a currupted Boot.ini or load manager. Lastly if you recently installed any device or program uninstall it. Good Luck
Apr 22, 2014 | Computers & Internet
Boot log 1525
venkatachalam,
How to Enable Boot Logging in Windows By Dan Gookin from Troubleshooting Your PC For Dummies, 3rd Edition
Two event log files that come in handy for troubleshooting your PC are the boot log files. These files are created when you specify boot logging as a start-up option. The files are named either ntbtlog.txt or bootlog.txt, depending on how old your PC is. These files, found in the Windows folder, list the success or failure of various pieces of Windows as it's loaded into memory from the PC's mass storage system.
You can enable or disable boot logging by using the MSCONFIG utility. Follow these steps in Windows 7 and Windows Vista:
  1. Press Win+R to summon the Run dialog box.
  2. Type msconfig and press Enter.
  3. In Windows Vista, type the administrator's password or click the Continue button.
  4. Click the Boot tab.
  5. Place a check mark by the item Boot Log.
  6. Click OK.
  7. Click the Restart button to restart now. Otherwise, click Exit without Restart.
    The logging doesn't take effect until you restart Windows, and you have no reason to do so immediately unless you really want to see the boot log.
In Windows XP, you can enable boot logging by pressing the F8 key when Windows first starts and choose the item Enable Boot Logging.
The boot log is overwritten every time you start Windows. And, the log is produced only when you turn on the boot logging option.
What can you do with the boot log? You can check for the failed installation of certain pieces of Windows or device drivers. The drivers or files are obviously flagged in the log. Because you know the filename, you can then either disable it from loading or look for an update.
  • Activating the boot log in Windows 7 or Windows Vista means that you configured your PC for a custom start-up. If that bothers you, disable the boot log after you cull whatever useful information you need from the boot log file; repeat the steps used to enable boot logging, but in Step 5, remove the check mark.
  • Traditionally, computer logs are all text files. They may have the filename extension log, or they may use txt instead.
  • You can search for log files by using the Windows Search command. Simply look for files named *log* anywhere on the hard drive, including system, hidden, and non-indexed locations.
  • Most log files are in plain text, but the text may be organized by using the XML, or Extensible Markup Language. XML is merely a way to organize information, and although XML files are readable as text, to get the most from the information, you should use an XML reader, such as the Event Viewer program.
  • If you find the file boot.ini on your Windows XP computer, you can enable boot logging by modifying the file. Open it in Notepad and look for the line that contains this text:
    Windows="Windows XP (That's only a portion of the line; in the file, it's longer). Add the text /bootlog to the end of the line. Save the file. When you restart Windows, boot logging takes place automatically.
Thank You,Dell-Jesse LDell Social Media and Communities
Aug 19, 2013 | Dell Inspiron M5030 Laptop
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
When booting up the devise, only the GPX logo appears. seems stuck and won't shut down unless i remove the battery. switch to off position does not work. I can load and delete mp3 files from the computer...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or you might try
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
Apr 10, 2011 | Computers & Internet
Reboot and select proper boot device or insert boot media in selected boot device and press a key
Hello cdcrowley2, it seems that the "problem is the [Operating System] is not loading correctly." The CPU is trying to find or fix the 'loading' of the OS!
Follow these instructions
To get the Computer to "Boot into the OS and "Loading Windows."
  • Restart the Computer
  • Next, just before the [Page] that you mentioned, "Displays," {Press the F12} button.
  • This will open the "Boot Menu:" [Priority Boot Sequence] window.
  • There will be a "list" of (Devices), Optical Drive / CD, SATA / HardDisk Drive, or USB...
  • I do not know the "Configuration of your Operating System" or the Drive: that "holds the Boot [NTLDR] files.
  • It may also hold the "Master Boot Record" or Boot.ini file?
  • So, what you need to do is give the Drives a "Priority Boot Sequence," meaning , you will 'place' the Drives in the 'order' of Bootup [First] listings.
  • You will use the {Arrow buttons} to 'move the "Drives."
  • More than 'likely' it will be the (*Optical Drive / SATA or Hard Disk Drive}.
Try each, and hopefully the Computer will make it to "Windows," and you can "Login!"
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Feb 27, 2011 | Acer Computers & Internet
MY COMPUTER COULD NO LONGER BOOT UP AFTER POWER FLUCTUATION
Check the power supply, sounds like it isn't getting enough electricity out the the PC components.
Jun 09, 2009 | Intel D845PEBT2 Motherboard
Pc not starting up
Can you at least boot up pass the BIOS POST?
If you can try tapping F8 repeatedly, sometimes it will give you choices of boot devices, so just choose your primary hard drive press enter and tap F8 again until you see the Advance Boot Menu, choose safe mode and see if you can successfully boot into it.
Once in safe mode click on Start>Run then type in restore. Anew window will pop up. double click on on rstrui icon.
This will now launch the System Restore window click on the radio button "Restore my Computer to an earlier time" and press enter. A calendar will show you the available dates that you can restore from. Choose the day you know that your computer was stable.
If your computer still wont boot up do the same procedure and choose another date.
"NEVER GO BACK TO MORE THAN 30 DAYS UNLESS YOU ARE OUT OF OPTIONS"
Hope this solves your problems don't worry this is just the 1st solution there are many more.
Jan 21, 2009 | Acer Aspire E500 PC Desktop
MY PC HAS BOOTING PROBLEM
Hi bridey28, when you replaced the cmos battery & the bios did not maintain the correct time than the cmos is not at fault. More likely its your power supply. The cmos receives its power (Recharge) from the power supply. An average cmos battery should last for 5 years. The fact that you attempt to power up the PC & you have to wait, points to a power supply problem. Not a bios problem.
Bios corruption is rare, unless you have tried to flash the bios & it failed. Replace the power supply before attempting flashing the bios. Every manufacture warns against flashing the bios. Only flash the bios if your 100% sure that it will correct a bios malfunction. If the issue presist after replacing the power supply, Intel has instructions of (How to flash the bios) on their site.
Here are the instruction from Intel for your MB model number.
http://downloadmirror.intel.com/5519/ENG/BIOS%20Update%20Readme.pdf
You'll need this link to download the bios file;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=899&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21#SAP
Good luck bridey28!
Need more info, post here.
Mike
Jan 14, 2009 | Computers & Internet
My PC does not boot when I press the power button on. The power comes alright but it will not boot and load files unless I leave it on for a long time and later reboot it again. This has been the problem...
You need to clear cmos usually on board is a little coloured jumper,but also first disconnect power plugs from board which come from the big psu,normally have a little clip you have to squeeze,find cmos normally 3 pins with a littl jumper move it from one set of pins to next set of 2 pins,you normally have i pin exposed,so move left or right and hold for 10 seconds make sur e you put back as it was,reconnect psu plugs ,reboot enter the bios normally Delete button or what it says on your screen normally setup button ,reset your time and date and make sure you save your settings before you leave bios page
I went to reformat and the computer took a mind of its own, not letting me!
Please try to reboot PC and get to the BIOS,
Pressing F2, DEL or ESC key during bootup, and change there the Boot Priority, Boot from CD.
Let me know the result, otherwise I will investigate further.
Also let me know the Hardware Detail of your PC.
Oct 09, 2008 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
427 people viewed this question
David Payne
David Payne
