Question about Cuisinart Programmable Espresso Maker
The cuisinart programmable espresso maker water keeps coming out onto tray
ThaMp3Doctor
  • 8596 Answers
SOURCE: my cuisinart coffee maker leaks
Cuisinart – leaking from bottom
There is a tube inside that is melted, damaged - cannot get this part from manufacturer. I would call Cuisinart to see if you are still in warranty.
-Tha Mp3 Doctor
Posted on Dec 15, 2008
  • 10 Answers
SOURCE: can't get milk to foam
How long have you had the machine? Use a straight pin and poke the opening of the wand. It may be blocked. If the bottom of the wand can be removed, use some pliers, and CAREFULLY remove it, soak it in hot water. Rinse it thoroughly, and replace it back on the machine. If you cannot remove the wand, turn the machine upside down, and check the opening to the wand. It most likely is stopped up. Run vinegar and water through your machine once a week. Calcium build up does the same thing. Good luck! Happy Lattes!
Posted on Feb 05, 2009
ThaMp3Doctor
  • 8596 Answers
Place 1/3 part distilled white vinegar and 2/3 part water into the water reservoir. Turn the machine on and wait for the heat light to go off. Once the heat light goes off, turn the steam vs. water knob to the water drop icon, and turn the main function knob to steam/water. Make sure to have your frothing cup underneath the steam element ready to catch the water. The vinegar/water solution should clear out the calcium that clogs the steam element. Also, remove the cover to the steam element and dip it in a bowl with vinegar for about 5 minutes, and use something like a pipe cleaner to clean out that cover. Then apply vinegar and hot water to a rag and clean the calcium off the shaft of the steam element. Once you are all finished with this, run plain water through the espresso maker on the steam/water setting to clear out the bitter vinegar residue. Now, try again to make espresso and froth it.
Since milk contains calcium, the steam element has to be decalcified more often than a regular coffee maker. The EM-100 is a beautiful machine, but it is definitely high-maintenance - you will probably spend more time cleaning it than making cappuccino, etc.
-Tha Mp3 Doctor (is also a huge Cuisinart fan)
Posted on Feb 26, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: how do i use my Cuisineart Coffee maker
Here is the link to the full user's manual:
http://www.cuisinart.com/share/pdf/manuals/dcc-1100.pdf
Posted on Sep 29, 2009
SOURCE: My cuisinart cofee maker is clogged. Water goes
If you pull out the plastic stem on the back left side, you can access the filter at the bottom. The filter can be popped out of this piece, washed and replaced.
Posted on Dec 30, 2009
Leaking underneath
You are not alone having the water leak in your SS-700. For better understanding what caused that leak please read the review on Cuisinart SS-700:
http://www.cuisinartfoodprocessordeals.com/cuisinart-ss-700/
Nov 22, 2011 | Cuisinart SS-700 5-Cup Coffee Maker
I have cousine art programable espresso machine ( 3 months old). The lights keep flashing when I turn it on and never stop. There is no usual sound when I turn it on also???
Hi.It needs to be looked at by a repairer. Could be a blockage in the water system or the main ECU board has a fault. The pump maybe faulty or a sencor mabe faulty. A repairer can fix it for you. Dazza REPAIRER
Sep 23, 2011 | Cuisinart Programmable Espresso Maker
Cuisinart 12-cup grinder coffemaker all gummed up
It is endemic to this unit - condensation builds up in the grind chute, which makes the grinds stick to the walls of the chute. Decalcifying with vinegar/water helps, but only in an indirect way - by keeping the inside tubing clean, decalcifying generally allows the water to flow through the machine without obstruction. Inside tubing that has calcium, lime deposits built up obstructs water, and makes it flow through the machine slower - when water flows more slowly through the machine, the machine steams off the water at a higher rate, hence more condensation builds up in the grind chute walls.
Generally, i have found all Cuisinart coffee and espresso makers to be high maintenance to a greater or lesser extent, but the Grind-n-Brews have the highest cleaning/maintenance requirement.
Mar 26, 2009 | Cuisinart Coffee Makers & Espresso...
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
New machine, following instructions, but water will not pour thro
Make sure there is water in the reservoir. Take the water reservoir out of the back and reposition it. Turn the power button on - wait for the heating light to go off - then turn the dial to the icon that looks like a coffee cup. Water should come through.
Dec 25, 2008 | Cuisinart Programmable Espresso Maker
Cuisinart programmable espresso maker em-200C
Currently, both my manual and steam button are flashing. No idea why. Any help?
Feb 27, 2008 | Cuisinart Programmable Espresso Maker
Cuisinart Programmable Espresso Maker Logo
35 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
